TriState Switch
433Mhz opensource Receiver & Transmitter.
pkriek
TriState Switch
Post by pkriek »
I have a switch detected thru the RFLINK gateway.
With the remote of the switch, I press 1 time to switch it on, 1 time to turn it Off.
thru Domoticz, only the "turn on" seems to activate the device. meaning have to press twice in Domoticz to switch (Turn Off is doing nothing to the switch.
How can I solve this?
gizmocuz
Re: TriState Switch
Post by gizmocuz »
Buy a better switch !
Serious.. as nobody knows the actual state of the switch, it is of no use.
Image you are placing your sprinkler system behind this, and make a timer like
10:00am -> On
12:00am -> Off
So actually 12:00am should be -> On (because second ON turns it off)
Now image if the switch was in a wrong state, this will now turn off your sprinkler at 10:00am and on 12:00am On, meaning 22 hours a day it is on
Its probably a china device ! .... home automation is not cheap, just invest in a good 433Mhz switch, you have them from 6 euro+
jjansen
Re: TriState Switch
Post by jjansen »
gizmocuz wrote:Buy a better switch !
Can you give an example of a good switch?
pkriek
Re: TriState Switch
Post by pkriek »
indeed a cheap chinese switch. I bought these since I tested with a chacon switch, which gives similair dissapointing results.
what do you suggest to buy?
thanks
gizmocuz
Re: TriState Switch
Post by gizmocuz »
Well here (in holland) the Klik aan klik uit (kaku) switches are good, outside holland it is called coco
but any switch that is supported and have a separate on/off and if needed a set level, is OK
pkriek
Re: TriState Switch
Post by pkriek »
afte updating the rflnk firmware to te latest, the devices are detected as Chuango and do not work anymore.
I see there is work in progress, so I will wait untill the next version to see wat happens
devros
Re: TriState Switch
Post by devros »
hello i have same problem anyone have solution for this?
switch on works but when i want switch off i have click again (light is off now) ,but then switch in domoticz is on
i have latest rflink version
2017-01-14 22:25:16.083 RFLink Sending: 10;TriState;069498;1;ON
2017-01-14 22:25:20.022 RFLink Sending: 10;TriState;069498;1;OFF
edit: find that switch can be switched to two buttons mode (one for on and one for off)
when i switched
reflink read this
SWITCH ON
20;88;EV1527;ID=0d7c74;SWITCH=08;CMD=ON;
SWITCH OFF
20;89;EV1527;ID=0d7c74;SWITCH=02;CMD=ON;
but domoticz cant add this in autodetect mode...
here is debug log:
tristate on/off (one button on remote)
20;B6;DEBUG;Pulses=50;Pulses(uSec)=1020,270,930,270,240,960,930,270,240,960,930,270,930,270,930,270,930,240,930,270,240,960,240,960,240,960,930,240,930,270,930,270,240,960,930,270,240,960,240,960,240,960,930,270,240,960,24;
20;B7;EV1527;ID=0d7c74;SWITCH=04;CMD=ON;
20;B8;DEBUG;Pulses=50;Pulse,240,960,930,270,240,960,930,270,930,270,930,240,930,270,930,240,240,960,240,960,240,960,930,270,930,270,930,240,240,960,930,270,240,960,240,960,240,960,930,240,240,960,240,960,240,6990;
20;B9;DEBUG;Pulses=34;Pulses(uSec)=1020,270,930,240,240,960,930,270,240,960,930,270,930,270,930,240,930,270,930,270,240,960,240,960,240,960,930,240;
and here is A button on and B button off
A
20;BE;EV1527;ID=0d7c74;SWITCH=08;CMD=ON;
20;BF;DEBUG;Pulses=50;Pulses(uSec)=1020,240,930,270,240,960,930,240,240,960,930,240,930,240,930,270,930,270,930,240,240,960,240,960,240,960,930,240,930,240,930,270,240,960,930,240,240,960,240,960,930,240,240,6990;
B
20;C2;DEBUG;Pulses=511;Pulses(uSec)=180,960,120,960,90,960,90,960,120,960,120,960,120,960,90,960,120,960,120,1920,120,960,120,1920,90,960,120,960,120,960,120,960,120,1920,120,1920,120,1920,90,1920,120,3960,120,1020,120,960;
20;C3;DEBUG;Pulses=204;Pulses(uSec)=180,3960,90,1020,120,960,120,960,120,960,90,960,120,960,120,960,120,960,90,960,120,960,120,1920,120,960,120,1920,90,960,120,960,120,960,120,1920,120,1920,90,960,120,960,120,1920,120,1920;
20;C4;DEBUG;Pulses=511;Pulses(uSec)=390,1860,390,1860,390,1860,390,1860,390,1860,390,870,390,870,390,9870,390,900,390,870,390,870,390,870,390,870,390,870,390,870,390,870,390,870,390,1860,390,1860,390,870,390,870,390,1860,3;
here is link for switches https://www.aliexpress.com/item/Crystal ... 0.0.5P9cM4
they looks really nice and are easy to connect
