schneider connect and domoticz
maxiepax
Post by maxiepax »
I've searched the documentation to try get some information on how this is even supposed to work. either i suck at searching or this just isn't in there.
I have a Fibaro Dimmer in the ceiling, which i can control via a Razberry shield and Domoticz. So this works as intended.
For one reason or the other, i needed a wireless button to active the light. So since i use schneider light switches everywhere else, i purchased their z-wave 'CONNECT' series with 2 gangs. Awesome... sofar..
I plug in the battery and thought i might do the usual "press 3 times to connect", which actually found something. However it doesn't work,.. i think?
I then tried to find a way to pair this button, with the lightswitch in domoticz, but i'm at a loss here..
Either the button isn't working, or im simply doing something wrong in domoticz..
How should this actually work?
Do i pair both the button and the light together in domoticz?
or do i pair each with domoticz, and then via z-wave, them together? If im not mistaken you can pair devices 4 ways?
Any documentation, search terms, or guidance is very much appreciated.
TheBod
Re: schneider connect and domoticz
Post by TheBod »
Very curious to hear more about the Schneider Electric connect series. Do they operate on 868MHz frequency and if so how are you communicating to them using Domoticz?
