I've searched the documentation to try get some information on how this is even supposed to work. either i suck at searching or this just isn't in there.
I have a Fibaro Dimmer in the ceiling, which i can control via a Razberry shield and Domoticz. So this works as intended.
For one reason or the other, i needed a wireless button to active the light. So since i use schneider light switches everywhere else, i purchased their z-wave 'CONNECT' series with 2 gangs. Awesome... sofar..
I plug in the battery and thought i might do the usual "press 3 times to connect", which actually found something. However it doesn't work,.. i think?
I then tried to find a way to pair this button, with the lightswitch in domoticz, but i'm at a loss here..
Either the button isn't working, or im simply doing something wrong in domoticz..
How should this actually work?
Do i pair both the button and the light together in domoticz?
or do i pair each with domoticz, and then via z-wave, them together? If im not mistaken you can pair devices 4 ways?
Any documentation, search terms, or guidance is very much appreciated.
schneider connect and domoticz
TheBod
Re: schneider connect and domoticz
Very curious to hear more about the Schneider Electric connect series. Do they operate on 868MHz frequency and if so how are you communicating to them using Domoticz?
