I bougth the Intertek 75.006.1455010x10 switch at the Action. Unfortunately I cann't get it to work. the screendump from the RFXmgr is:
5-2-2016 20:40:02
Packettype = Lighting2
subtype = AC
Sequence nbr = 0
ID = 0288402 decimal:2655234
Unit = 1
Command = On
Signal level = 7 -64dBi
5-2-2016 20:40:03
subtype = HomeEasy EU
Sequence nbr = 1
ID = 0008666 decimal:34406
Unit = 1
Command = On
Signal level = 5 -80dBi
I tried sending the HomeEasy Eu and th AC commands seperately but that is not working any clue how to solve this?
Action Intertek 75.006.1455010x10 switch RFXcom
Frankm
- image2.JPG (77.34 KiB) Viewed 2781 times
- image1.JPG (89.94 KiB) Viewed 2781 times
PeterFleur
- Domoticz version: 2.4739
Re: Action Intertek 75.006.1455010x10 switch RFXcom
Did you get this to work?
RaspberryPI
ZWave
RFXtrx433E
ZWave
RFXtrx433E
b_weijenberg
- Target OS: -
Use Ext2 firmware and configure an IT On/Off module in Domoticz.
The PROmax and FA500 use only the IT protocol which can be transmitted by the RFXtrx433E - Ext2 firmware.
The remote transmits 3 protocols, IT, AC and ARC. IT is received by the RFXtrx433E as Lighting4 but this could not be used. The AC and ARC can be used to detect the remote but the module can not be controlled by AC or ARC!
For a FA500DSS dimmer configure an IT Dimmer module in Domoticz.
RFX-433, RFX-433EMC, RFX-868
edgarhildering
- Domoticz version: 2023.2
I cannot find InterTek in the Set Mode list of Domoticz. The strange thing is that I managed to control the switches with the RFXCOM utility (under windows), using the EXT2 firmware. All works fine there. But I simply cannot define a device as 'IT', it does not pop up in the list:
It seems I am missing a step... Any suggestions?
Thanks in advance --Edgar
RaspberryPi running Domoticz 2025.2
PIRs + lightswitches
thermometers + heating control
hygrometers + dehumifiers
TUYA switches
TUYA switches
cobra045
- Domoticz version: 3.4834
Hallo Edgar,
yes you need to set it somewhere else, see http://www.domoticz.com/forum/viewtopic ... 038#p81514
step (2) Set Type to IT
Or see the whole discussion http://www.domoticz.com/forum/viewtopic ... 44&t=10228
Regards cobra
Regards cobra
