domoticz in synology as package! Available now.
amz4u2nv
Post by amz4u2nv »
My synology box just got updated automatically, and now I can't start Domoticz package. Nothing in the logs
I've got ds 215j on 4031-7
Please help, wife is going to kill when the lights don't work..
Egregius
Domoticz version: v2024.7
Post by Egregius »
I think you need the beta 6 repo (link some posts above).
And disable automatic updates, do them manually on a moment you'll have time in case something goes wrong.
gizmocuz
Post by gizmocuz »
Yep, and that is one of the reasons i always say that you should be able to control everything manually as well ;)
amz4u2nv
Post by amz4u2nv »
Thanks guys.. add beta repo to synology and updated to beta -
4989-7
But still not starting-
getting the following in the logs
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domotifz/lib/libboost_thread.so.1.60.0)
this occurs multiple times,
also libboost_date_time.so.160.0
Any ideas?
bossybum
Post by bossybum »
Hey Guys,
I have updated to DSM 6 and have trouble using openzwave usb drivers from the recent Jadahl 6.0 package. It seems that the ACM0 driver is available, but communication to the device does not work. IE the controlpanel is blank
Im on a DS415+
Have any of you experienced this ?`
BTW: Jumbotroll!!! keep up the good work!!
jumbotroll
Post by jumbotroll »
bossybum wrote:Hey Guys,
Im on a DS415+
No need to install UsbSerialDrivers package.
Remove UsbSerialDrivers package and just install domoticz.
All drivers are included in the domoticz package.
Install domoticz from here: http://www.jadahl.com/domoticz_beta_6/?arch=avoton
Reboot NAS.
https://paypal.me/Jumbotroll
Jumbotroll
bossybum
Post by bossybum »
I have deleted the usbserial package from /var/packages and /volume1/@appstore
I had to do this, as it would not allow uninstall of the package.
However, it still won't recognize the aeon labs G5 adapter. it seems that it's there, under the ACM0 name, but it does not work....
Any clues ?
bossybum
Post by bossybum »
bossybum wrote:I have deleted the usbserial package from /var/packages and /volume1/@appstore
Any clues ?
Found the culprit.
It was my USB hub that caused the trouble.
Jumbotroll, Thanks for a quick reply!
clubeddie
Post by clubeddie »
Domoticz package won't work anymore after DSM update (DSM 6.0-7321), mine synology updated last night and i cannot start Domoticz anymore.
In the logfiles i see
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_thread.so.1.59.0)
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_date_time.so.1.59.0)
All other packages are also updated on my synology. So it is completely up to date.
More people facing this issue?
(synology DS213J)
Egregius
Post by Egregius »
Do you use the beta_6 repo of Jumbotroll?
clubeddie
Post by clubeddie »
Shoot, first read then post. I am reading above entries now. I missed these. Trying to install the beta. Come back soon with the answer!
clubeddie
Post by clubeddie »
Problem solved. Beta is working perfect!
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Same here... Added the package source.. Pushed the update button and everything was up and running on the DS215J!
Verstuurd vanaf mijn SM-G925F met Tapatalk
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
so what is the plan for all the users still on 5.2?
first upgrade domoticz to dsm6 package 5010 and then upgrade to dsm 6(if you want to)
or first upgrade to dsm 6 and then upgrade domoticz to 5010?(stop package before upgrade?)
jumbotroll
This worked for me:
1. Backed up domoticz database.
2. Uninstalled domoticz from package center.
3. Updated NAS software to DSM 6.0-7321.
4. installed latest Domoticz beta for DSM 6.0 from http://www.jadahl.com/domoticz_beta_6/i ... llist=true
5. Restored domoticz database file.
Thats All!
Worked without any problem on my DS712+ arch-x86
Jumbotroll
mschut
Domoticz version: V3.5613
Post by mschut »
Maybe the wrong threat, but it is definitely about Evohome. I would like to use an event combined with the status of the Evohome. I know I cant set tempretaures (yet), but what I would like to do is turn to holiday light switching when the Evohome system has the status "Away". Sounds logic. If I am away, the heating is turned to "Away", whcih is also a nice time to switch lights on and off at night.
I can find the Evohome main controller in the blocky devices, buit I can't act on the status "away". Is there a way to accomplish what I am looking for?
amz4u2nv
Post by amz4u2nv »
Anyway to configure ssl on Domoticz package can't find any confit file
lampje25
Post by lampje25 »
I have updated to 3.5010, and now I saw that the data from Sunday rises to Saturday
See picture
this applies for electricity, gas and KWH meters
Saturday -> 17.235
Sunday -> 7.002
How can this be solved?
Or is this a bug
Gravityz
Post by Gravityz »
I have the same and i am still on 5.2 V3.4958
my guess it is a DST bug since we switched summertime on sunday 02:00
really strange because i would not havre expected this setting the time 1 hour forward.
You would expect this when setting it back(because then you have 2 settings with the same time)
i will make a note of this on github
gizmocuz
Post by gizmocuz »
Gravityz wrote:I have the same and....
Please search the forum:
http://www.domoticz.com/forum/viewforum.php?f=6
it is the second or first post here on this page, it is a 'sticky' post
There is also a sollution posted there
