Check, will look into it.bvduijv wrote:Please have a look at: viewtopic.php?f=37&t=8884&start=680#p75187RoadXY wrote:Setpoint has issues?bvduijv wrote:[I really would love to have the setpoint working without problems. And I do not see it on the issue list anymore. Could you please have a look at it?
KR, Bart
Could you please explain?
- RoadXY
- Domoticz version: 2.2331
Re: Domoticz app 2.0
That would be very nice. Thanks in advance.RoadXY wrote:Check, will look into it.bvduijv wrote:Please have a look at: viewtopic.php?f=37&t=8884&start=680#p75187RoadXY wrote: Setpoint has issues?
Any progress in working on the blinds / rolling shutter fix?
http://www.domoticz.com/forum/viewtopic ... nds#p76800
Or is it fixed in the upcoming release?
I bought the premium version, with the wear gadget, but I cannnot see the app on my Samsung wear watch. What do I wrong? I turnt the function on my Phone.
No table MobileDevices in my db. Is this table created in runtime or is it depending on a certain version of Domoticz?RoadXY wrote:MobileDevicesceedebee wrote:Okay, installed the SQLiteExpert and I can browse the database (a backup file ). Which table is the registration ID supposed to be in?
- Domoticz version: 3.5877
I updated the server to the latest March stable - v3.4834 and it works after that.ceedebee wrote:No table MobileDevices in my db. Is this table created in runtime or is it depending on a certain version of Domoticz?RoadXY wrote:MobileDevicesceedebee wrote:Okay, installed the SQLiteExpert and I can browse the database (a backup file ). Which table is the registration ID supposed to be in?
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
Updated yesterday, working now. But to many notifications, my fault. Need some more Lua programming.
- galadril
- Domoticz version: latest
You can suppress some notifications from the settings screenceedebee wrote:Updated yesterday, working now. But to many notifications, my fault. Need some more Lua programming.
- galadril
Samsung gear doens't have Android Wear as his OS, but Tizen.Richard wrote:I bought the premium version, with the wear gadget, but I cannnot see the app on my Samsung wear watch. What do I wrong? I turnt the function on my Phone.
We support Android Wear....
- galadril
There is an option to show buttons instead of switches in the next versionRoadXY wrote:Because space is limited on your mobile (especially the 3,8" devices which we also support).marktn wrote:Update are comming fast, keep up the good work!
What is still do not understand is why do switches have only a on or off function.
Scenes do have both, i like to have that also for my switches. When the switch doesnt respond i have to switch double.
I am using kaku.
send from tapatalk app.
This isn't true - the Samsung Gear Live is an Android Wear watch - the LG G Watch and the Samsung Gear Live were the first 2 Android Wear watches available, and thus - are very cheap now to pick up from places like eBay. If this indeed a Samsung Gear Live and the app isn't showing up - you probably just need to resync apps in the Android Wear companion app on the phone.galadril wrote:Samsung gear doens't have Android Wear as his OS, but Tizen.Richard wrote:I bought the premium version, with the wear gadget, but I cannnot see the app on my Samsung wear watch. What do I wrong? I turnt the function on my Phone.
- galadril
This isn't true - the Samsung Gear Live is an Android Wear watch - the LG G Watch and the Samsung Gear Live were the first 2 Android Wear watches available, and thus - are very cheap now to pick up from places like eBay. [/quote]galadril wrote:Samsung Gear doens't have Android Wear as his OS, but Tizen.
As stated in my Quote..
I thought he had 'Samsung Gear' watch... that IS Tizen OS.
Originally released as an Android-based device, Samsung replaced the operating system with Tizen through the May 2014 software update
- jisse44
- Domoticz version: 4.10915
I have the current Play store premium version of the app, because I want to use the geofencing part. I have a Samsung S3 4G (Kitkat 4.4.4)
On domoticz server I created a Virtual switch On/Off connected on a Dummy hardware. Then I set a geofence for Home in the app.
When I enter the place, sometimes I have the notification and the button is turning On, sometimes I have to go in Parameters > Geofencing, and the app detects the place and I have the notification each time I go in the Parameters.
And when I left the place the switch never switched off, even if I go in Parameters > Geofencing.
When I enable Debug mode, I see the log in Parameters > Geofencing part (Starting Geofence service) each time. It seems that the service starts when I go in the Parameters, and stops as soon as I leave the menu.
galadril wrote: There is an option to show buttons instead of switches in the next version
While you're at it, is there a way you could make the font size in the widgets changeable? It's huge, especially on tablets and takes up way more space than needed...
keep up the good work, really looking forward to the nfc fix.
- RoadXY
At what range did you set you Geofence to?jisse44 wrote:Hello,
If you disable GPS and reboot your device, how accurate is Google Maps to pinpoint your location?
Is Wifi enabled on your device?
How reliable/strong is your cell data connection (no wifi but 3G/4G)?
https://github.com/domoticz/domoticz-an ... -geofences
- Domoticz version: V3.8650
And for my MySensors HVAC device set point from 4*C to 55*Cpiokuc wrote: For set temp should be from 4*C to 28*C. This is example for Danfoss thermostat. Now is from 10 to 30*C.
Currently I get 10 to 30*C
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
I downloaded te new beta.
Still the setpoint is not working as expected for *.5 temps. When opening the setpoint it is now oke. But when changing the setpoint the first attempt is not doing anything. The next attempt do set the temp from *.5 to *.0.
However it is looking better and better. Just keep it going!
eg.
When temp is set on "18.5" and pressing + the setpoint is doing nothing the first press. Another press sets the temp to 19
When temp is set on "18.5" and pressing - the setpoint is directly going to 17.5
eg.
- jisse44
300 metersRoadXY wrote: At what range did you set you Geofence to?
It is about 40-80 meters, and 10-20 meters after 30 seconds.RoadXY wrote:If you disable GPS and reboot your device, how accurate is Google Maps to pinpoint your location?
It's strange because whan I leave home, I switch on GPS for Waze, and when I returned in the evening, GPS is on with Waze too.
When I go in Geofence parameters, I must put the Lat/Long manually: when I push GET button, I have the "Could not find location, please try again" message.
And when I come back and I return in Geofence parameters, I have 'Enter in Work' notification each time.
In logcat, I have something like:
V/GeoSettingsActivity(13404): We have permission, let's go!
D/GEOFENCE(13404): Triggered entering a geofence location: Work
- RoadXY
But when do you set your thermostat to below 10*C or above 30*C?pj-r wrote:And for my MySensors HVAC device set point from 4*C to 55*Cpiokuc wrote: For set temp should be from 4*C to 28*C. This is example for Danfoss thermostat. Now is from 10 to 30*C.
- RoadXY
Could you create a video and PM that to me please?jisse44 wrote:300 metersRoadXY wrote: At what range did you set you Geofence to?
In logcat, I have something like:Code: Select all
V/GeoSettingsActivity(13404): We have permission, let's go! ... D/GEOFENCE(13404): Triggered entering a geofence location: Work
