RoadXY
Domoticz version: 2.2331
Re: Domoticz app 2.0
Post by RoadXY »
bvduijv wrote:
RoadXY wrote:
bvduijv wrote:[I really would love to have the setpoint working without problems. And I do not see it on the issue list anymore. Could you please have a look at it?
KR, Bart
Setpoint has issues?
Could you please explain?
Please have a look at: viewtopic.php?f=37&t=8884&start=680#p75187
Check, will look into it.
bvduijv
Post by bvduijv »
RoadXY wrote:
bvduijv wrote:
RoadXY wrote: Setpoint has issues?
That would be very nice. Thanks in advance.
EdwinDaems
Post by EdwinDaems »
Any progress in working on the blinds / rolling shutter fix?
http://www.domoticz.com/forum/viewtopic ... nds#p76800
Or is it fixed in the upcoming release?
Richard
Post by Richard »
I bought the premium version, with the wear gadget, but I cannnot see the app on my Samsung wear watch. What do I wrong? I turnt the function on my Phone.
ceedebee
Post by ceedebee »
RoadXY wrote:
ceedebee wrote:Okay, installed the SQLiteExpert and I can browse the database (a backup file ). Which table is the registration ID supposed to be in?
MobileDevices
No table MobileDevices in my db. Is this table created in runtime or is it depending on a certain version of Domoticz?
asjmcguire
Domoticz version: 3.5877
Post by asjmcguire »
ceedebee wrote:
MobileDevices
I updated the server to the latest March stable - v3.4834 and it works after that.
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
ceedebee
Post by ceedebee »
Updated yesterday, working now. But to many notifications, my fault. Need some more Lua programming.
galadril
Domoticz version: latest
Post by galadril »
ceedebee wrote:Updated yesterday, working now. But to many notifications, my fault. Need some more Lua programming.
You can suppress some notifications from the settings screen
galadril
Post by galadril »
Richard wrote:I bought the premium version, with the wear gadget, but I cannnot see the app on my Samsung wear watch. What do I wrong? I turnt the function on my Phone.
Samsung gear doens't have Android Wear as his OS, but Tizen.
We support Android Wear....
galadril
Post by galadril »
RoadXY wrote:
marktn wrote:Update are comming fast, keep up the good work!
What is still do not understand is why do switches have only a on or off function.
Scenes do have both, i like to have that also for my switches. When the switch doesnt respond i have to switch double.
I am using kaku.
send from tapatalk app.
Because space is limited on your mobile (especially the 3,8" devices which we also support).
There is an option to show buttons instead of switches in the next version
asjmcguire
This isn't true - the Samsung Gear Live is an Android Wear watch - the LG G Watch and the Samsung Gear Live were the first 2 Android Wear watches available, and thus - are very cheap now to pick up from places like eBay. If this indeed a Samsung Gear Live and the app isn't showing up - you probably just need to resync apps in the Android Wear companion app on the phone.
galadril
Post by galadril »
galadril wrote:Samsung Gear doens't have Android Wear as his OS, but Tizen.
This isn't true - the Samsung Gear Live is an Android Wear watch - the LG G Watch and the Samsung Gear Live were the first 2 Android Wear watches available, and thus - are very cheap now to pick up from places like eBay. [/quote]
As stated in my Quote..
I thought he had 'Samsung Gear' watch... that IS Tizen OS.
Originally released as an Android-based device, Samsung replaced the operating system with Tizen through the May 2014 software update
jisse44
Domoticz version: 4.10915
Post by jisse44 »
I have the current Play store premium version of the app, because I want to use the geofencing part. I have a Samsung S3 4G (Kitkat 4.4.4)
On domoticz server I created a Virtual switch On/Off connected on a Dummy hardware. Then I set a geofence for Home in the app.
When I enter the place, sometimes I have the notification and the button is turning On, sometimes I have to go in Parameters > Geofencing, and the app detects the place and I have the notification each time I go in the Parameters.
And when I left the place the switch never switched off, even if I go in Parameters > Geofencing.
When I enable Debug mode, I see the log in Parameters > Geofencing part (Starting Geofence service) each time. It seems that the service starts when I go in the Parameters, and stops as soon as I leave the menu.
four2six
Post by four2six »
galadril wrote: There is an option to show buttons instead of switches in the next version
While you're at it, is there a way you could make the font size in the widgets changeable? It's huge, especially on tablets and takes up way more space than needed...
keep up the good work, really looking forward to the nfc fix. :D
RoadXY
Post by RoadXY »
jisse44 wrote:Hello,
At what range did you set you Geofence to?
If you disable GPS and reboot your device, how accurate is Google Maps to pinpoint your location?
Is Wifi enabled on your device?
How reliable/strong is your cell data connection (no wifi but 3G/4G)?
https://github.com/domoticz/domoticz-an ... -geofences
pj-r
Domoticz version: V3.8650
Post by pj-r »
piokuc wrote: For set temp should be from 4*C to 28*C. This is example for Danfoss thermostat. Now is from 10 to 30*C.
And for my MySensors HVAC device set point from 4*C to 55*C ;)
Currently I get 10 to 30*C
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
bvduijv
Post by bvduijv »
I downloaded te new beta.
Still the setpoint is not working as expected for *.5 temps. When opening the setpoint it is now oke. But when changing the setpoint the first attempt is not doing anything. The next attempt do set the temp from *.5 to *.0.
However it is looking better and better. Just keep it going! :-) :D
eg.
When temp is set on "18.5" and pressing + the setpoint is doing nothing the first press. Another press sets the temp to 19 :?: :?: :?:
When temp is set on "18.5" and pressing - the setpoint is directly going to 17.5 :?: :?: :?:
jisse44
Post by jisse44 »
RoadXY wrote: At what range did you set you Geofence to?
300 meters
RoadXY wrote:If you disable GPS and reboot your device, how accurate is Google Maps to pinpoint your location?
It is about 40-80 meters, and 10-20 meters after 30 seconds.
It's strange because whan I leave home, I switch on GPS for Waze, and when I returned in the evening, GPS is on with Waze too.
When I go in Geofence parameters, I must put the Lat/Long manually: when I push GET button, I have the "Could not find location, please try again" message.
And when I come back and I return in Geofence parameters, I have 'Enter in Work' notification each time.
In logcat, I have something like:
V/GeoSettingsActivity(13404): We have permission, let's go!
D/GEOFENCE(13404): Triggered entering a geofence location: Work
RoadXY
Post by RoadXY »
But when do you set your thermostat to below 10*C or above 30*C?
RoadXY
Post by RoadXY »
300 meters
Could you create a video and PM that to me please?
