sudo pip install requests==2.5.3
./evo-update.sh
./evo-update.sh
Gordon,gordonb3 wrote:Did you enter your evohome username and password in the settings file? The script does not check whether the return from the client is in fact json or an html error page.
Edit: just noted that you stated not to have an account. You must have one for the scripts to succeed.
I think thats a problem that i dont have an account on mytotalconnect. I will try to get an account there. Haven't found it yet how to register.Erwinvos72 wrote:Gordon,gordonb3 wrote:Did you enter your evohome username and password in the settings file? The script does not check whether the return from the client is in fact json or an html error page.
I have an account for totalconnectcomfort, not mytotalconnect, i tried to set up an account but was unable to find the registration. At this point a manage it with this, its an app for controlling evohome. So if i use this site plus credentials it should work i assume
chroot /volume1/@appstore/debian-chroot/var/chroottarget /root/evohome-client/evo-update.sh
chroot /volume1/@appstore/debian-chroot/var/chroottarget /root/evohome-client/evohomeclient/evo-update.sh
Crontab doesn't work on debian-chrootErwinvos72 wrote:
Now i've looked again at the scripts and there is something that tells about regular updating. In wiki they talk about crontab -e and Alle is talking about creating a scheduled task in control panel. I have created the script in synology and every 1 minute it is updating, but i don't think that is working. It is the following line:
chroot /volume1/@appstore/debian-chroot/var/chroottarget/root/evohome-client/evo-update.sh
You need to add the space, not remove it.. I think that the path is incorrectErwinvos72 wrote:It is the space, i removed it . I will try it later on. Thnx for your pm, nice to be dutch too.
Only thing left then is the update temperature from domoticz to evohome. I am not able to send pm, not member long enough
I know, thnx for your update. You mentioned that you also have it running, does your temperature change from domoticz to evohome work?Alle wrote:You need to add the space, not remove it.. I think that the path is incorrectErwinvos72 wrote:It is the space, i removed it . I will try it later on. Thnx for your pm, nice to be dutch too.
Maybe its a good idea to set up a teamviewer session, i tried several options but the script in synology isnt execute as it should be.Alle wrote:Yes it works.
