I have a BAR339DP projection clock and it would be great if RFLink could pull the temperature from its external sensor.
From what I see, this sensor is combined Temperature + atomic time and uses protocol version 2.2 (http://global.oregonscientific.com/uplo ... bility.pdf)
Its not in supported device list, so I wasn't much surprised its not currently recognized via RFLink.
I can see undecoded packets in rflink monitor, so I suspect it may be a matter of fairly easy fix to recognize this sensor data since protocol should be not too different? I don't really care about date/time, but if at least temperature can be processed I would be very happy
Please let me know if you need any help/debug logs.
Thanks and best regards
