Oregon Scientific RTHN318 Sensor Support
RidingTheFlow
Post by RidingTheFlow »
I have a BAR339DP projection clock and it would be great if RFLink could pull the temperature from its external sensor.
From what I see, this sensor is combined Temperature + atomic time and uses protocol version 2.2 (http://global.oregonscientific.com/uplo ... bility.pdf)
Its not in supported device list, so I wasn't much surprised its not currently recognized via RFLink.
I can see undecoded packets in rflink monitor, so I suspect it may be a matter of fairly easy fix to recognize this sensor data since protocol should be not too different? I don't really care about date/time, but if at least temperature can be processed I would be very happy :)
Please let me know if you need any help/debug logs.
Thanks and best regards
deennoo
Re: Oregon Scientific RTHN318 Sensor Support
Post by deennoo »
Please post your debug hère : http://www.esp8266.nu/forum/viewforum.p ... dec8b0ff01
And dont forget to give real temperature
http://domo-attitude.fr
RidingTheFlow
Already received PM and emailed diags.
Just FYI, for now I've made a quick hack to source to make it work, maybe this will help to save some time:
- I had to increase OVERSIZED_LIMIT in Plugin_001 and OSV3_PULSECOUNT_MAX since this sensor sends a lot of data (due to datetime I assume)
- Added check for (id & 0xfff) == 0xADC to V2 temp-only sensor branch (since high nibble appear to change and contain some other flag, maybe again something to do with datetime)
After this I started receiving accurate temperatures. But obviously will still appreciate if proper fix added to mainline :)
