Door sensors and a timer. Topic is solved
golden07
Post by golden07 »
I've added some door sensors (klikaanklikuit AMST-606) to my system as doorlock. This works fine, i see when a door is opend, and when the door is closed. But i want to set a timer for this. on the doorlock option is no option for timer. Is there another option so i can add timers to the sensors?
Slinkos
Domoticz version: 3.4834
Re: Door sensors and a timer.
Post by Slinkos »
If you edit the switch you can set an "on delay". Is that what you want?
golden07
Post by golden07 »
Slinkos wrote:If you edit the switch you can set an "on delay". Is that what you want?
thnx for your reply.
i don't want a delay, what i want is for example:
between 8 and 9 no notification if the door is opend
between 9:01 and 17:00 send notification if the door is opend.
between 17:00 and 18:00 no notification if the door is opend
Slinkos
Post by Slinkos »
You can configure that in your blocky event like this:
golden07
Post by golden07 »
Thnx i wil try that.
