I've added some door sensors (klikaanklikuit AMST-606) to my system as doorlock. This works fine, i see when a door is opend, and when the door is closed. But i want to set a timer for this. on the doorlock option is no option for timer. Is there another option so i can add timers to the sensors?
Door sensors and a timer. Topic is solved
Slinkos
- Domoticz version: 3.4834
Re: Door sensors and a timer.
If you edit the switch you can set an "on delay". Is that what you want?
golden07
thnx for your reply.Slinkos wrote:If you edit the switch you can set an "on delay". Is that what you want?
i don't want a delay, what i want is for example:
between 8 and 9 no notification if the door is opend
between 9:01 and 17:00 send notification if the door is opend.
between 17:00 and 18:00 no notification if the door is opend
Slinkos
You can configure that in your blocky event like this:
- Knipsel.PNG (15.41 KiB) Viewed 1263 times
golden07
Thnx i wil try that.
