domoticz in synology as package! Available now.
dtech
Re: RE: Re: domoticz in synology as package! Available now.
Post by dtech »
jumbotroll wrote: What final release/stable version do you not find?
And what issue do you have?
What NAS do you have?
What DSM version do you have?
I try to update to the latest 4868 from version:
Version: 3.4836
Build Hash: 214e060-modified
Compile Date: 2016-03-03 09:16:19
When upgrade finish I have error message:
2016-03-06 11:53:31.911 Error: Error executing script command (/usr/local/domoticz/var/scripts/update_domoticz /usr/local/domoticz/var/). returned: 32512
I'm on the xpenology latest version.
jumbotroll
Post by jumbotroll »
You have to update domoticz from the package center on Synology NAS or package center. in XPenology
You can NOT update automatic from the domoticz interface, so please disable automatic check.
Do a Manual Install or Add http://www.jadahl.com/domoticz_beta/ to your Synology NAS Package Center sources !
V3.4868 is not yet uploaded. and this is beta!
https://paypal.me/Jumbotroll
Jumbotroll
dtech
Post by dtech »
Thank you very much for info, I will wait till latest package will be ready.
jumbotroll
dtech wrote:Thank you very much for info, I will wait till latest package will be ready.
BTW XPenology use Bromolow packages.
Jumbotroll
cherowley
Post by cherowley »
Version: 3.4868
Build Hash: 61da2d3-modified
Compile Date: 2016-03-06 08:36:49
The On delay / Off delay system in switches is broken.
Value in Off delay makes the switch On Delay as well as off delay.
The On delay is now ignored...
This issue is only in this beta...
UPDATE: The problem only manifests when switching on from the UI, is a switch is set using a lua script then the delays all work fine.
gizmocuz
Post by gizmocuz »
Please do not cross post on here and on github, working on it as you can see on the github issue page, hope to solve it soon
cherowley
Post by cherowley »
Many apologies gizmocuz :)
gizmocuz
Post by gizmocuz »
No worries... lets continue the discussion on github... i already made some tests
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
Hi Jumbotroll,
can you compile 4909 or later for me? (synology 112+)
i do not know how to do this myself(that's why i use your build)
i need to test out a Hue bug(percentage not displayed) which might be fixed in that build.
thanks
jumbotroll
Gravityz wrote:Hi Jumbotroll,
thanks
Here you go : http://www.jadahl.com/domoticz_beta/?arch=88f6281
Jumbotroll
Gravityz
Post by Gravityz »
wow that was quick.
tested it and it seems the bug is gone
thanks
mortyre
Domoticz version: v3.4921
Post by mortyre »
jumbotroll wrote:Domoticz on synology use SSL port:8443
thank you very much :D
mpalyga
Post by mpalyga »
Hi Jumbotroll
looking forward to old DSM version and Synology packages available. ANY plan on roadmap to have Domoticz 3.4834 (stable) available on DSM 4.x ?
/regards m.
/regards m.
jumbotroll
mpalyga wrote:Hi Jumbotroll
/regards m.
There are often problems to cross compile the older DSM versions due to old toolchains . It will probably not be as much updates to DSM 4.x versions, but what NAS and DSM version are you using?
Jumbotroll
mpalyga
Post by mpalyga »
indeed it is. I use Synology 411j with DSM 4.3-3827u7 running on ARM 88f6281 (only reason for use DSM 4.3 is that it is much faster than version 5.x)
I use latest available version of domoticz and installed from package available here your website for ARM 88f6281. it works extremly well....
if you have a little to to build for DSM 4.3 and for ARM 88f6281, i can deeply test on my NAS :)
thx for help. and really fast response ..
/regards m.
jumbotroll
mpalyga wrote:indeed it is. I use Synology 411j with DSM 4.3-3827u7 running on ARM 88f6281 (only reason for use DSM 4.3 is that it is much faster than version 5.x)
Here you go :)
domoticz_88f6281-4.2_3.0.4933-7.spk
domoticz_88f6282-4.2_3.0.4933-7.spk
domoticz_88f6281-4.3_3.0.4933-7.spk
domoticz_88f6282-4.3_3.0.4933-7.spk
http://www.jadahl.com/domoticz_old/inde ... llist=true
Jumbotroll
mpalyga
Post by mpalyga »
Wow and BIG THANK YOU. looking to your support i can see that it was well spent money for android client. Let me test and back to you with results, but im pretty sure that no bugs included. thx a lot one again
/regards m.
mschut
Domoticz version: V3.5613
Post by mschut »
@jumbotroll (cant send you a PM anymore).
I just performed an upgrade to the latest DSM 6.0 beta (NC). Unfortunately I noticethat the HGI80 is not recogniosed anymore. Glad to test any future adaptations ;)
jumbotroll
mschut wrote:@jumbotroll (cant send you a PM anymore).
Has unfortunately not had time to modify all ti_usb_3410_5052.h and ti_usb_3410_5052.c drivers in DSM 6.0 toolchains.
Has made one exception for arch-qoriq.
You may want to test the latest version :)
http://www.jadahl.com/domoticz_beta_6/?arch=qoriq
Jumbotroll
mschut
Post by mschut »
Perfect! Upgrade, restart and up and running again!
Verstuurd vanaf mijn SM-G920F met Tapatalk
Users browsing this forum: suhanidash557 and 1 guest
