[MyDomoAtHome] Support thread
lowca
Re: [MyDomoAtHome] Support thread
Post by lowca »
epierre wrote:@Iowca I was working on water and the new Energy yesterday ;-)
this is round number, I can multiply by 1000 and display Watt
I thought about to see in kWh in format x.xxx
"Iowca I was working on water and the new Energy yesterday ;-)" , do you have some beta version , changlog ,
or all changes are in new version .. (sorry i'm new here ;)
aleceuta
Domoticz version: 3.4834
Post by aleceuta »
Hello:
I try now fresh install of MyDomoAtHome on preconfigured SD with Domoticz 3.4834 for raspberry
I follow the wiki tutorial https://www.domoticz.com/wiki/ImperiHome
I have problem with sh ./run-once.sh never finish
I created any modificate script run-once2.sh that include 2 lines in verbose mode
run-once2.sh
#!/bin/sh
echo "Will update packages list first..."
clear
#sudo apt-get update 2>&1 > /dev/null
echo "Now getting the needed software..."
sudo apt-get -y install whiptail  2>&1 > /dev/null
 if ! whiptail  --backtitle "MyDomoAtHome ISS Interface" --yesno "Have you configured MyDomoAtHome.sh with your parameters before continuing ? Otherwise please say NO" 0 0; then
                whiptail  --backtitle "MyDomoAtHome ISS Interface" --msgbox "Understood! Aborting!" 0 0
                return
        fi
echo "Now getting getting and installing dependencies..."
sudo apt-get -y install libdancer-perl libdancer2-perl libfile-slurp-perl  liblwp-protocol-psgi-perl  2>&1
sudo apt-get -y install libtime-piece-perl libjson-perl libplack-perl starman  libcrypt-ssleay-perl libdatetime-perl libdatetime-format-strptime-perl  2>&1
sudo apt-get -y install libdbd-sqlite3-perl libdbi-perl sqlite3 2>&1
sudo apt-get -y install libaudio-mpd-perl libnet-upnp-perl libpoe-component-client-mpd-perl  2>&1
sudo curl -L https://cpanmin.us | perl - --sudo App::cpanminus
sudo cpanm Task::Plack --verbose --force
sudo cpanm Time::Moment --verbose --force
echo "Now installing the service"
sudo cp MyDomoAtHome.sh /etc/init.d/MyDomoAtHome.sh
sudo chmod +x /etc/init.d/MyDomoAtHome.sh
sudo update-rc.d MyDomoAtHome.sh defaults
whiptail  --backtitle "MyDomoAtHome ISS Interface" --msgbox "Everything has been installed ! Please remember default port is 3001." 0 0
and here the result
pi@raspberrypi:~/domoticz/MyDomoAtHome$ ./run-once2.sh
Reading package lists... Done
Building dependency tree
Reading state information... Done
libdancer-perl is already the newest version.
libdancer2-perl is already the newest version.
libfile-slurp-perl is already the newest version.
liblwp-protocol-psgi-perl is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Note, selecting 'perl' instead of 'libtime-piece-perl'
libcrypt-ssleay-perl is already the newest version.
libdatetime-format-strptime-perl is already the newest version.
libdatetime-perl is already the newest version.
libjson-perl is already the newest version.
libplack-perl is already the newest version.
starman is already the newest version.
libdbd-sqlite3-perl is already the newest version.
libdbi-perl is already the newest version.
sqlite3 is already the newest version.
libaudio-mpd-perl is already the newest version.
libnet-upnp-perl is already the newest version.
libpoe-component-client-mpd-perl is already the newest version.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   314    0   314    0     0    283      0 --:--:--  0:00:01 --:--:--   287
100  296k  100  296k    0     0   159k      0  0:00:01  0:00:01 --:--:--  405k
App::cpanminus is up to date. (1.7040)
cpanm (App::cpanminus) 1.7040 on perl 5.020002 built for arm-linux-gnueabihf-thread-multi-64int
Work directory is /root/.cpanm/work/1457115373.16925
You have make /usr/bin/make
You have LWP 6.08
You have /bin/tar: tar (GNU tar) 1.27.1
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by John Gilmore and Jay Fenlason.
You have /usr/bin/unzip
Searching Task::Plack () on cpanmetadb ...
--> Working on Task::Plack
Fetching http://www.cpan.org/authors/id/M/MI/MIYAGAWA/Task-Plack-0.28.tar.gz ... OK
Unpacking Task-Plack-0.28.tar.gz
Task-Plack-0.28/
Task-Plack-0.28/Build.PL
Task-Plack-0.28/Changes
Task-Plack-0.28/cpanfile
Task-Plack-0.28/dist.ini
Task-Plack-0.28/lib/
Task-Plack-0.28/LICENSE
Task-Plack-0.28/maint/
Task-Plack-0.28/MANIFEST
Task-Plack-0.28/META.json
Task-Plack-0.28/META.yml
Task-Plack-0.28/README
Task-Plack-0.28/t/
Task-Plack-0.28/xt/
Task-Plack-0.28/xt/perlcritic.t
Task-Plack-0.28/xt/pod.t
Task-Plack-0.28/xt/podspell.t
Task-Plack-0.28/xt/synopsis.t
Task-Plack-0.28/t/00_compile.t
Task-Plack-0.28/t/release-pod-syntax.t
Task-Plack-0.28/maint/bump.pl
Task-Plack-0.28/lib/Task/
Task-Plack-0.28/lib/Task/Plack.pm
Entering Task-Plack-0.28
Checking configure dependencies from META.json
Checking if you have Module::Build::Tiny 0.019 ... Yes (0.039)
Running Build.PL
Configuring Task-Plack-0.28 ... Creating new 'Build' script for 'Task-Plack' version '0.28'
OK
Checking dependencies from MYMETA.json ...
Checking if you have IO::Handle::Util 0.01 ... Yes (0.01)
Checking if you have Plack::Middleware::Debug 0.14 ... Yes (0.16)
Checking if you have FCGI::ProcManager 0.24 ... Yes (0.24)
Checking if you have Plack 1.0023 ... Yes (1.0033)
Checking if you have Starlet 0.18 ... No
Checking if you have Plack::Middleware::Auth::Digest 0.04 ... Yes (0.05)
Checking if you have Corona 0.1004 ... Yes (0.1004)
Checking if you have Plack::Middleware::Header 0.04 ... Yes (0.04)
Checking if you have Plack::Middleware::ReverseProxy 0.15 ... Yes (0.15)
Checking if you have PSGI 1.101 ... Yes (1.102)
Checking if you have HTTP::Server::Simple::PSGI 0.14 ... Yes (0.16)
Checking if you have Plack::Middleware::Session 0.18 ... Yes (0.30)
Checking if you have Twiggy 0.1021 ... Yes (0.1025)
Checking if you have Net::FastCGI 0.14 ... Yes (0.14)
Checking if you have Starman 0.3011 ... Yes (0.4010)
Checking if you have FCGI 0.74 ... Yes (0.77)
Checking if you have FCGI::Client 0.08 ... Yes (0.08)
Checking if you have Plack::Middleware::ConsoleLogger 0.04 ... Yes (0.05)
Checking if you have Plack::Middleware::Deflater 0.08 ... Yes (0.12)
Checking if you have Plack::App::Proxy 0.27 ... Yes (0.29)
Checking if you have CGI::PSGI 0.15 ... Yes (0.15)
Checking if you have CGI::Compile 0.16 ... Yes (0.17)
Checking if you have CGI::Emulate::PSGI 0.15 ... Yes (0.20)
==> Found dependencies: Starlet
Searching Starlet (0.18) on cpanmetadb ...
--> Working on Starlet
Fetching http://www.cpan.org/authors/id/K/KA/KAZUHO/Starlet-0.29.tar.gz ... OK
Unpacking Starlet-0.29.tar.gz
Starlet-0.29/
Starlet-0.29/.gitignore
Starlet-0.29/Changes
Starlet-0.29/inc/
Starlet-0.29/inc/Module/
Starlet-0.29/inc/Module/Install/
Starlet-0.29/inc/Module/Install/Base.pm
Starlet-0.29/inc/Module/Install/Can.pm
Starlet-0.29/inc/Module/Install/Fetch.pm
Starlet-0.29/inc/Module/Install/Makefile.pm
Starlet-0.29/inc/Module/Install/Metadata.pm
Starlet-0.29/inc/Module/Install/ReadmeFromPod.pm
Starlet-0.29/inc/Module/Install/Win32.pm
Starlet-0.29/inc/Module/Install/WriteAll.pm
Starlet-0.29/inc/Module/Install.pm
Starlet-0.29/lib/
Starlet-0.29/lib/Plack/
Starlet-0.29/lib/Plack/Handler/
Starlet-0.29/lib/Plack/Handler/Starlet.pm
Starlet-0.29/lib/Starlet/
Starlet-0.29/lib/Starlet/Server.pm
Starlet-0.29/lib/Starlet.pm
Starlet-0.29/Makefile.PL
Starlet-0.29/MANIFEST
Starlet-0.29/META.yml
Starlet-0.29/MYMETA.json
Starlet-0.29/MYMETA.yml
Starlet-0.29/README
Starlet-0.29/t/
Starlet-0.29/t/00base-hello.psgi
Starlet-0.29/t/00base.t
Starlet-0.29/t/01plack-test.t
Starlet-0.29/t/02graceful.t
Starlet-0.29/t/03post.t
Starlet-0.29/t/04-bumpy-life.t
Starlet-0.29/t/05server-header.t
Starlet-0.29/t/06harakiri.t
Starlet-0.29/t/07remote_port.t
Starlet-0.29/t/08chunked_req.t
Starlet-0.29/t/09chunked_zero_length.t
Starlet-0.29/t/10unix_domain_socket.t
Starlet-0.29/t/11multi-sockets.t
Starlet-0.29/t/12bad_request_line.t
Starlet-0.29/t/13spawn_interval.t
Starlet-0.29/t/assets/
Starlet-0.29/t/assets/baybridge.jpg
Entering Starlet-0.29
Checking configure dependencies from META.yml
Checking if you have ExtUtils::MakeMaker 6.59 ... Yes (6.98)
Running Makefile.PL
Configuring Starlet-0.29 ... Checking if your kit is complete...
Looks good
Generating a Unix-style Makefile
Writing Makefile for Starlet
Writing MYMETA.yml and MYMETA.json
OK
Checking if you have Plack 0.992 ... Yes (1.0033)
Checking if you have Parallel::Prefork 0.17 ... Yes (0.18)
Checking if you have ExtUtils::MakeMaker 0 ... Yes (6.98)
Checking if you have Test::More 0.88 ... Yes (1.001002)
Checking if you have Server::Starter 0.06 ... Yes (0.17)
Checking if you have LWP::UserAgent 5.8 ... Yes (6.06)
Checking if you have Test::TCP 2.1 ... Yes (2.14)
Building and testing Starlet-0.29 ... cp lib/Plack/Handler/Starlet.pm blib/lib/Plack/Handler/Starlet.pm
cp lib/Starlet/Server.pm blib/lib/Starlet/Server.pm
cp lib/Starlet.pm blib/lib/Starlet.pm
Manifying blib/man3/Starlet.3pm
PERL_DL_NONLAZY=1 /usr/bin/perl "-MExtUtils::Command::MM" "-MTest::Harness" "-e" "undef *Test::Harness::Switches; test_harness(0, 'inc', 'blib/lib', 'blib/arch')" t/*.t
t/00base.t ................. 2/?
#   Failed test 'request successfull'
#   at t/00base.t line 49.
t/00base.t ................. 3/?
#   Failed test 'content is hello'
#   at t/00base.t line 50.
#          got: 'Can't connect to 127.0.0.1:50364
# Connection refused at /usr/share/perl5/LWP/Protocol/http.pm line 49.
#     expected: 'hello'
# Looks like you failed 2 tests of 3.
t/00base.t ................. Dubious, test returned 2 (wstat 512, 0x200)
Failed 2/3 subtests
t/01plack-test.t ........... ok
t/02graceful.t ............. 18036 at t/02graceful.t line 11.
18036 at t/02graceful.t line 30.
18110 at t/02graceful.t line 16.
t/02graceful.t ............. ok
t/03post.t ................. 18154 at t/03post.t line 9.
Plack::Handler::Starlet: Accepting connections at http://0:50646/
127.0.0.1 - - [04/Mar/2016:18:19:07 +0000] "POST / HTTP/1.1" 200 3 "-" "libwww-perl/6.08"
t/03post.t ................. ok
t/04-bumpy-life.t .......... ok
t/05server-header.t ........ ok
t/06harakiri.t ............. ok
t/07remote_port.t .......... ok
t/08chunked_req.t .......... ok
t/09chunked_zero_length.t .. ok
t/10unix_domain_socket.t ... failed to listen to socket /tmp/B7bs9bOXhw:No such file or directory at t/10unix_domain_socket.t line 35.
    # Child (direct) exited without calling finalize()
t/10unix_domain_socket.t ... 1/?
#   Failed test 'direct'
#   at /usr/share/perl/5.20/Test/Builder.pm line 276.
# Tests were run but no plan was declared and done_testing() was not seen.
# Looks like your test exited with 2 just after 1.
on this line # Looks like your test exited with 2 just after 1. newer finish
I try step by step of the script.
But when I try start
sudo service MyDomoAtHome.sh start
when test it
http://192.168.3.125:3001/devices
not working
Nevertheless when start
start2.sh
works
epierre
Post by epierre »
@lowca is it there:
viewtopic.php?f=21&t=8951
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
epierre
Post by epierre »
aleceuta wrote: I try now fresh install of MyDomoAtHome on preconfigured SD with Domoticz 3.4834 for raspberry
not mine, but it seems package maintainer has some issues... and so people there... this is why I'm rewriting it in nodeJS
aleceuta wrote: I try step by step of the script.
when test it
not working
start2.sh
works
try:
service mydomoathome start
and then:
service mydomoathome status
to see the system status
epierre
Post by epierre »
need some testers here:
mostly on blinds and docker, please send me your email either pm or [email protected]
epierre
Post by epierre »
lowca wrote:Hello..
I'm trying to run Counter Incremental .,
It looks like it worked:.
if (($f->{"Type"} eq "General") and ($f->{"SubType"} eq "Counter Incremental"))  {
In debug("CounterToday:$v\n"); have [hit #91]CounterToday:1.463 ImpireHome show 1. Not showing numbers after decimal.
My question is how can i do that , or is it on Imperihome side ..[/quote]
@lowca I did it in the new version in nodeJS, this is not that simple, 4 types, 4 fixed units and one dynamic...
I need more testers but now only graphs are now missing, all new and updated devices are here
lowca
Post by lowca »
epierre wrote: @lowca I did it in the new version in nodeJS, this is not that simple, 4 types, 4 fixed units and one dynamic...
Ok. later i will install node js version and make some test .. 8-)
update:
Node version: 4.3.2
MDAH version: 0.0.19
in Imerihome Counter Incremental show N/A
console.log(res[1]); show good value , total and usage.. need some more time to get deeper in nodejs version .. ;)
update:
On my other pi system same node and mdah version , showing good values .. hmm,.
aleceuta
Post by aleceuta »
When I test
sudo service MyDomoAtHome.sh status
say is failed not working.
aleceuta
Post by aleceuta »
Is not possible generate any log´s to see the problem.
lowca
Post by lowca »
Problem is in { key: 'Watts', value: '6.791 kWh', unit: undefined },
For test i remove kWh from usage varible ,and static unit "kWh" it shows in watts.
usage = usage.substr(0, usage.length-3);
        console.log(usage);
Method is not the best, but its working now .,
lowca
Post by lowca »
aleceuta wrote:Is not possible generate any log´s to see the problem.
Try to start manualy ,, In Your MyDomoAtHome directory try to run start2.sh
pi@raspberrypi:~/domoticz/MyDomoAtHome $ sh ./start2.sh
aleceuta
Post by aleceuta »
Yes lowca at moment start with ./start2.sh
But not is good solution. I want start as service.
lowca
Post by lowca »
Try: sudo /etc/init.d/MyDomoAtHome.sh start
and send as output ..
hendrik6073
Post by hendrik6073 »
used search cannot find anything on this issue
i added 8 test dummy tekst devices. i use them to post the heater thermostat schedule information . I want to display the devices using ImperiHome.
In ImperiHome the dummy text devices are not visible (http://imperihome:5001/devices) ? should i do some extra ?
thanks
rafal
Domoticz version: latest
Post by rafal »
Hello everybody,
I have Domoticz v3.4834 by Jadahl on NAS Synology and i installed docker on nas with MyDomoAtHome to connect imperihome on samsung android.
my domoticz on nas is on 192.168.0.11:8084, so i try connect but i have different range ip:
MyDomoAtHome Dev
MDAH: http://172.17.0.11:3002
MDAH ver: 0.0.23
Domoticz: http://127.0.0.1:8080
NodeJS: v4.3.0
Webmanager: EJS
Renderer: Express
how i can change domoticz http for 192.168.0.11:8084???
i conected from my phone to the gatway but i'cant see any sensors :(
Is it possible to connect MyDomotAtHome in any different way expect raspberry pi?? for example:
Domoticz on windows --any "system" with gate ---imperihome or
Domoticz on NAS --- any "system" with gate(like docker) ---imperihome
https://drive.google.com/file/d/0B5vmlS ... sp=sharing
Thank You for any anwer and help
epierre
Post by epierre »
aleceuta wrote:When I test
sudo service MyDomoAtHome status
epierre
Post by epierre »
hendrik6073 wrote:used search cannot find anything on this issue
can you send me the output of your http://192.168.0.xx:8080/json.htm?type= ... order=Name
epierre
Post by epierre »
rafal wrote:Hello everybody,
MyDomoAtHome Dev
MDAH ver: 0.0.23
NodeJS: v4.3.0
Webmanager: EJS
Renderer: Express
Normally this should start as :
docker run --name=mdah --env DOMO="http://your_ip:8080" -it --rm -p 3002:3002 epierre/mdah
the environment variable would change the IP/PORT in the DOMO variable, and if you want to use something different as port 3002 you could change -p 3002:your_port
If you can't change environment, can you "mount" the image and modify in it /etc/mydomoathome/config.json ?
rafal
Post by rafal »
"Remember to change the IP below and authorize in Domoticz the docker IP range
docker run --name=mdah --env DOMO="http://your_ip:8080" -it --rm -p 3002:3002 epierre/mdah"
i did same way with instrukction on github and you container is added but when i try switching on and i had error:
meybe i doing something wrong...??
i do not think i using port 3002 for something else.
how to i can modifay it /etc/mydomoathome/config.json ? in docker is terminal bash? i newbie on linux bash etc anyway when i config manually
and config ip and domoticz port i have error:
i know is terminal in docker but i dont't know how to use it :
Thank You for help
Rafal
rafal
Post by rafal »
second question how i can use these commands in docker on synology????:
Check running docker processes
docker ps
Stoping a docker process
docker stop mdah
