mstrandbo
Re: Domoticz app 2.0
@galadril: I received your PM, but I am unfortunately unable to reply. I have set up viewer-access for you, though... Oh well
Boezelman
I can acces the Domoticz webUI from outside my network just fine (ip:8080)
(so assume my port forwarding is OK)
Now I just bought the app (looks great!), and it runs great on my locale network but when I try to acces it from outside my network ($g connection) the app just show the "loading" circle when I try to acces the Switches tab for example.
(I add the same IP + port that I put in my browser)
Any idea what I do wrong?
thanks~!
thanks~!
- RoadXY
- Domoticz version: 2.2331
We're going to check.mstrandbo wrote:In the Dashboard I have my favorites, where I have a group called "Utebelysning". When I press its buttons, I get the notification underneath saying "Turning switch on: Outside weather".
Well, outside weather is not a switch - it's a thermometer....Utebelysning should turn on my outdoor lights, but it doesnt.
However, if I go into Scenes and turn on Utebelysning from there, it works.
If we're unable to reproduce, could we get access to your server?
- RoadXY
It should always time out and show an error message.Boezelman wrote:I can acces the Domoticz webUI from outside my network just fine (ip:8080)
thanks~!
Could you post the message please?
- RoadXY
No, something changed in an update on the server so this has to be revised.Jango wrote:Hello, server update does not work in beta Android cliënt.
- RoadXY
https://www.google.com/search?q=android+screenshotceedebee wrote:I'm sorry I realy don't know how to make a screenshot on Android. But on the phone there is at the right of the text a switch, just like a switch for lamps etc. On the tablet there is a rectangular switch (like the one used for my scenes)RoadXY wrote:Could you post some screenshots please?ceedebee wrote:Updated the app today and it doesn't crash anymore on start-up.
Now I can see the security panel but it onlo shows the status and an on button. No possibility to change the status of the alarm, is this by design?
Hope this helps.
mstrandbo
Thanks, galadril have already requested it. But I am not able to send PM yet, so I haven't been able to give you login details.RoadXY wrote:We're going to check.mstrandbo wrote:In the Dashboard I have my favorites, where I have a group called "Utebelysning". When I press its buttons, I get the notification underneath saying "Turning switch on: Outside weather".
Dennis1986
Great app, but I have the following problems:
- The sequence of the buttons is not the same as on the server.
- The Kaku ASUN 650 is not shown as a blind but as an ON or OFF button, on the server this is different, it's shown as a blind and if you tap the close button twice it stops on that position.
Can you solve this?
Can you solve this?
- galadril
- Domoticz version: latest
Changelog new release:
Added support for NFC
Support for Push on/off connected to Geofences and NFC
Added Italian Translations
Added Finnish Translation
Various Crash fixes
Update are comming fast, keep up the good work!
What is still do not understand is why do switches have only a on or off function.
Scenes do have both, i like to have that also for my switches. When the switch doesnt respond i have to switch double.
I am using kaku.
send from tapatalk app.
I am using kaku.
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
edraket
Hi, thank to you guys for this briljant piece of work!
I installed the latest update from the play store, especially because of the streaming camera option. But I 've noticed that de picture is not updating between each stream. Same when I don't choose the stream. When I save a pic than its timestamp is sometimes 2 hours behind.
Is there a way/bypass to overcome this?
Cheers, EdRaket
Cheers, EdRaket
sweup
Hi, after last update i got instant FC when opening the app. Tried reboot without success. Unfortunately I haven't root and I haven't find any app to take logs without root. Im using Xperia Z5 5.1.1
- RoadXY
I saw the crash reports last night.sweup wrote:Hi, after last update i got instant FC when opening the app. Tried reboot without success. Unfortunately I haven't root and I haven't find any app to take logs without root. Im using Xperia Z5 5.1.1
We already fixed this in and is currently in beta testing.
Could you reset the app data, please?
Attention!
This will reset the Domoticz for Android app! You'll have to set the server and other settings again!
How to reset you app data:
- Go to your device’s Settings page.
- Go to Apps.
- Touch the maps Maps icon.
- Touch Clear data on the "App info" page.
- Touch OK in the dialogue box that appears.
- Open your device's Settings application
- Select Applications > Manage applications.
- Touch the All tab.
- Touch Maps in the scrolling list.
- Touch Clear data.
- RoadXY
Yes, streaming camera doesn't always work.edraket wrote:Hi, thank to you guys for this briljant piece of work!
Cheers, EdRaket
It's a work in progress.
jannl
- Domoticz version: 2025.5.x
The app keeps improving
However, besides the (my) blinds not working I see some issues with the graphs, especcially the day and week graph (did nog really check the mont/year graphs) in the app.
The daily graph seems to run out of the screen, not sure (do not think so) if the end of the graph is visible
The week graph gives the message: No data found, the week graph in the Domoticz web interface show daya however.
Jan
Jan
- RoadXY
Because space is limited on your mobile (especially the 3,8" devices which we also support).marktn wrote:Update are comming fast, keep up the good work!
I am using kaku.
- RoadXY
We're currently working on the blinds issues and graphs enhancements.jannl wrote:The app keeps improving
However, besides the (my) blinds not working I see some issues with the graphs, especially the day and week graph (did nog really check the mont/year graphs) in the app.
The week graph gives the message: No data found, the week graph in the Domoticz web interface show data however.
Jan
Graphs are inside of a dialog (hence, not full screen size). We're changing this to an activity where we have more control on the screen.
jannl
super,
I'll be glad to help testing this.
Re: RE: Re: Domoticz app 2.0
Maybe a idea to make in the settings this choice? Now i need sometimes the dromotica app to set the lights off.RoadXY wrote:Because space is limited on your mobile (especially the 3,8" devices which we also support).marktn wrote:Update are comming fast, keep up the good work!
I am using kaku.
NiklasO
- Target OS: -
This does not help. My app still crash. Why do you instruct on how to clear data for Google Maps?RoadXY wrote:I saw the crash reports last night.sweup wrote:Hi, after last update i got instant FC when opening the app. Tried reboot without success. Unfortunately I haven't root and I haven't find any app to take logs without root. Im using Xperia Z5 5.1.1
Attention!
How to reset you app data:If you have an older Android device, follow these steps:
- Go to Apps.
- Touch Clear data.
I cleared data for both Maps(?) and Domoticz app. It crashes as soon I have added the server settings again.
I use the paid version...
