This is on another thread: viewtopic.php?f=21&t=8951&p=76176#p76176
[MyDomoAtHome] Support thread
- epierre
Re: [MyDomoAtHome] Support thread
@doler the nodejs is restarted with children's holidays free time for me
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
Evelen
- Domoticz version: 2.4538
Just installed MyDomoAtHome, but can't start it?
help
help
- epierre
@Eleven what gives:
sudo /etc/init.d/MyDomoAtHome.sh status
also do you see a running starman process ?
also try (as mentioned above):
Try to find and kill ALL mdah fork processes, by using following cmd ex.
sudo kill -9 `ps -ef |grep tarman |awk '{print $2}'`
then remove pid file:
sudo rm /var/run/MyDomoAtHome.pid
Evelen
epierre wrote:@Eleven what gives:
*reboot*
(I'm not that great with linux)
- epierre
@Doler I've tested on my PI B running Wheezy the script is fine on start/stop from my last commit on github, waiting from your infos on that.
- epierre
@Evelen there is a quote and a backquote that is why you had terminating issues:
what gives you:
ps -ef |grep tarman
if no starman is running, try starting start2.sh to see if installation is successful or not
what gives you:
ps -ef |grep tarman
Evelen
epierre wrote:@Evelen there is a quote and a backquote that is why you had terminating issues:
what gives you:
ps -ef |grep tarman
This is what I got
- epierre
@Evelen, do you have a MyDomoAtHome in the domoticz directory ? start2.sh is in this directory
Evelen
yes it is.epierre wrote:@Evelen, do you have a MyDomoAtHome in the domoticz directory ? start2.sh is in this directory
used the wiki install guide.
PS: I run this on a virtual VMware ESXi server, and I have a backup for before i installed MyDomoAtHome
let me know whether you think I should try from the start again. (and how)
- epierre
@Evelen well... how to say... this is weird.
normally a "git pull" should bring back some files but maybe the issue is elsewhere
try this, then try run-once.sh and then start2.sh again to see if this fixes this error which is fatal (you're the first to have it congratulations
Evelen
heh
did not work
This is btw my config changes:
MyDomoAtHome.sh:
APP_DIR="/home/flemmingss/domoticz/"
config.yml:
domo_path: "http://localhost:8080"
did not work
MyDomoAtHome.sh:
config.yml:
- epierre
@Evelen much better yet for missing files have been added.
edit start2.sh to match your /home/flemmingss/ and start it again
Doler
Sorry, I've been occupied by some urgent family business. Gave it a short try on both my working version after git pull and a version after an update. I couldn't get it to work on both. If time permits I'll try a clean, new install tomorrow (still on Wheezie).epierre wrote:@Doler I've tested on my PI B running Wheezy the script is fine on start/stop from my last commit on github, waiting from your infos on that.
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Evelen
got this nowepierre wrote:@Evelen much better yet for missing files have been added.
- epierre
@Evelen ok we advance, can you run ./update-mdah.sh there a missing lib
Doler
Ok, did a clean install (on Wheezy) following the wiki and everything is fine. Next is install on Jessie once I got that up and running, will be continued...Doler wrote:Sorry, I've been occupied by some urgent family business. Gave it a short try on both my working version after git pull and a version after an update. I couldn't get it to work on both. If time permits I'll try a clean, new install tomorrow (still on Wheezy).epierre wrote:@Doler I've tested on my PI B running Wheezy the script is fine on start/stop from my last commit on github, waiting from your infos on that.
Thanks for the help so far, Mark
Evelen
Hi.epierre wrote:@Evelen ok we advance, can you run ./update-mdah.sh there a missing lib
Results:
Doler
Installing on Jessie gives a problem. Output of run-once.sh (second time install so most is up-to-date):
Thanks, Mark
- Spoiler: show
Thanks, Mark
- epierre
looks we had this issue on another VM try... no clue why...
Doler
Hmm...epierre wrote:looks we had this issue on another VM try... no clue why...
If I do "dpkg -l | grep cpan" I get " libcpan-meta-perl (Perl module to access CPAN distributions meta data)" as a result. So there is something available? Could it be that the path is not correct? "echo $PATH" gives "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games", maybe there is something missing?
Thanks, Mark
