Trying to use Android app "IP Webcam"
LTBsweden
Post by LTBsweden »
As I understad this app should work with Domoticz, but no matter how i configure it Im unable to get working,
the feed window in Edit camera only shows picture for <1 second when pressing "test connection".
Using Raspberry Pi 2 with RFLink/USB
Any ideas?
//Tomas B
LTBsweden
Re: Trying to use Android app "IP Webcam"
Post by LTBsweden »
When adding a new camera with the same settings that new one worked? then I just deleted the first one.
//Tomas
JanKarel
Post by JanKarel »
Hello Thomas, can't comment on the use of this Android app but I Have experienced comparable kinds of problems with Domoticz connecting an iPhone 3 and 4 as IP camera to Domoticz using the IPCam app of SKJM.
For reasons, I don't know yet I also get pictures for a very brief instance. Also it seems as if only one of the iPhones can be connected at the same time.
I'm using a Raspberry 2 with a Aeotec Z-stick Gen5
JanKarel
sundberg84
Post by sundberg84 »
Hi!
Im using this android app as ip-cam every day - very solid and has been working without issues since i posted this:
http://www.domoticz.com/forum/viewtopic.php?f=35&t=8199
Here you can see some settings and so.
One issue I experienced was if I had post set the same as Domoticz.
Br
Controller: Domoticz (Raspberry PI)
Gateways: MySensors (Ethernet W5100), RFLink
kalien
Post by kalien »
I tried to use the webcam with this application, but the image is canceled after two seconds and it closes. I do not know if there is an update to correct this error or what can I do ...
I appreciate your help
DewGew
Domoticz version: V4.10618
Post by DewGew »
I have no problems with this app. Make sure the settings in ip webcam app is optimal for your phone
Alyson01
Post by Alyson01 »
DewGew wrote: Monday 14 January 2019 15:11 I have no problems with this app. Make sure the settings in ip webcam app is optimal for your phone
I think I am also facing this issue.
Did you get any proper solution?
DewGew
Post by DewGew »
Alyson01 wrote: Wednesday 27 March 2019 6:13
Check settings for screen resolution. I had to reduce that once.
Melody684
Post by Melody684 »
zicht
Domoticz version: 2023.1+
Post by zicht »
this app works like a charm,
BUT You need to turn on development mode, make sure the screen stays always on. Most devices cancel the camera feed to this app when the screen dims or turns of (battery saving or so)
The only nasty thing is : once or twice a day the app "steals" focus -> so it is less suitable on a tablet running domoticz to switch things.
