[MyDomoAtHome] Support thread
lrybak
Re: [MyDomoAtHome] Support thread
Post by lrybak »
Hi Guys,
I did mdah update on my test pi. Indeed had the same behaviour as you mentioned.
Try to find and kill ALL mdah fork processes, by using following cmd ex.
sudo kill -9 `ps -ef |grep tarman |awk '{print $2}'`
then remove pid file:
sudo rm /var/run/MyDomoAtHome.pid
And check once again.
Hope it helps
HW: HP dc7900 USD running ESXi, RaspberryPi (few of it), AEON S2 USB stick, Fibaro modules (Dimmers, switches), 1-wire (DS18B20, DS2423), DSC Alarm with Envisalink ethernet module, MySensors, RFLink
lrybak
Post by lrybak »
Doler wrote:Another question: is MDAH compatible with Debian-Jessie?
It works for me on Debian 7.8 and 8.0
Gabe
Post by Gabe »
Hi Irybak,
thanks for helping. I can start now the service and it say ok, but when I stop it it says "kill 3615: No such process, start-stop-deamon:warning: failed to kill 3615:No such porocess"
Also connecting through brower after start not function
rgds
lrybak
Post by lrybak »
1) please post process list:
sudo ps -ef |grep [s]tarman
2) check if you have current version of init.d script, please post output of command
wget https://raw.githubusercontent.com/empierre/MyDomoAtHome/master/MyDomoAtHome.sh -O /tmp/MDH.sh > /dev/null 2>&1 && diff /etc/init.d/MyDomoAtHome.sh /tmp/MDH.sh && rm /tmp/MDH.sh
Gabe
Post by Gabe »
Hi Irybak,
I get no results if I put sudo ps -ef |grep tarman in my terminal.
Other I check situation still the same
lrybak
Post by lrybak »
check if your init.d script is up to date - please post output of 2nd cmd
Doler
Post by Doler »
Hello Irybak,
Same result as Gabe: no starman process. From your second check I discovered a difference between MyDomoAtHome.sh in init.d and the MDAH directory. The first (original/older) user /var/tmp for the pid-file while the new one uses /var/run (at least that was the most obvious difference).
I replaced the MyDomoAtHome.sh in init.d with the new one (chmod +x, update-rc.d) but not with positive result. I see the pid-file in /var/run, it even holds a process number but that process doesn't exist. So I'm stuck here. But thanks for your efforts in helping us.
Mark
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Gabe
Post by Gabe »
just update init.d too, but no futher sucess
lrybak
Post by lrybak »
Strange.
I already updated my PROD MDAH instance running Debian Jessie 8.0 without issues, please see my full output below
pi@pi2 ~/domoticz $ cp -pr MyDomoAtHome MyDomoAtHome.2016-02-19
pi@pi2 ~/domoticz $ cp -pr /etc/init.d/MyDomoAtHome.sh MyDomoAtHome.sh.2016-02-19
pi@pi2 ~/domoticz/MyDomoAtHome $ ./update-mdah.sh
Stoping MyDomoAtHome service...
Retrieving latest code...
error: cannot open .git/FETCH_HEAD: Permission denied
Setting directories rights...
Checking latest libraries dependencies...
Reading package lists... Done
Building dependency tree
Reading state information... Done
cpanminus is already the newest version.
libaudio-mpd-perl is already the newest version.
libnet-upnp-perl is already the newest version.
libpoe-component-client-mpd-perl is already the newest version.
whiptail is already the newest version.
The following packages were automatically installed and are no longer required:
  python-django-common python-sqlparse
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 128 not upgraded.
Note, selecting 'perl' instead of 'libtime-piece-perl'
libcrypt-ssleay-perl is already the newest version.
libdatetime-perl is already the newest version.
libjson-perl is already the newest version.
libplack-perl is already the newest version.
libswitch-perl is already the newest version.
starman is already the newest version.
The following extra packages will be installed:
  perl-base perl-modules
Suggested packages:
  perl-doc libterm-readline-gnu-perl libterm-readline-perl-perl libb-lint-perl libcpanplus-dist-build-perl libcpanplus-perl libfile-checktree-perl libobject-accessor-perl
The following packages will be upgraded:
  perl perl-base perl-modules
3 upgraded, 0 newly installed, 0 to remove and 125 not upgraded.
Need to get 5,697 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://piotrkosoft.net/pub/mirrors/raspbian/raspbian/ jessie/main perl armhf 5.20.2-3+deb8u3 [2,055 kB]
Get:2 http://piotrkosoft.net/pub/mirrors/raspbian/raspbian/ jessie/main perl-base armhf 5.20.2-3+deb8u3 [1,097 kB]
Get:3 http://piotrkosoft.net/pub/mirrors/raspbian/raspbian/ jessie/main perl-modules all 5.20.2-3+deb8u3 [2,545 kB]
Fetched 5,697 kB in 6s (849 kB/s)
(Reading database ... 74780 files and directories currently installed.)
Preparing to unpack .../perl_5.20.2-3+deb8u3_armhf.deb ...
Unpacking perl (5.20.2-3+deb8u3) over (5.20.2-3+deb8u1) ...
Preparing to unpack .../perl-base_5.20.2-3+deb8u3_armhf.deb ...
Unpacking perl-base (5.20.2-3+deb8u3) over (5.20.2-3+deb8u1) ...
Processing triggers for man-db (2.7.0.2-5) ...
Setting up perl-base (5.20.2-3+deb8u3) ...
Preparing to unpack .../perl-modules_5.20.2-3+deb8u3_all.deb ...
Unpacking perl-modules (5.20.2-3+deb8u3) over (5.20.2-3+deb8u1) ...
Setting up perl-modules (5.20.2-3+deb8u3) ...
Setting up perl (5.20.2-3+deb8u3) ...
./update-mdah.sh: 30: ./update-mdah.sh: ./speedUP.sh: not found
--> Working on Time::Moment
Fetching http://www.cpan.org/authors/id/C/CH/CHANSEN/Time-Moment-0.38.tar.gz ... OK
Configuring Time-Moment-0.38 ... OK
==> Found dependencies: Test::Requires
--> Working on Test::Requires
Fetching http://www.cpan.org/authors/id/T/TO/TOKUHIROM/Test-Requires-0.10.tar.gz ... OK
Configuring Test-Requires-0.10 ... OK
Building and testing Test-Requires-0.10 ... OK
Successfully installed Test-Requires-0.10
Building and testing Time-Moment-0.38 ...
Successfully installed Time-Moment-0.38 (upgraded from 0.36)
2 distributions installed
Restarting MyDomoAtHome service...
Update path finished
pi@pi2 ~/domoticz/MyDomoAtHome $ ps -ef |grep [s]tarman
www-data 17004     1  5 21:36 ?        00:00:09 starman master
www-data 17075 17004  0 21:36 ?        00:00:01 starman worker
www-data 17076 17004  1 21:36 ?        00:00:01 starman worker
www-data 17077 17004  0 21:36 ?        00:00:01 starman worker
www-data 17078 17004  1 21:36 ?        00:00:01 starman worker
pi@pi2 ~/domoticz/MyDomoAtHome $ sudo kill -9 17004
pi@pi2 ~/domoticz/MyDomoAtHome $ sudo /etc/init.d/MyDomoAtHome.sh stop
[ ok ] Stopping MyDomoAtHome.sh (via systemctl): MyDomoAtHome.service.
[after couple of seconds]
www-data 19179     1 92 21:42 ?        00:00:08 starman master
www-data 19207 19179  1 21:42 ?        00:00:00 starman worker
www-data 19208 19179  0 21:42 ?        00:00:00 starman worker
www-data 19209 19179  1 21:42 ?        00:00:00 starman worker
www-data 19210 19179  0 21:42 ?        00:00:00 starman worker
pi@pi2 ~/domoticz/MyDomoAtHome $ sudo wget https://raw.githubusercontent.com/empierre/MyDomoAtHome/master/MyDomoAtHome.sh -O /etc/init.d/MyDomoAtHome.sh
--2016-02-19 21:50:04--  https://raw.githubusercontent.com/empierre/MyDomoAtHome/master/MyDomoAtHome.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.31.17.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.31.17.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2286 (2.2K) [text/plain]
Saving to: ‘/etc/init.d/MyDomoAtHome.sh’
/etc/init.d/MyDomoAtHome.sh             100%[==============================================================================>]   2.23K  --.-KB/s   in 0s
2016-02-19 21:50:04 (5.49 MB/s) - ‘/etc/init.d/MyDomoAtHome.sh’ saved [2286/2286]
pi@pi2 ~/domoticz/MyDomoAtHome $ cd /etc/init.d/
pi@pi2 /etc/init.d $ sudo chmod +x ./MyDomoAtHome.sh && sudo update-rc.d MyDomoAtHome.sh defaults
insserv: Starting monit depends on MyDomoAtHome.sh and therefore on system facility `$all' which can not be true!
pi@pi2 /etc/init.d $ cat /etc/init.d/MyDomoAtHome.sh |grep Required-
# Required-Start:    $all
# Required-Stop:     $all
[changed only Required-Start and Required-Stop to fit my needs (monit daemon requirements)]
pi@pi2 /etc/init.d $ sudo vi /etc/init.d/MyDomoAtHome.sh
# Required-Start:    $local_fs $network $named $time $syslog
# Required-Stop:     $local_fs $network $named $time $syslog
pi@pi2 /etc/init.d $ ps -ef |grep [s]tarman
www-data 19179     1  1 21:42 ?        00:00:08 starman master
www-data 19207 19179  0 21:42 ?        00:00:06 starman worker
www-data 19208 19179  0 21:42 ?        00:00:05 starman worker
www-data 19209 19179  0 21:42 ?        00:00:05 starman worker
www-data 19210 19179  0 21:42 ?        00:00:05 starman worker
pi@pi2 /etc/init.d $ sudo /etc/init.d/MyDomoAtHome.sh stop
pi@pi2 /etc/init.d $ sudo /etc/init.d/MyDomoAtHome.sh start
[ ok ] Starting MyDomoAtHome.sh (via systemctl): MyDomoAtHome.service.
www-data 23574     1 95 21:57 ?        00:00:08 starman master
www-data 23652 23574  0 21:57 ?        00:00:00 starman worker
www-data 23653 23574  1 21:57 ?        00:00:00 starman worker
www-data 23654 23574  0 21:57 ?        00:00:00 starman worker
www-data 23655 23574  0 21:57 ?        00:00:00 starman worker
pi@pi2 /etc/init.d $ cat /etc/debian_version
8.0
Gabe
Post by Gabe »
this is my outpute
[....] Stopping plack server: MyDomoAtHomestart-stop-daemon: warning: failed to kill 4179: No such process
failed!
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
E: Unable to locate package libdancer2-perl
[ ok ] Starting plack server: MyDomoAtHome.
[ ok ] MyDomoAtHome process is running.
Doler
Post by Doler »
lrybak wrote:Strange.
Sorry that I possibly put you on the wrong path. I'm still at Wheezy but was trying to migrate to Jessie this afternoon. Just got inot some trouble with Fibaro motion sensors so I had to revert back (only got one RPI). So the problems I have are on Wheezy, didn't try it yet on Jessie so therefore my question on compatibility. But the given info is very welcome and I'll give it a try on Jessie. Just have to wait till next week (upcoming birthday :P ) when I have more time. Again thanks.
Mark
Gabe
Post by Gabe »
maybe this is the solution I have also Wheezy from standard Domoticz installation. Hi I must migrate from wheezy to Jessie without loosing all setting of Domoticz
lrybak
Post by lrybak »
My test pi runs on Debian Wheezy (7.8) - I don't think this is an issue.
Maybe epierre will help you
epierre
Post by epierre »
@doler what was the previous version number/date ? last modification is 4 months old
for all, to manually kill the process, you have to find the Starman master pid
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
epierre
Post by epierre »
Gabe wrote:maybe this is the solution I have also Wheezy from standard Domoticz installation. Hi I must migrate from wheezy to Jessie without loosing all setting of Domoticz
by design all domoticz settings except scripts are in domoticz.db so backup it often !
@gabe who is the owner of either:
ls -la /var/run/MyDomoAtHome.pid
ls -la /var/tmp/MyDomoAtHome.pid
starting the script as pi or root may add a file with wrong rights, so you have to remove it and let the system start/stop it.
what gives you '/etc/init.d/MyDomoAtHome.sh status' ?
Doler
Post by Doler »
epierre wrote:@doler what was the previous version number/date ? last modification is 4 months old
The package.json (09-09-2015) in the MDAH directory tells me it's version 0.12. I see more recent files though, like run-once.sh that is dated 05-02-2016.
The problem that I meet is that, after upgrading, there is no Starman master pid: the service just doesn't start.
Thanks, Mark
epierre
Post by epierre »
@doler try start2.sh as pi user to see if all libs dependencies are ok
The best for me would be to know the MyDomoAtHome.sh date in /etc/inin.d and in your MDAH directory so I could know when it work and when it doesn't... maybe a diff would be enough
Doler
Post by Doler »
epierre wrote:@doler try start2.sh as pi user to see if all libs dependencies are ok
Output of start2.sh:
pi@raspberrypi ~/domoticz/MyDomoAtHome $ ./start2.sh
YAML Warning: Duplicate map key found. Ignoring.
Code: YAML_LOAD_WARN_DUPLICATE_KEY
Line: 17
Document: 1
at /usr/local/share/perl/5.14.2/YAML/Mo.pm line 24, <$IN> line 1.
YAML::Mo::__ANON__(YAML::Loader=HASH(0x125e448), "YAML_LOAD_WARN_DUPLICATE_KEY") called at /usr/local/share/perl/5.14.2/YAML/Loader.pm line 356
YAML::Loader::_parse_mapping(YAML::Loader=HASH(0x125e448), "") called at /usr/local/share/perl/5.14.2/YAML/Loader.pm line 165
YAML::Loader::_parse_node(YAML::Loader=HASH(0x125e448)) called at /usr/local/share/perl/5.14.2/YAML/Loader.pm line 100
YAML::Loader::_parse(YAML::Loader=HASH(0x125e448)) called at /usr/local/share/perl/5.14.2/YAML/Loader.pm line 24
YAML::Loader::load(YAML::Loader=HASH(0x125e448), "# appdir/environments/development.yml\x{a}# configuration file fo"...) called at /usr/local/share/perl/5.14.2/YAML.pm line 33
YAML::Load("# appdir/environments/development.yml\x{a}# configuration file fo"...) called at /usr/local/share/perl/5.14.2/YAML.pm line 74
YAML::LoadFile("/home/pi/domoticz/MyDomoAtHome/environments/development.yml") called at /usr/share/perl5/Dancer/Config.pm line 201
eval {...} called at /usr/share/perl5/Dancer/Config.pm line 201
Dancer::Config::load_settings_from_yaml("/home/pi/domoticz/MyDomoAtHome/environments/development.yml") called at /usr/share/perl5/Dancer/Config.pm line 182
Dancer::Config::load("Dancer::Config") called at /usr/share/perl5/Dancer.pm line 258
Dancer::import("Dancer") called at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19
Plack::Sandbox::_2fhome_2fpi_2fdomoticz_2fMyDomoAtHome_2fbin_2fapp_2epl::BEGIN() called at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19
eval {...} called at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19
require /home/pi/domoticz/MyDomoAtHome/bin/app.pl called at (eval 10) line 3
eval 'package Plack::Sandbox::_2fhome_2fpi_2fdomoticz_2fMyDomoAtHome_2fbin_2fapp_2epl;
my $app = do $_file;
if ( !$app && ( my $error = $@ || $! )) { die $error; }
$app;
;' called at /usr/local/share/perl/5.14.2/Plack/Util.pm line 120
Plack::Util::_load_sandbox("/home/pi/domoticz/MyDomoAtHome/bin/app.pl") called at /usr/local/share/perl/5.14.2/Plack/Util.pm line 136
Plack::Util::load_psgi("/home/pi/domoticz/MyDomoAtHome/bin/app.pl") called at /usr/local/share/perl/5.14.2/Plack/Runner.pm line 179
Plack::Runner::__ANON__() called at /usr/local/share/perl/5.14.2/Plack/Runner.pm line 24
Plack::Runner::__ANON__() called at /usr/local/share/perl/5.14.2/Plack/Loader.pm line 55
Plack::Loader::preload_app(Plack::Loader=HASH(0xad4dd0), CODE(0xb6be90)) called at /usr/local/share/perl/5.14.2/Plack/Runner.pm line 274
Plack::Runner::run(Plack::Runner=HASH(0x9b33a0)) called at /usr/local/bin/plackup line 7
environment:development
log:core
logger:console
domoticz:http://192.168.2.202:8080
[20598] core @0.000052> PLACK_ENV is set (development) forcing PSGI handler in /usr/share/perl5/Dancer/Handler.pm l. 31
[20598] core @0.007802> loading Dancer::Handler::PSGI handler in /usr/share/perl5/Dancer/Handler.pm l. 45
[20598] core @0.077914> loading handler 'Dancer::Handler::PSGI' in /usr/share/perl5/Dancer.pm l. 464
2016/02/22-12:31:09 Starman::Server (type Net::Server::PreFork) starting! pid(20598)
Resolved [*]:3001 to [0.0.0.0]:3001, IPv4
Host [*] resolved to IPv6 address [::] but IO::Socket::INET6->new fails: Address family not supported by protocol at /usr/share/perl5/Net/Server/Proto.pm line 133.
Binding to TCP port 3001 on host 0.0.0.0 with IPv4
2016/02/22-12:31:09 Can't connect to TCP port 3001 on 0.0.0.0 [Address already in use]
at line 67 in file /usr/share/perl5/Net/Server/Proto/TCP.pm
2016/02/22-12:31:09 Received QUIT. Running a graceful shutdown
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 355.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 385.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 405.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 413.
2016/02/22-12:31:09 Worker processes cleaned up
2016/02/22-12:31:09 Server closing!
shutdown() on closed socket GEN1 at /usr/lib/perl/5.14/IO/Socket.pm line 294.
Output of diff /etc/init.d/MyDomoAtHome.sh ~/domoticz/MyDomoAtHome/MyDomoAtHome.sh
pi@raspberrypi ~/domoticz/MyDomoAtHome $ diff /etc/init.d/MyDomoAtHome.sh ~/domoticz/MyDomoAtHome/MyDomoAtHome.sh
14c14,18
< PATH=/bin:/usr/bin:/sbin:/usr/sbin:
> # CHANGE TO YOUR PATH HERE
> APP_DIR="/home/pi/domoticz/"
> PORT=3001
> # DO NOT CHANGE BELOW
> PATH=/bin:/usr/bin:/sbin:/usr/sbin:$HOME/perl5/bin
16a21,25
> PIDFILE=/var/run/$NAME.pid
> USER=www-data
> GROUP=www-data
20,23c29
< OPTIONS="-E production -s Starman --workers=4 -p 3001 -a /home/pi/domoticz/MyDomoAtHome/bin/app.pl --pid /tmp/mydomoathome.pid" # CHANGE TO YOUR PATH HERE
< # PIDFILE="$NAME.pid"
< PIDFILE="/tmp/mydomoathome.pid"
> OPTIONS="-E production -s Starman --workers=4 --user $USER --group $GROUP --port $PORT -a $APP_DIR/MyDomoAtHome/bin/app.pl"
85c91
< if [ "$SIGNAL" = "KILL" ]; then
> if [ "$SIGNAL" = "KILL" ] || [ "$SIGNAL" = "TERM" ]; then
119c125,127
> status)
> status_of_proc -p $PIDFILE $DAEMON "$NAME process" && exit 0 || exit $?
121c129
< echo "Usage: /etc/init.d/$NAME {start|force-start|stop|force-stop|reload|restart|force-reload}"
> echo "Usage: /etc/init.d/$NAME {start|force-start|stop|status|force-stop|reload|restart|force-reload}"
This is for the current (working) version.
Mark
epierre
Post by epierre »
@doler "Can't connect to TCP port 3001 on 0.0.0.0 [Address already in use]", you need to kill the starman master before starting it, it seems it is already running which is good !
can you send me the MyDomoAtHome.sh version that works for you so I shall make a regression till I find what is wrong ? [email protected]
I've restarted working on nodejs version yesterday, all statuses are good, switches also working, will follow on this in parallel now. I'll investigate on graphes as some reported on both at the same time.
Doler
Post by Doler »
epierre wrote:@doler "Can't connect to TCP port 3001 on 0.0.0.0 [Address already in use]", you need to kill the starman master before starting it, it seems it is already running which is good !
Yes, it's running :), it is the working version. I've sent you the MyDomoAtHome.sh file. I could also try a clean install to see if that works.
I'd be interested in the nodejs version, I have node version 5.3 running for my Nefit interface. If you need some testing to do, I can help.
Thanks, Mark
