Pilot: Home Automation Control (iOS app)
Bikey
- Domoticz version: 2020.x
Re: Pilot: Home Automation Control (iOS app)
Question: with the new beta, how can I mark/unmark a switch to be Favorite? Tapping on the star icon does not do anything.
patoo77
On which screen?Is it bugged on every kind of switch?Bikey wrote:Question: with the new beta, how can I mark/unmark a switch to be Favorite? Tapping on the star icon does not do anything.
Domoticz on iOS: Pilot: Home Automation Control
Bikey
Yes, nothing happens if I tap on the star, whatever screen that is (favorites, all switches, rooms).
patoo77
Working on my side :/Bikey wrote:Yes, nothing happens if I tap on the star, whatever screen that is (favorites, all switches, rooms).
Not sure what that could be about.
What iPhone do you have, and what version of Domoticz are you using?
Bikey
I'm on Domoticz 2.3530 (latest stable version) and an iPhone 6S. I'm logging In with Pilot on a general user (not admin) account, perhaps that is the issue?
Bikey
Ok, to answer my own question: the PilotRemote App user needs to have admin rights to be able to mark/unmark switches as favorites.
patoo77
That's a nice find. And very good to know!Bikey wrote:Ok, to answer my own question: the PilotRemote App user needs to have admin rights to be able to mark/unmark switches as favorites.
I could "not" display it if user doesn't have admin rights.
Will add it to the feature request list.
dannybloe
Yeah, that's kind of weird because to me, a favorite is something personal. It shouldn't be that an admin tells another user what his/her favorite should be. To me that's up the each user individually and should not be a global setting.
Alas.. that's just how it works. I strongly advocate that Pilot has its own favorite settings and simple ignores the favorites from Domoticz. It is very likely that a favorites list on a mobile device contains different devices than such a list on a desktop computer. On my phone I usually want to control devices and not so much want to monitor water temperatures etc. So on my phone I want a quick list of switches that I am very likely to operate.
So, maybe in a future version of Pilot I can make one (or even more different) favorite lists than can be easily switched depending on my need (like in which room I am chilling). I know you can achieve that with room plans but again, this is a global thing and not a personal thing.
patoo77
You're right. However not that many people have requested it so far.dannybloe wrote:Yeah, that's kind of weird because to me, a favorite is something personal. It shouldn't be that an admin tells another user what his/her favorite should be. To me that's up the each user individually and should not be a global setting.
patoo77
Been trying what dannybloe suggested: having relative swipe control when device is on, and absolute swipe when device is off -> it's way too confusing imo and doesn't work well, I'll keep relative swipe as it is in the current beta, see how that goes
However, I'll add a setting so that users can choose between absolute and relative swipe.
patoo77
1.7.0 is out!
Let me know how it goes;)
- Spoiler: show
pvm
- Domoticz version: 4.10538
Nice. I like the graphs and today support
schulpr
The app is getting better and better. My compliments and thank you for all your work. Is it possible to hide the roomplans that start with a "$" in the name? In this way we can hide roomplans like used in homebridge.
Thanks again!
Rob
Thanks again!
Rob
Nautilus
Thanks for the great app! I used the iOS today widget quite a lot but have now run into some issues when selector switches were added to the picture
Therefore I'd like to request that either a) selector switches would be implemented to Pilot (including the today widget) or b) possibility to select the "today widget" devices based on a room plan. And now that I think of it, actually I'd like to see these both implemented as selector switches would be a very nice addition as such and to allow the user to set the today widget devices/sensors etc would be the most user friendly option.
I guess this request is on the same lines as:
But I wouldn't mind separating the today widget from favorites so it could contain something different than the actual favorites (or at least a selection of the favorites if there's some stuff that is of no use in the today widget).dannybloe wrote:maybe in a future version of Pilot I can make one (or even more different) favorite lists than can be easily switched depending on my need (like in which room I am chilling). I know you can achieve that with room plans but again, this is a global thing and not a personal thing.
patoo77
Hi Nautilus,Nautilus wrote:Thanks for the great app! I used the iOS today widget quite a lot but have now run into some issues when selector switches were added to the pictureTherefore I'd like to request that either a) selector switches would be implemented to Pilot (including the today widget) or b) possibility to select the "today widget" devices based on a room plan. And now that I think of it, actually I'd like to see these both implemented as selector switches would be a very nice addition as such and to allow the user to set the today widget devices/sensors etc would be the most user friendly option.
I guess this request is on the same lines as:But I wouldn't mind separating the today widget from favorites so it could contain something different than the actual favorites (or at least a selection of the favorites if there's some stuff that is of no use in the today widget).dannybloe wrote:maybe in a future version of Pilot I can make one (or even more different) favorite lists than can be easily switched depending on my need (like in which room I am chilling). I know you can achieve that with room plans but again, this is a global thing and not a personal thing.
Selector switches will be in 1.8
I understand that you want to choose which devices appear in the today widget. Adding this to the feature request list. I was also thinking about making a "Scenes" widget.
patoo77
@everyone using PUSH notifications
Sound should now work. No update needed!
Can anyone confirm it actually works now?
patoo77
Adding this to the feature request list.schulpr wrote:Is it possible to hide the roomplans that start with a "$" in the name? In this way we can hide roomplans like used in homebridge.
hjvingen
I can confirm that the sound now works.patoo77 wrote:@everyone using PUSH notifications
Both on my watch and also on my phone I get sound with the notification.
Nautilus
Great, looking forward to 1.8!patoo77 wrote: Hi Nautilus,
Yes, correct. The actual method for enabling this is of course entirely up to you (in case it is doable) -using a room plan is just something that came to mind first. But could be done e.g. within the app as well...
Like the idea of a scene widget!
batso
Feature Request: How about showing a notification when someone rings on my doorbell?
