Humidity/temp sensor suggestion
stuiow
Domoticz version: 3.6857
Post by stuiow »
I would like to find c couple of temperature/humidity sensors that will work with either rfxtrx433e (NOT Oregon mode though!) or with z-wave.
Reason why not Oregon, I have byronSX mode active.
Any suggestions for a temperature/humidity sensor that ISN'T Oregon scientific?
Cheers
Stuart
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
SweetPants
Re: Humidity/temp sensor suggestion
Post by SweetPants »
stuiow wrote:Any suggestions for a temperature/humidity sensor that ISN'T Oregon scientific?
Did you search in the forum? I have three Cresta TX-320 using rfxtrx433e
stuiow
Post by stuiow »
Yeah I searched for through the forums and other forums using Google. Got some good results but none gave definitive advice on "non-oregon" devices.
I'll take a look at the Cresta TX-320 then, cheers.
Sent from my SM-G925F using Tapatalk
b_weijenberg
Post by b_weijenberg »
You can also use Oregon 1.0 or 2.1 sensors together with ByronSX enabled.
THR128
THR138
THC138
THC238/268
THN122N/132N
THWR288A
THRN122N
AW129
AW131
THGN122N/123N
THGR122NX
THGR228N
THGR238/268
RTGR328N
THGR328N
THGR918
THGRN228NX
THGN500
BTHR918N
BTHR968
RGR126
RGR682
RGR918
WGR918
UVN128
UV138
RTGR328N
RFX-433, RFX-433EMC, RFX-868
stuiow
Post by stuiow »
Are there different modes to enable for Oregon 1.0/2.1 against 3.0?
I did use a Owl 168 energy monitor but that blinded the ByronSx signals.
b_weijenberg
There is only one Oregon enabled for all Oregon sensors.
OWL sensors use the Oregon 3.0, except CM113 which is using 2.1
stuiow
Post by stuiow »
So by using one of those listed sensors above that use oeogen 1/2, it won't cause issues with my doorbells? I want to ensure when the bell pushes are pushed, domoticz see them.
