I would like to find c couple of temperature/humidity sensors that will work with either rfxtrx433e (NOT Oregon mode though!) or with z-wave.
Reason why not Oregon, I have byronSX mode active.
Any suggestions for a temperature/humidity sensor that ISN'T Oregon scientific?
Cheers
Stuart
Humidity/temp sensor suggestion
stuiow
- Domoticz version: 3.6857
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
SweetPants
Re: Humidity/temp sensor suggestion
Did you search in the forum? I have three Cresta TX-320 using rfxtrx433estuiow wrote:Any suggestions for a temperature/humidity sensor that ISN'T Oregon scientific?
stuiow
Yeah I searched for through the forums and other forums using Google. Got some good results but none gave definitive advice on "non-oregon" devices.
I'll take a look at the Cresta TX-320 then, cheers.
b_weijenberg
- Target OS: -
You can also use Oregon 1.0 or 2.1 sensors together with ByronSX enabled.
THR128
THR138
THC138
THC238/268
THN122N/132N
THWR288A
THRN122N
AW129
AW131
THGN122N/123N
THGR122NX
THGR228N
THGR238/268
RTGR328N
THGR328N
THGR918
THGRN228NX
THGN500
BTHR918N
BTHR968
RGR126
RGR682
RGR918
WGR918
UVN128
UV138
RTGR328N
THR128
THR138
THC138
THC238/268
THN122N/132N
THWR288A
THRN122N
AW129
AW131
THGN122N/123N
THGR122NX
THGR228N
THGR238/268
RTGR328N
THGR328N
THGR918
THGRN228NX
THGN500
BTHR918N
BTHR968
RGR126
RGR682
RGR918
WGR918
UVN128
UV138
RTGR328N
RFX-433, RFX-433EMC, RFX-868
stuiow
Are there different modes to enable for Oregon 1.0/2.1 against 3.0?
I did use a Owl 168 energy monitor but that blinded the ByronSx signals.
b_weijenberg
- Target OS: -
There is only one Oregon enabled for all Oregon sensors.
OWL sensors use the Oregon 3.0, except CM113 which is using 2.1
stuiow
So by using one of those listed sensors above that use oeogen 1/2, it won't cause issues with my doorbells? I want to ensure when the bell pushes are pushed, domoticz see them.
