Moon phase
Yihaaa
Moon phase
Post by Yihaaa »
Hereby my suggestion to add a "moon phase" feature.
On a lot a standard weather stations the phase of the moon can be seen and it looks me a good idea that it would be nice to have this implemented also in Domoticz 8-)
soiltech
Re: Moon phase
Post by soiltech »
*bump*
would love to see this as well, it is an important part for gardeners using this controller.
gizmocuz
Re: Moon phase
Post by gizmocuz »
Please give more details
URL, screenshot, API, usage, .....
LouiS22
Re: Moon phase
Post by LouiS22 »
gizmocuz wrote:Please give more details
I believe he'd like the data from: http://www.wunderground.com/weather/api ... onomy&MR=1
more specifically:
moon_phase
percentIlluminated
ageOfMoon
phaseofMoon
hemisphere
If I'm not mistaken,
gizmocuz
Re: Moon phase
Post by gizmocuz »
So something like a moon rise/set ?
I still do not get its usage ? Why is this important ? And can't the sun set/rise be used ?
LouiS22
Re: Moon phase
Post by LouiS22 »
gizmocuz wrote:So something like a moon rise/set ?
Not sure, but found this: http://www.almanac.com/content/planting ... g-calendar
Could be something in it :)
alexsh1
Domoticz version: v3.8975
Re: Moon phase
Post by alexsh1 »
No need to add anything to Domoticz.
One has to use the existing capabilities to add things like moon rise/set in case needed.
Please see my lua script below. Do not forget to add 5 dummy sensors and name the script "script_time_moon.lua" before placing it in lua directory under scripts in domoticz folder.
PS I am still developing it
    -- Variables to customize ------------------------------------------------
       local city = "London"            -- Your city for Wunderground API
       local countryCode = "UK"            -- Your country code for Wunderground API
       local idxmoonpercentage ='214'            -- Your virtual moon percentage illuminated Device ID
       local idxmoonage ='213'       -- Your virtual moon age Device ID
       local idxmoonphase ='210'       -- Your virtual phase moon Device ID
       local idxmoonrise='211'           -- Your virtual moon rise variable ID
       local idxmoonset='212'           -- Your virtual moon set variable ID
       local wuAPIkey = "" -- Your Weather Underground API Key
       local DEBUG = 0             -- 0 , 1 for domoticz log
    time = os.date("*t")
    if  ((time.min % 60)==0)  then -- Run every hour. Check the wundergroud API limitation before changing this
    json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
       --  API Wunderground
    local file=assert(io.popen('curl http://api.wunderground.com/api/'..wuAPIkey..'/astronomy/q/'..countryCode..'/'..city..'.json'))
    local raw = file:read('*all')
    file:close()
    s = (string.gsub(raw, "%c+", ""))
    if( DEBUG == 1) then print('Moon'..s) end
     -- moonrise
     moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
     print("Moonrise:\t"..moonriseHour..":"..moonriseMinute)
     -- moonset
     moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
     print("Moonset:\t"..moonsetHour..":"..moonsetMinute)
     -- percentage of moon illuminated
     percentIlluminated = string.match(s, [["percentIlluminated":"(%d+)"]])
     print("Percent:\t"..percentIlluminated.."%")
     -- age of moon since last new moon
     age = string.match(s, [["ageOfMoon":"(%d+)"]])
     print("Age:\t\t"..age)
     -- Phase of the moon
     moonPhase = string.match(s, [["phaseofMoon":"(.-)"]])
     print("Phase:\t"..moonPhase)
commandArray[1] = {['UpdateDevice'] = idxmoonphase.."|0|"..moonPhase}
commandArray[2] = {['UpdateDevice'] = idxmoonrise.."|0|"..moonriseHour..moonriseMinute}
commandArray[3] = {['UpdateDevice'] = idxmoonset.."|0|"..moonsetHour..moonsetMinute}
commandArray[4] = {['UpdateDevice'] = idxmoonage.."|0|"..age}
commandArray[5] = {['UpdateDevice'] = idxmoonpercentage.."|0|"..percentIlluminated}
papoo
Domoticz version: 4.10
Re: Moon phase
Post by papoo »
forecast.io have this information in daily json
daily: {
data: [
time: 1465941600,
summary: "Light rain throughout the day.",
icon: "rain",
sunriseTime: 1465963534,
sunsetTime: 1466020087,
moonPhase: 0.34,
precipIntensity: 0.0141,
precipIntensityMax: 0.0317,
precipIntensityMaxTime: 1466017200,...
moonPhase: 0.34,
just add it in forecast.io hardware like wind or rain?
moonPhase (only defined on daily data points): A number representing the fractional part of the lunation number of the given day: a value of 0 corresponds to a new moon, 0.25 to a first quarter moon, 0.5 to a full moon, and 0.75 to a last quarter moon. (The ranges in between these represent waxing crescent, waxing gibbous, waning gibbous, and waning crescent moons, respectively.)
source : https://developer.forecast.io/docs/v2
gizmocuz
Re: Moon phase
Post by gizmocuz »
Why not calculate the moon-phase yourself ?
http://www.nano-reef.com/topic/217305-a ... e-arduino/
jackslayter
Domoticz version: stable
Re: Moon phase
Post by jackslayter »
and add dummy device in Dz with moon phase like Alert device ;)
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
gizmocuz
Re: Moon phase
Post by gizmocuz »
Why a dummy device? We could create a 'moon sensor' ?
jackslayter
Re: Moon phase
yes, like Alert sensor
Toulon7559
Domoticz version: <2025
Re: Moon phase
Post by Toulon7559 »
For Python-applications the modules Astral and PyEphem provide easy & accurate calculation of moonphase, etc.
Last edited by Toulon7559 on Wednesday 01 February 2017 13:42, edited 4 times in total.
gizmocuz
Re: Moon phase
Post by gizmocuz »
I shown the calculation part already above... not that difficult, and should be easy to add to the system, just like the sunset/sunrise is calculated
Infact, someone could use that as a start place to implement it
wizjos
Re: Moon phase
Post by wizjos »
Thanks @alexsh1!
I used your script and modified it somewhat :mrgreen:
The result looks like this:
As you can see with a Custom sensor that represents the actual moonphase as an icon 8-)
-- MoonPhase script
-- Original by: alexsh1 in https://www.domoticz.com/forum/viewtopic.php?f=31&t=107
-- Adapted by wizjos 26-10-2016
-- Requirements:
-- 1 uservariable "MoonphaseCheck"
-- 1 dummy sensor (type percentage) for moonpercentage
-- 3 dummy sensors (type text) for moonphase, moonrise and moonset
-- 2 dummy sensors (type custom) for moonage and moonphase icon
-- 8 custom icon sets (http://domoticz-icon.aurelien-loyer.fr/) for the moonphase icons
-- note: Only the first (or 'on') icon of a custom iconset is used, so you need 8 different sets of custom icons
--       The icons are referenced by their internal number.
local checkvar = "MoonphaseCheck"               -- name of the uservar to check if update is allowed
local checktime = 3600                          -- check allowed every x seconds 3600 = 60 min. Check the wundergroud API limitation before changing this
local city = "<YOUR CITY HERE>"                 -- Your city for Wunderground API
local countryCode = "NL"                        -- Your country code for Wunderground API
local idxmoonpercentage ='125'                  -- Your virtual moon percentage illuminated Device ID
local idxmoonage ='131'                         -- Your virtual moon age Device ID
local idxmoonphase ='132'                       -- Your virtual moon phase Device ID
local idxmoonrise='124'                         -- Your virtual moon rise variable ID
local idxmoonset='127'                          -- Your virtual moon set variable ID
local idxmoonphaseicon = "133"                  -- Your virtual moon phase icon variable ID
local wuAPIkey = "<YOUR API KEY HERE>"          -- Your Weather Underground API Key
local DOMO_IP = "<YOUR DOMOTICZ IP HERE>"       -- Domoticz ip address
local DOMO_PORT = "8084"                        -- Domoticz port
local tempfilename = '/var/tmp/phase.tmp'       -- can be anywhere writeable
local debug=false                               -- false, true for domoticz log
function file_exists(path)
    -- function to check if a file exists
    local file = io.open(path, "rb")
    if file then file:close() end
    return file ~= nil
function timedifference(s)
    -- function to determine the difference in seconds between the current time and a given one
    year = string.sub(s, 1, 4)
    month = string.sub(s, 6, 7)
    day = string.sub(s, 9, 10)
    hour = string.sub(s, 12, 13)
    t1 = os.time()
    difference = os.difftime (t1, t2)
    return difference
function may_update(device, timeelapsed)
    -- function to check whether an update is allowed
    return uservariables_lastupdate[device] == nil or timedifference(uservariables_lastupdate[device]) >= timeelapsed
    url='http://api.wunderground.com/api/'..wuAPIkey..'/astronomy/q/'..countryCode..'/'..city..'.json'
    if (may_update(checkvar,checktime)==true) or (file_exists(tempfilename)==false) then
       -- read API Wunderground
        if debug then
            message ="Moonphase - Collecting data from: "..url
            if (file_exists(tempfilename)==false) then
                message=message.."because /var/tmp/phase.tmp does not exist."
            if (may_update(checkvar,checktime)==true) then
                message=message.." it's time."
            print(message)
            print("Difference: "..timedifference(uservariables_lastupdate[checkvar]).." seconds")
        read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
        commandArray['Variable:'..checkvar]=time.hour..":"..time.min
        file = io.open(tempfilename, "r")
        s= file:read("*a")
        s = (string.gsub(s, "%c+", ""))
        file:close()
        -- moonrise
        -- moonset
        -- set the moonPhaseIcon to your appropriate icon number (8 x)
        if moonPhase=="New" then
            moonPhaseIdx = 1
            moonPhaseIcon = 103
            moonPhase = "Nieuwe maan"
        if moonPhase=="Waxing Crescent" then
            moonPhaseIdx = 2
            moonPhaseIcon = 104
            moonPhase = "Wassende halve maan"
        if moonPhase=="First Quarter" then
            moonPhaseIdx = 3
            moonPhaseIcon = 105
            moonPhase = "Eerste kwartier"
        if moonPhase=="Waxing Gibbous" then
            moonPhaseIdx = 4
            moonPhaseIcon = 106
            moonPhase = "Wassende maan"
        if moonPhase=="Full" then
            moonPhaseIdx = 5
            moonPhaseIcon = 107
            moonPhase = "Volle maan"
        if moonPhase=="Waning Gibbous" then
            moonPhaseIdx = 6
            moonPhaseIcon = 108
            moonPhase = "Afnemende maan"
        if moonPhase=="Last Quarter" then
            moonPhaseIdx = 7
            moonPhaseIcon = 109
            moonPhase = "Laatste kwartier"
        if moonPhase=="Waning Crescent" then
            moonPhaseIdx = 8
            moonPhaseIcon = 110
            moonPhase = "Afnemende halve maan"
        -- Because there is no api command available to set a custom icon a JSON call is made
        -- This requires the following parameters:
        -- type = setused (not to be changed)
        -- idx = idxmoonphaseicon (not to be changed here)
        -- name = Maanfase (This is the Name of the control. You need to pass this value. This name will be displayd in the Domoticz GUI.
        -- description = (left empty: no need for a description in the Domoticz GUI)
        -- switchtype = 0 (not to be changed)
        -- customimage = moonPhaseIcon (not to be changed here)
        -- devoptions = 1;%20 (This is the 'axis-label'. Because only a number is sent a space (%20) is given as axis-label, resulting in no axis-label in Domoticz GUI (not to be changed)
        -- used = true (not to be changed)
        os.execute('curl -s -i -H "Accept: application/json" "http://"'..DOMO_IP..'":"'..DOMO_PORT..'"/json.htm?type=setused&idx="'..idxmoonphaseicon..'"&name=Maanfase&description=&switchtype=0&customimage="'..moonPhaseIcon..'"&devoptions=1;%20&used=true"')
        commandArray[2] = {['UpdateDevice'] = idxmoonrise.."|0|"..moonriseHour..":"..moonriseMinute}
        commandArray[3] = {['UpdateDevice'] = idxmoonset.."|0|"..moonsetHour..":"..moonsetMinute}
        commandArray[6] = {['UpdateDevice'] = idxmoonphaseicon.."|0|"..moonPhaseIdx}
        if debug then print("MoonPhase - Update not allowed: Difference is "..timedifference(uservariables_lastupdate[checkvar]).." seconds") end
Derik
Re: Moon phase
Post by Derik »
mmm try this get working...
Do i need the city name
Or the station id?
And the variable:
Do not understand this function?
Please explane som more...
Nice icon..
please share:
https://drive.google.com/drive/u/0/fold ... WdHV1Qxbm8
[email protected]
alexsh1
Re: Moon phase
Post by alexsh1 »
Good work @ wizjos!
Is your moon icon changing according to the moon phase? Very nice - now I'd like to implement it too :D
Amsterdam020
Domoticz version: 3.5629
Re: Moon phase
Post by Amsterdam020 »
https://en.m.wikipedia.org/wiki/Agricultural_astrology
"There is a lack of scientific evidence proving the beneficial effects of astrological gardening."
Nonetheless the moon phase is a nice extension to domoticz.
Rp3, youlesss, rfxcom, philips hue, dsb1820
wizjos
Re: Moon phase
Post by wizjos »
Derik wrote:mmm try this get working...
Or the station id?
The city name
The url should look like this:
http://api.wunderground.com/api/<YourwuAPIkey>/astronomy/q/NL/Nijmegen.json
Derik wrote: And the variable:
I'd love to, but I'm not completely sure about what exactly your question/problem is. When looking at your screenshot you're adding a uservariable. I use this variable to determine when the last check (= property lastupdated of this uservariable) was done. At this time plus 3600 seconds ore more the check/update is performed again. The uservariable displays a time, but this is purely cosmetic. The check is performed against the time of the last update.
Does that answer your question/clarifies things somewhat?
I was not aware of this site. Thanks for mentioning! I'll post my icon-sets a soon as I've sanitized things...
wizjos
Re: Moon phase
Post by wizjos »
alexsh1 wrote:Good work @ wizjos!
I can confirm it is 8-)
