Qubino
manwe
Qubino
Post by manwe »
I'm planning Z-Wave project for my new house and I think I would control it from my RaZBerry with Domoticz.
Because of the low power consumption and the possibility of temperature measurement I'd like to do it with Qubino Products but I'm not sure about compatibilty. Two of my three selected components are not in the Compatibility List in the Wiki and there is not much Information in the Forum about there components
Does that mean that they are not compatible or just not tested?
I would use these components:
ZMNHDD1 (Qubino Flush Dimmer)
ZMNHCD1 (Qubino Flush Shutter)
ZMNHBD1 (Qubino Flush 2 Relays)
Anyone here with positive or negative Experience with Qubino components?
Egregius
Domoticz version: v2024.7
Re: Qubino
Post by Egregius »
I would say not tested.
I have these:
Qubino ZMNHBA2 Flush 2 Relays
Qubino ZMNHDA2 Flush Dimmer
Qubino ZMNHCD Flush Shutter
On a Aeotec S2 stick.
Another ZMNHDD1 Dimmer is soon to be installed.
bbqkees
Domoticz version: 4.1x
Re: Qubino
Post by bbqkees »
I have both positive and negative experiences with Qubino.
As long as you have an Aeon Labs Gen 5 Z-Wave stick all Qubino devices will mostly work.
If you have the S2 stick you will run into problems with the Z-Wave Plus Qubino devices.
I am not sure about the Razberry.
I have 12 ZMNHDA2 dimmers and they work pretty well with Domoticz and 60+ Philips Master LED lights.
Dimming behavior is excellent and I also use the additional switch inputs.
The dimmer do sometimes flicker though at certain times, apparently due to power noise on the net.
I also have a ZMNHDD1 dimmer and this one is incompatible with the Aeon Labs S2 stick.
You can add the node to Domoticz, but it will report as dead immediately.
(It will work at least with the Gen 5 stick, confirmed by a colleague).
Egregius
Re: Qubino
Post by Egregius »
I remembered I read something like that about the ZMNHDD1 dimmer on a S2. Will know next week...
Strange because the ZMNHCD1 flush shutter is also Zwave+ and works as it should.
Egregius
Re: Qubino
Post by Egregius »
How long does it take to be marked as dead?
Hooked one up on a power cord to test...
Machielw
Re: Qubino
Post by Machielw »
ZMNHBD1 (Qubino Flush 2 Relays) Not working well (both gen 5 stick and razberry)
Status is not reporting good in Domoticz,
I could not get it to work well.
(there is a workaround, but to complicated to me)
Last edited by Machielw on Saturday 06 February 2016 16:55, edited 1 time in total.
Machielw
Re: Qubino
Post by Machielw »
ZMNHDD1 (Qubino Flush Dimmer) works well with me (gen 5 stick)
With Razberry I had a problem with the range after building it in the wall
Last edited by Machielw on Saturday 06 February 2016 16:57, edited 1 time in total.
Egregius
Re: Qubino
Post by Egregius »
My ZMNHDD1 Dimmer is installed, still not dead :)
The workaround for the Flush 2 relays isn't that complicated, please post your problem with it in that topic, I'll be happy to help ;)
manwe
Re: Qubino
Post by manwe »
Thanks for all your Feedback.
I think for this time I'll stay on the safe side and use Fibaro.
In the moment it's to risky for me to order more than 20 Components let them install to find out that they don't really work.
Maybe if I need some single components after that I'll give Qubino a chance.
Egregius
Re: Qubino
Post by Egregius »
Why do you think they won't work? I have 13 Qubino's installed and am very happy with them.
nickgosling
Re: Qubino
Post by nickgosling »
I have 4 ZMNHDD1's and the s2 and s3 inputs are not fully supported. I have a work around for that but I wish I had installed the non plus ones as they work perfectly
Sent from my Nexus 5X using Tapatalk
OTiby
Re: Qubino
Post by OTiby »
bbqkees wrote: I have 12 ZMNHDA2 dimmers and they work pretty well with Domoticz and 60+ Philips Master LED lights.
I have the same! I've 12 Qubino dimmers, now installed 5 of them, and it depends also on the combination of Qubino with driver and leds.
Flickering combination:
Qubino ZMNHDA2 H1S5P1
driver: http://www.ledlampendirect.nl/dimbare-e ... -watt.html
leds: http://www.ledlampendirect.nl/yphix-gu5 ... t-50w.html
Working, not flickering:
driver: http://www.ledlampendirect.nl/yphix-dim ... -watt.html
leds: http://www.ledlampendirect.nl/led-inbou ... v-20w.html
And the lights flickers sporadically, some days they work perfectly, other days they flickers sporadically. Some hours they are good, and then unexpectedly they flickers a couple of minutes.
recording of flickering:
http://1drv.ms/1OuzfsQ
Does someone has a solution for this?
Thanks in advance!
OTiby
Re: Qubino
Post by OTiby »
Someone?
juankar
Re: Qubino
Post by juankar »
Hello
I've just bought a Qubino ZMNHBD1 2Relays ... and I think it was a big error.
It does NOT work fine.
By hand it works ok but I doesn't report right status to Domoticz (or Domoticz doesn't read status).
Working from domoticz, via web: If I set on Q2 , Domoticz reports Q1 and Q2 ON although the only light on is the one on Q2. That's it turns on/off the correct lights but Dashboard doesn't show the real status. The same with energy report: it reports energy of Q1 as it were Q2 and opposite (some times).
It reports fine status of Q1 when manual switch, but not Q2
Manual switch of Q2 is reported as Q1. But a reset in ZWace control panel set every sensor right.
It looks like the fault is in Q2.
Refresh button in ZWave control panel set every sensor with its right value.
I think it was an OZwave libraries or Domoticz program error.
Anybody has found a solution?
Egregius
Re: Qubino
Post by Egregius »
Search for Qubino on the forum, solutions are provided.
OTiby
Re: Qubino
Post by OTiby »
OTiby wrote:Someone?
juankar
Re: Qubino
Post by juankar »
I can find any real solution. Just a workaround using a php script.
It looks like Q1 act as a Q1+Q2 when status is read and as relay when an order is sent. So when you send a switch ON order to Q2, this one change to ON and Q1 shows status ON because one of the two relays is ON, but it doesn't reflect the real status of Q1.
I wonder why the associations? Manual says that Group 2-3 are for Q1 state and 5-6 for Q2 state. So nodes associated whith Group2 must react when Q1 change and so for Q2. Doesn't it? then if Node 1 is associated with this groups it would receive changes in Q1 and Q2.
Egregius
Re: Qubino
Post by Egregius »
The php workaround works fine for a year here.
ESFnl
Domoticz version: 2022.2
Re: Qubino
Post by ESFnl »
I had the Qubino ZMNHBD1 Flush 2 Relays running for a few weeks (with a Zwave.me USB controller) and was testing some blockly events when suddenly the node appears dead. How could that be? It works or it won't I suppose. How can the node be broken suddenly?
Z-wave network.PNG (59.08 KiB) Viewed 6724 times
jvmaanen
Re: Qubino
Post by jvmaanen »
I have the same issues. I have two Qubino ZMNHBD1 Flush 2 Relays and a range extender close to each other. It worked for some time without issues and suddenly it appears dead. Sometimes I was able to switch the power off/on and reboot Domoticz. But today it doesn't work.
