ehallq
Re: Domoticz app 2.0
Post by ehallq »
This is the third time I report this problem. However,now I know what you have to do in order to fix this
See this thread.
http://www.domoticz.com/forum/viewtopic.php?f=6&p=65774
Since there are conflicting idx there are problems with the widgets (which make my purchase useless) . When I try to add a switch with idx 4, I get the scene with idx 4. Scenes seems to be choosen before switches if there are conflicts. Please fix this :-)
walnut2000
Post by walnut2000 »
Great App. Many thanks to all who are working on this.
Using premium, released version, I noticed something odd.
I had not noticed my phone had gone into power save mode and turned off wifi, so when I fired up the domoticz App it tried to connect via 3g and failed.
Now here's the odd bit - I turned WiFi back on and connected to my home WiFi, but the App still would not connect - closed the App and fired it up again and still no connect. Fired up the VPN client on my phone and it worked fine, so it
looks like the App had not recognised when the WiFi was restored and was still locked onto 3g.
Is this a bug?
sent via Tapatalk
bitjeverkeerd
Post by bitjeverkeerd »
Great app. I have one small "bug" with my Somfy screens (RFXCOM). In the "schakelaars" tabpage you can see the actual status (open or closed) but in the Dashboard tabpage (and also the "Ruimtes" tabpage) the actual status of the screens is invisible.
EdwinDaems
Post by EdwinDaems »
Great app..
Got the full version because of the geofencing which works great by the way.
Also thought it would work on my smartwatch (Gear S2) but became aware that Tizen isn't supported (non android wear)
I would love to see it getting developed so if I can contribute to that in any way, just ask.
Maybe an extra thread with bugs would be nice so all the bugs get seperated from the other questions asked in here.
I've encountered only one bug in my setup and that is with Blinds not working from within the app but working fine from the normal Domoticz frontpage.
Running Domoticz v2.3530 on Pi (SD card edition)
Would be nice if someone could shed any light on this.
Keep up the great work guys!
Thijsvr
Domoticz version: 2.4075
Post by Thijsvr »
Thijsvr wrote:Hi, just wanted to reply that I've been using the premium version of the app for some time now. Very happy with it so far. I have noticed two things though:
- Using widgets (well actually just one) consumes a lot of battery. 10 ~ 15% on a full day on a Galaxy S6.
- Android Wear app doesn't load on my Moto360 Gen1. It only opens the loading screen which cuts out after a few seconds.
I would like to add that I haven't been able to find a solution yet. I've reset my 360 which didn't solve anything and I've just bought a Huawei Watch which also doesn't work. I'm guessing there is something wrong with the app on my phone, which I'll install again to test.
superczar
Post by superczar »
Bug/Functionality issue report
- The camera section shows static images in the main page (probably by design)
However Selecting a specific camera opens it in a center zoomed in format only - The video can't be moved around or scaled down to get a full view
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
ehallq wrote:This is the third time I report this problem. However,now I know what you have to do in order to fix this
See this thread.
Yes, this is a known issue.
RoadXY
Post by RoadXY »
walnut2000 wrote:Great App. Many thanks to all who are working on this.
Is this a bug?
sent via Tapatalk
We only instruct Android to do something on the network/internet and Android takes care of it.
RoadXY
Post by RoadXY »
superczar wrote:Bug/Functionality issue report
Camera's is still a work in progress.
RoadXY
Post by RoadXY »
EdwinDaems wrote:Great app..
Not before all other bugs are squashed :lol:
RoadXY
Post by RoadXY »
bitjeverkeerd wrote:Great app. I have one small "bug" with my Somfy screens (RFXCOM). In the "schakelaars" tabpage you can see the actual status (open or closed) but in the Dashboard tabpage (and also the "Ruimtes" tabpage) the actual status of the screens is invisible.
You can show or hide this in settings
RoadXY
Post by RoadXY »
bvduijv wrote:Are you planning supporting Tablets (2 or 3 colums) in the future?
I saw a commit concerning a tablet-view (https://github.com/domoticz/domoticz-an ... b530727afa), is it still on your list?
Yes
RoadXY
Post by RoadXY »
I have 6 widgets on my homescreen and have no issues. We only update the widgets once per half our and on app startup.
Thijsvr
Post by Thijsvr »
Thanks for your reply, I'll look into it and see if I can find a reason why it's draining battery.
RoadXY
Post by RoadXY »
You could try to remove them, one in a day 2/3 and see if it get's any better?
Better is to have one removed per week because to test one day could have other influenced.
Thijsvr
Post by Thijsvr »
So I've reset my 360, no result. Got another watch, no result. Uninstalled Domoticz on my phone and watch and then reinstalled, no result. Also tried connecting the watch directly to my home network with and without the phone connected through Bluetooth and again it didn't work. Other than getting another phone to test with I'm out of ideas.
galadril
Domoticz version: latest
Post by galadril »
Thijsvr wrote:So I've reset my 360, no result. Got another watch, no result. Uninstalled Domoticz on my phone and watch and then reinstalled, no result. Also tried connecting the watch directly to my home network with and without the phone connected through Bluetooth and again it didn't work. Other than getting another phone to test with I'm out of ideas.
Have you enabled custom items for Wear in the settings?
Or do you use default settings for Wear (then it only shows switch types that are supported for wear)?
koluniu
Post by koluniu »
Hi, i still can't get the connection by app to my Domoticz. Can somebody help me with the connection settings? I've tried every configuration and still nothing.
jannl
Domoticz version: 2025.5.x
Post by jannl »
Is there a list somewhere of reported issues?
Because so far, the app looks very nice, but Dromotica works much better in my opinion.
galadril
Post by galadril »
jannl wrote:Is there a list somewhere of reported issues?
https://github.com/domoticz/domoticz-android/issues
jannl wrote:but Dromotica works much better in my opinion.
What features are better then?
