Re: Domoticz app 2.0
This is the third time I report this problem. However,now I know what you have to do in order to fix this
See this thread.
http://www.domoticz.com/forum/viewtopic.php?f=6&p=65774
Since there are conflicting idx there are problems with the widgets (which make my purchase useless) . When I try to add a switch with idx 4, I get the scene with idx 4. Scenes seems to be choosen before switches if there are conflicts. Please fix this
See this thread.
Great App. Many thanks to all who are working on this.
Using premium, released version, I noticed something odd.
I had not noticed my phone had gone into power save mode and turned off wifi, so when I fired up the domoticz App it tried to connect via 3g and failed.
Now here's the odd bit - I turned WiFi back on and connected to my home WiFi, but the App still would not connect - closed the App and fired it up again and still no connect. Fired up the VPN client on my phone and it worked fine, so it
looks like the App had not recognised when the WiFi was restored and was still locked onto 3g.
Is this a bug?
sent via Tapatalk
Is this a bug?
sent via Tapatalk
- bitjeverkeerd
Great app. I have one small "bug" with my Somfy screens (RFXCOM). In the "schakelaars" tabpage you can see the actual status (open or closed) but in the Dashboard tabpage (and also the "Ruimtes" tabpage) the actual status of the screens is invisible.
Great app..
Got the full version because of the geofencing which works great by the way.
Also thought it would work on my smartwatch (Gear S2) but became aware that Tizen isn't supported (non android wear)
I would love to see it getting developed so if I can contribute to that in any way, just ask.
Maybe an extra thread with bugs would be nice so all the bugs get seperated from the other questions asked in here.
I've encountered only one bug in my setup and that is with Blinds not working from within the app but working fine from the normal Domoticz frontpage.
Running Domoticz v2.3530 on Pi (SD card edition)
Would be nice if someone could shed any light on this.
Keep up the great work guys!
- Thijsvr
- Domoticz version: 2.4075
I would like to add that I haven't been able to find a solution yet. I've reset my 360 which didn't solve anything and I've just bought a Huawei Watch which also doesn't work. I'm guessing there is something wrong with the app on my phone, which I'll install again to test.Thijsvr wrote:Hi, just wanted to reply that I've been using the premium version of the app for some time now. Very happy with it so far. I have noticed two things though:
- Using widgets (well actually just one) consumes a lot of battery. 10 ~ 15% on a full day on a Galaxy S6.
- Android Wear app doesn't load on my Moto360 Gen1. It only opens the loading screen which cuts out after a few seconds.
Bug/Functionality issue report
- The camera section shows static images in the main page (probably by design)
However Selecting a specific camera opens it in a center zoomed in format only - The video can't be moved around or scaled down to get a full view
- RoadXY
- Domoticz version: 2.2331
Yes, this is a known issue.ehallq wrote:This is the third time I report this problem. However,now I know what you have to do in order to fix this
See this thread.
- RoadXY
We only instruct Android to do something on the network/internet and Android takes care of it.walnut2000 wrote:Great App. Many thanks to all who are working on this.
Is this a bug?
sent via Tapatalk
- RoadXY
Camera's is still a work in progress.superczar wrote:Bug/Functionality issue report
- RoadXY
Not before all other bugs are squashedEdwinDaems wrote:Great app..
- RoadXY
You can show or hide this in settingsbitjeverkeerd wrote:Great app. I have one small "bug" with my Somfy screens (RFXCOM). In the "schakelaars" tabpage you can see the actual status (open or closed) but in the Dashboard tabpage (and also the "Ruimtes" tabpage) the actual status of the screens is invisible.
- RoadXY
Yesbvduijv wrote:Are you planning supporting Tablets (2 or 3 colums) in the future?
I saw a commit concerning a tablet-view (https://github.com/domoticz/domoticz-an ... b530727afa), is it still on your list?
- RoadXY
I have 6 widgets on my homescreen and have no issues. We only update the widgets once per half our and on app startup.Thijsvr wrote:Hi, just wanted to reply that I've been using the premium version of the app for some time now. Very happy with it so far. I have noticed two things though:
- Thijsvr
Thanks for your reply, I'll look into it and see if I can find a reason why it's draining battery.RoadXY wrote:I have 6 widgets on my homescreen and have no issues. We only update the widgets once per half our and on app startup.Thijsvr wrote:Hi, just wanted to reply that I've been using the premium version of the app for some time now. Very happy with it so far. I have noticed two things though:
- RoadXY
You could try to remove them, one in a day 2/3 and see if it get's any better?Thijsvr wrote:Thanks for your reply, I'll look into it and see if I can find a reason why it's draining battery.RoadXY wrote:I have 6 widgets on my homescreen and have no issues. We only update the widgets once per half our and on app startup.Thijsvr wrote:Hi, just wanted to reply that I've been using the premium version of the app for some time now. Very happy with it so far. I have noticed two things though:
Better is to have one removed per week because to test one day could have other influenced.
- Thijsvr
So I've reset my 360, no result. Got another watch, no result. Uninstalled Domoticz on my phone and watch and then reinstalled, no result. Also tried connecting the watch directly to my home network with and without the phone connected through Bluetooth and again it didn't work. Other than getting another phone to test with I'm out of ideas.Thijsvr wrote:I would like to add that I haven't been able to find a solution yet. I've reset my 360 which didn't solve anything and I've just bought a Huawei Watch which also doesn't work. I'm guessing there is something wrong with the app on my phone, which I'll install again to test.Thijsvr wrote:Hi, just wanted to reply that I've been using the premium version of the app for some time now. Very happy with it so far. I have noticed two things though:
- galadril
- Domoticz version: latest
Have you enabled custom items for Wear in the settings?Thijsvr wrote:So I've reset my 360, no result. Got another watch, no result. Uninstalled Domoticz on my phone and watch and then reinstalled, no result. Also tried connecting the watch directly to my home network with and without the phone connected through Bluetooth and again it didn't work. Other than getting another phone to test with I'm out of ideas.
Or do you use default settings for Wear (then it only shows switch types that are supported for wear)?
Hi, i still can't get the connection by app to my Domoticz. Can somebody help me with the connection settings? I've tried every configuration and still nothing.
- Domoticz version: 2022.2
Is there a list somewhere of reported issues?
Because so far, the app looks very nice, but Dromotica works much better in my opinion.
- galadril
https://github.com/domoticz/domoticz-android/issuesjannl wrote:Is there a list somewhere of reported issues?
What features are better then?jannl wrote:but Dromotica works much better in my opinion.
