The Vellman K8090 USB relay card is delivered with a DLL that allows to control it under windows.
As I use a linux system I developped a driver that can control the card. I used C++
2 projects :
- K8090lib = a library that can send orders to the card (K8090lib.so)
- K8090cmd = a commandline utility that uses the library to control the card
As I recently discovered Domoticz (and fell back in front of what I dreamed of for years ;o) I would like to give you my work if you are interested
I thought I could include it myself but I am not sure about how I could include my files in the make process
I would be proud if I could contribute a little bit to this VERY nice project.
Let me know ...
Cheers
Christophe
Velleman K8090 USB relay card support
Re: Velleman K8090 USB relay card support
Christophe
I'm looking for a USB relay card... So I'm very interested in your solution.
Albert
Albert
Hi Albert
I am very happy with the Vellman K8090 card
Note that it needs an external power supply to activate the 8 power relays
Regarding the C++ development I did to control it = I will be happy to provide it to you
I need to package it correctly ;o)
I will let you know when it will be ready. I will probably put it on Sourceforge
Cheers
Christophe
Cheers
Christophe
Here it is !
https://sourceforge.net/projects/k8090/
The packaging is super light ...
Christophe
Christophe
Hi Chris,chris.garcia wrote:Here it is !
Christophe
I just got my raspberry pi 2b and velleman relay board.
I have downloaded Your code from sourceforge, but as i'm new on linux didn't understand how to use it (I also read Readme file)
Can You please explain, how to correctly use Your provided files.
