Velleman K8090 USB relay card support
chris.garcia
Post by chris.garcia »
The Vellman K8090 USB relay card is delivered with a DLL that allows to control it under windows.
As I use a linux system I developped a driver that can control the card. I used C++
2 projects :
- K8090lib = a library that can send orders to the card (K8090lib.so)
- K8090cmd = a commandline utility that uses the library to control the card
As I recently discovered Domoticz (and fell back in front of what I dreamed of for years ;o) I would like to give you my work if you are interested
I thought I could include it myself but I am not sure about how I could include my files in the make process
I would be proud if I could contribute a little bit to this VERY nice project.
Let me know ...
Cheers
Christophe
Sappien
Re: Velleman K8090 USB relay card support
Post by Sappien »
Christophe
I'm looking for a USB relay card... So I'm very interested in your solution.
Albert
chris.garcia
Hi Albert
I am very happy with the Vellman K8090 card
Note that it needs an external power supply to activate the 8 power relays
Regarding the C++ development I did to control it = I will be happy to provide it to you
I need to package it correctly ;o)
I will let you know when it will be ready. I will probably put it on Sourceforge
Cheers
Christophe
chris.garcia
Here it is !
https://sourceforge.net/projects/k8090/
The packaging is super light ...
Christophe
Sappien
Post by Sappien »
Thankz
1stmaster
Post by 1stmaster »
chris.garcia wrote:Here it is !
Christophe
Hi Chris,
I just got my raspberry pi 2b and velleman relay board.
I have downloaded Your code from sourceforge, but as i'm new on linux didn't understand how to use it (I also read Readme file) :?
Can You please explain, how to correctly use Your provided files.
