Battery_level_check script - nil value :/
karde
Domoticz version: 3.7412
Post by karde »
Trying to run the script:
https://www.domoticz.com/wiki/Battery_level_check
Have copied this "installed" it under the lua folder, I have installed jq, and have the below values under user variable in domoticz:
These are the name that I have under devices:
I have the following set for the lua script (johan is the one running domoticz)
-rw-rw-r-- 1 johan johan 2446 jan 26 12:50 script_time_battery.lua
and the following for the tmp file:
-rwxrwxrwx 1 johan johan 0 jan 26 12:55 JsonAllDevData.tmp
Is this correct?
Cause when I the script runs I get the following error i domoticz:
2016-01-26 12:55:00.444 Error: EventSystem: /home/johan/domoticz/scripts/lua/script_time_battery.lua:42: attempt to concatenate local 'DeviceIDToCheckBatteryLevel' (a nil value)
jvdz
Domoticz version: 4.107
Re: Battery_level_check script - nil value :/
Post by jvdz »
You have a mixup on Upeer/Lowercase case characters for VattenSensorKokTemp.
The devicename in the device list is VattensensorKokTemp. :)
Jos
karde
Post by karde »
Goddammit that embarrassing :)
But, I changed it to the below
Still the same error though :/
2016-01-26 18:10:00.267 Error: EventSystem: /home/johan/domoticz/scripts/lua/script_time_battery.lua:42: attempt to concatenate local 'DeviceIDToCheckBatteryLevel' (a nil value)
Ain't it the name from under "devices", and the name that has a battery icon on it you should use?
jvdz
Post by jvdz »
Did you check the contents of: /var/tmp/JsonAllDevData.tmp ?
You could add these lines for debugging purposes:
     --Determine battery level
       print("DomoticzIP:",DomoticzIP)
       print("DomoticzPort:",DomoticzPort)
       print("DeviceIDToCheckBatteryLevel:",DeviceIDToCheckBatteryLevel)
       print("DeviceName:",DeviceName)
       local handle = io.popen("curl 'http://" .. DomoticzIP .. ":" .. DomoticzPort .. "/json.htm?type=devices&rid=" .. DeviceIDToCheckBatteryLevel .. "' 2>/dev/null | /usr/local/bin/jq -r .result[].BatteryLevel")
Jos
karde
Post by karde »
Thanks for your help jvdz, added the above commands in the script but the temp file is still empty (and got the above error).
Tried to remove the JsonAllDevData.tmp and seems like root want to change it so update the permissions on both files as follow:
-rw-rw-rw- 1 root root 0 jan 26 19:05 JsonAllDevData.tmp
-rw-rw-rw- 1 root root 2633 jan 26 19:06 script_time_battery.lua
I get this in domoticz log:
2016-01-26 19:08:00.378 LUA: DomoticzIP:
2016-01-26 19:08:00.378 LUA: 172.16.30.20
2016-01-26 19:08:00.378 LUA: DomoticzPort:
2016-01-26 19:08:00.378 LUA: 8081
2016-01-26 19:08:00.378 LUA: DeviceIDToCheckBatteryLevel:
2016-01-26 19:08:00.378 LUA: DeviceName:
2016-01-26 19:08:00.378 LUA: Flood
2016-01-26 19:08:00.378 Error: EventSystem: /home/johan/domoticz/scripts/lua/script_time_battery.lua:46: attempt to concatenate local 'DeviceIDToCheckBatteryLevel' (a nil value)
jvdz
Post by jvdz »
Is JsonAllDevData.tmp located in directory /var/tmp as I also see the LUA script there?
Jos
karde
Post by karde »
No sorry,
the lua script in under:
-rw-rw-rw- 1 root root 2633 jan 26 19:12 script_time_battery.lua
johan@domoticz:~/domoticz/scripts/lua$ pwd
and the JsonAllDevData.tmp is under /var/tmp:
-rw-rw-rw- 1 root root 0 jan 26 19:13 JsonAllDevData.tmp
johan@domoticz:/var/tmp$ pwd
/var/tmp
simonrg
Domoticz version: 3.8807
Post by simonrg »
It would probably be a good idea to post your version of the script in a code block here, as line 46 where you have error according to previous post appears to be blank on the wiki.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
karde
Post by karde »
Thanks, sure, but I guess that the the reason that's it is line 46 i because I pasted the above print from jvdz.
--~/domoticz/scripts/lua/script_time_battery.lua
-- Check battery level of devices
--Uservariables
BatteryLevelSetPoint=99
EmailTo="[email protected]"
ReportHour=19
ReportMinute=13
DomoticzIP="172.16.30.20"
DomoticzPort="8081"
Message = 'Batterijchecker'
DeviceFileName = "/var/tmp/JsonAllDevData.tmp"
-- Time to run?
time = os.date("*t")
if time.hour == ReportHour and time.min == ReportMinute then
    -- Update the list of device names and ids to be checked later
    os.execute("curl 'http://" .. DomoticzIP .. ":" .. DomoticzPort .. "/json.htm?type=devices&order=name' 2>/dev/null| /usr/local/bin/jq -r '.result[]|{(.Name): .idx}' >" .. DeviceFileName)
    BattToReplace = false
    -- Retrieve the battery device names from the user variable - stored as name one|name 2|name 3|name forty one
    DevicesWithBatteries = uservariables["DevicesWithBatteries"]
    DeviceNames = {}
    for DeviceName in string.gmatch(DevicesWithBatteries, "[^|]+") do
       DeviceNames[#DeviceNames + 1] = DeviceName
    -- Loop round each of the devices with batteries
    for i,DeviceName in ipairs(DeviceNames) do
       --Determine device id
       local handle = io.popen("/usr/local/bin/jq -r '.\"" .. DeviceName .. "\" | values' " .. DeviceFileName)
       local DeviceIDToCheckBatteryLevel = handle:read("*n")
       handle:close()
       local BattLevel = string.gsub(handle:read("*a"), "\n", "")
       handle:close()
       print(DeviceName .. ' batterylevel is ' .. BattLevel .. "%")
       -- Check batterylevel against setpoint
       if tonumber(BattLevel) < BatteryLevelSetPoint then
          BattToReplace = true
          print("!!!" .. DeviceName .. " batterylevel below " .. BatteryLevelSetPoint .. "%, current " .. BattLevel .. "%")
          Message = Message .. '\n *** ' .. DeviceName .. ' battery level is ' .. BattLevel .. '%'
    -- Only send an email if at least one battery fails the test
    if(BattToReplace) then
       commandArray['SendEmail']='Domoticz Battery Levels#'.. Message .. '#' .. EmailTo
--LUA default
I am running on Ubuntu, but that shouldn't be ann issue - right..?
Thanks everyone for the assistance!
Westcott
Post by Westcott »
From your earlier post, the log shows no value on a new line after -
This suggests that DeviceIDToCheckBatteryLevel has a nil value when it is assigned by -
Can you do a -
print("/usr/local/bin/jq -r '.\"" .. DeviceName .. "\" | values' " .. DeviceFileName)
to see if the file name is formed correctly?
jvdz
Post by jvdz »
Do I see it correctly that JsonAllDevData.tmp is empty which would indicate that the initial retrieval of all devices is failing?
Are the IP and port correct or do you have security enabled for local lan access?
Just try this url in a browser to test:
http://172.16.30.20:8081/json.htm?type=devices&order=name
Jos
karde
Post by karde »
Thanks guys.. I tried
http://172.16.30.20:8081/json.htm?type= ... order=name
got back :/
401 Unauthorized
Edited the settings under domoticz to allow for local area network, didn't know that you had to do this / that this option was there..
but now it's working :)!!
So I guess now I don't have any login page..? that's fine, but strange that you have to disable it to get the script to work, didn't cross my mind..
Thanks everyone for your help!! It's amazing that you put time to help me in this, really appreciate your support!!!
Thanks jvdz and Westcott.
jvdz
Post by jvdz »
You also could have used 127.0.0.1 as IP address as the script runs on the same hardware as the server and allow that subnet in without any login.
Guess it is quite common to allow the local LAN subnet in without a login and anything external force the login prompt.
Jos
karde
Post by karde »
True, on a small home network this ain't any issue..
Didn't now that you need to allow it under the domoticz GUI for the scripting though..
Thanks again! I'm really happy that It's working :)!
simonrg
Post by simonrg »
karde wrote:True, on a small home network this ain't any issue..
Didn't know that you need to allow it under the domoticz GUI for the scripting though..
If you want to keep local authentication, then you shouldn't need to turn it off, just incorporate your username and password in the DomoticzIP variable:
DomoticzIP="username:[email protected]"
mischa
Domoticz version: 3.8872
Post by mischa »
I have the same problem, but think it is because my JsonAllDevData.tmp file has not sufficient rights.
cannot open it or change it.
I use WINSCP for editing and file transfer.
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
mischa
Post by mischa »
Try to install Jq-1.4 but get an error, can anybody help me out.
Thanks,
Mischa
mischa
Post by mischa »
After digging around, I found out that I had no compiler installed.
updating first; sudo apt-get update
next install; sudo apt-get install build-essential
after this I could configure and make the install.
Now the battery script is working. Maybe somebody can update the WIKI page.
simonrg
Post by simonrg »
mischa wrote:..... Maybe somebody can update the WIKI page.
Yes, you can update the Wiki page, just log in with your Forum id and click edit on the page.
