I'm new to Domoticz and I was wondering if it was possible to use a secondary raspberry pi to extract the Power / Gas usage data and publish it to the Domoticz Raspberry Pi?
Thanks in advance.
P1 Port - Secundairy Raspberry Pi (Smart Meter)
daandamhuis
- Domoticz version: 2.4608
RPi Model 2: Domoticz Server (Beta)
RPi Model B+: Smart Meter Slave (Stable)
Particle Photon (2x): Prototyping, Controlling LEDS and gathering Sensor data for Domoticz
Arduino Uno R3: with CC2500 Shield for Philips LivingColor Lights 1st Gen.
- bbqkees
- Domoticz version: 4.1x
Re: P1 Port - Secundairy Raspberry Pi (Smart Meter)
Yes you can. But there is also a very cheap option by using f.i. a ESP822/NodeMcu device.
Someone here uses it to send the data to Domoticz.
daandamhuis
Thanks for the reply but I would like to stick with the RPI, since I've bought a P1 USB Cable and Wifi Dongle for it and I have 3 RPI's laying around. Does anyone have an example for the RPI "Slave" for Domoticz?
- bbqkees
The function is called 'remote domoticz server'.
You can add it in the Hardware menu.
If needed, the port can be changed in teh Setting menu.
daandamhuis
Thanks! I'll look into this function!
- sincze
- Domoticz version: 2024.4
or if you don't want to use domoticz remote server on your secondary raspberry,
you might want to consider using ser2net
and have your main domoticz use a smartmeter over lan.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
daandamhuis
Hi Sincze,
That seems like even a better option! Thanks for the Tip!
