I use zwave modules from Qubino to manage my electric heater. This module relies on a Dimmer widget to send 6 different orders to the heater: for instance, if dimmer is set at 50-100 values, then module understands "comfort" order, while values 0-9 mean "off" and "10-20" values mean "no freeze", etc. (I don't remember exact values, that's only to explain the logic).
So, in Domoticz, this module is displayed with the dimmer widget and I need to adjust the trigger on the bar to appropriate level to reach ad hoc value, and fidning the exact level is not always easy, especially on small screens. Instead of that, I'd like to create 6 buttons which I would press to trigger the 6 orders. Maybe it requires only some light coding ?
How should I proceed to do so ?
I'm not an expert in scripts or programming, but if I need to build a widget based on existing ones, I could probably contribute. But I could not find tutorials on how to build/modify these widgets, and I did not find either where it is coded in Domoticz (I found some xxx.js files, with a lot of code).
ricorico94
Modifying Dimmer widget into multiple buttons ?
ricorico94
- StephaneG
Re: Modifying Dimmer widget into multiple buttons ?
Did you work on this? Or find a solution?
I am also using the Fil Pilote Qubino modules, and intend to make a discrete-values dimmer UI object if noone has made one.
Regards,
Stéphane
Regards,
Stéphane
rtenklooster
I don't know for sure if i understand you correctly.
You might be able to accomplish this by creating 6 dummy devices. (Switches)
As On option you fill in this:
http://127.0.0.1//json.htm?type=command ... &level=YYY
Where XXX is the IDX of your current dimmer AND YYY Is the dim value e.g. 1-10
- Egregius
- Domoticz version: v2024.7
Take a look at my floorplan. I use buttons to control dimmers.
pj-r
- Domoticz version: V3.8650
Is this what you are looking for? viewtopic.php?f=31&t=7244#p66519
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
- StephaneG
Very much so, indeed ! Good find
With "Radiateur rdc hall" being the dimmer setpoint of a Qubino ZMNHJD1 ZWave pilot wire controller, and "Radiateurs rdc" being the virtual selector switch set with the 6 "pilot wire" possible values:
... and the blocky event :
Regards,
Stéphane
Regards,
Stéphane
oldchap
Hello
I'm currently installing the same qubino device.
I've some difficulties to identify the switch representing the "fil pilote", as 5 ones have been automatically created by the device ZMNHJD1 in my Domoticz.
As I'm not on the location with the "radiator", so have you an idea to be sure to select the good one (in order to program the same virtual selector switch you have done ?
Many thanks, as following some screen copies of my Domoticz.
https://docs.google.com/document/d/1qn ... p=sharing
Raspberry Pi 2B + RFXCOM + USB Z-Wave + Domoticz + Open-zwave
Pilotage Chaudière relai sec + Plancher chauffant Qubino (en cours) + Oregon températeur + Prises Chacon-like
- StephaneG
As said on thr french forum, it is the one ending in 1, so 301 in your case.
Regards,
Stéphane
Regards,
Stéphane
