[MyDomoAtHome] Support thread
tomeaton
Re: [MyDomoAtHome] Support thread
Post by tomeaton »
I'm having similar issues trying to get the software working. I've got to the stage of running start2.sh manually and get this error:
sh start2.sh
YAML Warning: Duplicate map key found. Ignoring.
   Code: YAML_LOAD_WARN_DUPLICATE_KEY
   Line: 17
   Document: 1
 at /usr/share/perl5/YAML/Mo.pm line 24, <$IN> line 1.
        YAML::Mo::__ANON__(YAML::Loader=HASH(0x21c4888), "YAML_LOAD_WARN_DUPLICATE_KEY") called at /usr/share/perl5/YAML/Loader.pm line 359
        YAML::Loader::_parse_mapping(YAML::Loader=HASH(0x21c4888), "") called at /usr/share/perl5/YAML/Loader.pm line 168
        YAML::Loader::_parse_node(YAML::Loader=HASH(0x21c4888)) called at /usr/share/perl5/YAML/Loader.pm line 103
        YAML::Loader::_parse(YAML::Loader=HASH(0x21c4888)) called at /usr/share/perl5/YAML/Loader.pm line 25
        YAML::Loader::load(YAML::Loader=HASH(0x21c4888), "# appdir/environments/development.yml\x{a}# configuration file fo"...) called at /usr/share/perl5/YAML.pm line 34
        YAML::Load("# appdir/environments/development.yml\x{a}# configuration file fo"...) called at /usr/share/perl5/YAML.pm line 75
        YAML::LoadFile("/home/pi/domoticz/MyDomoAtHome/environments/development.yml") called at /usr/share/perl5/Dancer/Config.pm line 201
        eval {...} called at /usr/share/perl5/Dancer/Config.pm line 201
        Dancer::Config::load_settings_from_yaml("/home/pi/domoticz/MyDomoAtHome/environments/development.yml") called at /usr/share/perl5/Dancer/Config.pm line 182
        Dancer::Config::load("Dancer::Config") called at /usr/share/perl5/Dancer.pm line 258
        Dancer::import("Dancer") called at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19
        Plack::Sandbox::_2fhome_2fpi_2fdomoticz_2fMyDomoAtHome_2fbin_2fapp_2epl::BEGIN() called at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19
        eval {...} called at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19
        require /home/pi/domoticz/MyDomoAtHome/bin/app.pl called at (eval 9) line 3
        eval 'package Plack::Sandbox::_2fhome_2fpi_2fdomoticz_2fMyDomoAtHome_2fbin_2fapp_2epl;
    my $app = do $_file;
    if ( !$app && ( my $error = $@ || $! )) { die $error; }
    $app;
;' called at /usr/local/share/perl/5.14.2/Plack/Util.pm line 120
        Plack::Util::_load_sandbox("/home/pi/domoticz/MyDomoAtHome/bin/app.pl") called at /usr/local/share/perl/5.14.2/Plack/Util.pm line 136
        Plack::Util::load_psgi("/home/pi/domoticz/MyDomoAtHome/bin/app.pl") called at /usr/local/share/perl/5.14.2/Plack/Runner.pm line 179
        Plack::Runner::__ANON__() called at /usr/local/share/perl/5.14.2/Plack/Runner.pm line 24
        Plack::Runner::__ANON__() called at /usr/local/share/perl/5.14.2/Plack/Loader.pm line 55
        Plack::Loader::preload_app(Plack::Loader=HASH(0x13986b0), CODE(0x165bf78)) called at /usr/local/share/perl/5.14.2/Plack/Runner.pm line 274
        Plack::Runner::run(Plack::Runner=HASH(0x138e618)) called at /usr/local/bin/plackup line 7
Error while loading /home/pi/domoticz/MyDomoAtHome/bin/app.pl: Can't locate Time/Moment.pm in @INC (@INC contains: /home/pi/domoticz/MyDomoAtHome/bin/../lib /home/pi/domoticz/MyDomoAtHome/lib /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 31.
BEGIN failed--compilation aborted at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 31.
Compilation failed in require at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 20.
BEGIN failed--compilation aborted at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 20.
Zycker
Post by Zycker »
Hi epierre,
I'm using Imperihome everyday on my tablet and phone and still very pleased with it.
Although, today I've created a new incremental counter on Domoticz and one alert sensor. It works fine in Domoticz but first the counter doesn't appear in Imperihome.
I did refresh both tablet and phone but nothing changed. It appears in mydomoip:3001/devices. I did run "sh ./update-mdah.sh" and it returns that everything is up to date. Domoticz v2.3866. Both software restarted.
The alert sensor appears on my devices but without the colors that are shown in Domoticz and without the "text" that I enter with the value.
Purejet
Post by Purejet »
After a few months usable installation of imperihome on rpi, yesterday i had to reboot the pi.
After that the imperihome didn't come up anymore. Can anyone help me in the right direction;
./start2.sh
Error while loading /home/pi/domoticz/MyDomoAtHome/bin/app.pl: Can't find string terminator ")" anywhere before EOF at /usr/share/perl5/Dancer.pm line 42, <DATA> line 1000.
Compilation failed in require at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19, <DATA> line 1000.
BEGIN failed--compilation aborted at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19, <DATA> line 1000.
./run-once.sh
Will update packages list first...
Now getting the needed software...
Now getting getting and installing dependencies...
Reading package lists... Done
Building dependency tree
Reading state information... Done
cpanminus is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
--> Working on Task::Plack
Fetching http://www.cpan.org/authors/id/M/MI/MIYAGAWA/Task-Plack-0.28.tar.gz ... OK
Configuring Task-Plack-0.28 ... OK
==> Found dependencies: Starlet
--> Working on Starlet
Fetching http://www.cpan.org/authors/id/K/KA/KAZUHO/Starlet-0.28.tar.gz ... OK
Configuring Starlet-0.28 ... OK
Building and testing Starlet-0.28 ...
I have already copy the repo MyDomoAtHome again and run the run-once again keeps hanging on building and testing starlet-0.28.
The 3001/devices page also doesn't work anymore. When i start the service it says OK.
Drdre
Post by Drdre »
Hello Epierre,
I've got this error:
Can you help me????
fixeon
Domoticz version: 3.6587
Post by fixeon »
Hi i'm using docker and i'm doing something wrong but i can't figure out what.
Running domoticz V2.4031 on Archlinux64 and mdah through docker on same machine.
sudo docker run --name=mydomoathome --env domo_path="http://192.168.1.10:8080" -it --rm -p 3001:3001 epierre/mydomoathome
2016/01/08-09:23:00 Starman::Server (type Net::Server::PreFork) starting! pid(8)
Resolved [*]:3001 to [::]:3001, IPv6
Not including resolved host [0.0.0.0] IPv4 because it will be handled by [::] IPv6
Binding to TCP port 3001 on host :: with IPv6
Setting gid to "0 0"
Use of uninitialized value in concatenation (.) or string at /MyDomoAtHome/lib/Domo.pm line 343.
Use of uninitialized value $ver in string at /MyDomoAtHome/lib/Domo.pm line 809.
Use of uninitialized value $mpd_host in string ne at /MyDomoAtHome/lib/Domo.pm line 817.
Use of uninitialized value in concatenation (.) or string at /MyDomoAtHome/lib/Domo.pm line 831.
Use of uninitialized value in concatenation (.) or string at /MyDomoAtHome/lib/Domo.pm line 865.
when i try to connect to server i get
{"devices":[{"id":"S00","name":"Unable to connect to Domoticz","type":"DevGenericSensor","params":[{"graphable":"false","key":"Value","value":"","unit":""}]},{"name":"Please add this gateway in Setup/settings/Local Networks","params":[{"graphable":"false","key":"Value","value":"","unit":""}],"type":"DevGenericSensor","id":"S01"}]}
Docker Network inspect
sudo docker network inspect 9dc8fdcf12d5
        "Name": "bridge",
        "Id": "9dc8fdcf12d5bf6846142f6a06ab15d88276c8d7e64ebdc16101dca446e1f213",
        "Scope": "local",
        "Driver": "bridge",
        "IPAM": {
            "Driver": "default",
            "Config": [
                    "Subnet": "172.17.0.0/16"
        "Containers": {
            "8901681f1ced0e5f48736bf313598d1647695fa98b4fe22e31018fc783d46a68": {
                "EndpointID": "cd515d27ee2de91f7b99f239252e88be34cc310b09b624ac8e97772569e45162",
                "MacAddress": "**.***.**.**",
                "IPv4Address": "172.17.0.2/16",
                "IPv6Address": ""
        "Options": {
            "com.docker.network.bridge.default_bridge": "true",
            "com.docker.network.bridge.enable_icc": "true",
            "com.docker.network.bridge.enable_ip_masquerade": "true",
            "com.docker.network.bridge.host_binding_ipv4": "0.0.0.0",
            "com.docker.network.bridge.name": "docker0",
            "com.docker.network.driver.mtu": "1500"
Authorised networks in Domoticz
192.168.1.*; 127.0.0.*;172.17.0.*
Domoticz host ip 192.168.1.10 (fixed)
Any idea ?
Raspberry Pi 2 Type B or Arch64 Server (still testing)
RFXTRX433E + Aeotec Z-Stick S2
All pcs running various linux distros including sat receiver
Extreme noob warning :)
johansson
Post by johansson »
Hmm, I'm a bit lost now: after reading the topics and documentations, I still cannot get the gateway up and running.
Domoticz is installed on a Raspberry Pi (192.168.1.50, port 8080. The MyDomoAtHome installation was completed without errors, but still no luck:
1) the domo_path in config.yml changed to "http://192.168.1.50:8080" or "http://192.168.1.50:3001" or "http://192.168.1.50:whatever"
2) Port in MyDomoAtHome.sh changed respectively to 8080 or 3001 or something
Result always the same: http://192.168.1.50:8080/devices ends up always to normal Domoticz interface and http://192.168.1.50:3001/devices (or any alternative) results in "Safari can't connect to the Server"
Long story short: what should the gateway ip and port be set to?
hanor
Post by hanor »
I've got this error when executing start2.sh
[21887] debug @0.731817> [hit #1]DBG:182:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[21887] error @3.781034> [hit #1]request to GET /devices crashed: Could not create socket: Aucun chemin d'accès pour atteindre l'hôte cible in /usr/share/perl5/Dancer/Handler.pm l. 98
Any idea ?
epierre
Post by epierre »
tomeaton wrote:I'm having similar issues trying to get the software working. I've got to the stage of running start2.sh manually and get this error:
sh start2.sh
a missing dependency that should be in the run-once.sh ; try this manually:
sudo cpanm Time::Moment
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
epierre
Post by epierre »
Drdre wrote:Hello Epierre,
Can you help me????
same for you:
epierre
Post by epierre »
fixeon wrote:Hi i'm using docker and i'm doing something wrong but i can't figure out what.
Any idea ?
no, I'm not docker specialist enough maybe, is the machine running docker on the same subnet as domoticz ?
some command:
$ docker-machine ip
or
$ docker inspect --format '{{ .NetworkSettings.IPAddress }}' $(docker ps -q)
or
$ boot2docker ip (on mac)
What gives this:
docker inspect -f '{{ json .NetworkSettings }}' YOUR_IMAGE_ID
epierre
Post by epierre »
johansson wrote:Hmm, I'm a bit lost now: after reading the topics and documentations, I still cannot get the gateway up and running.
1) domo_path is the http address to reach your domoticz so http://192.168.1.50:8080
2) if on the same machine, 8080 port is already for domoticz, so starting MDAH will not be possible if the port is already binded to another application, leave 3001 here to test, and try ./start2.sh to validate it can start
epierre
Post by epierre »
hanor wrote:Hi all,
Any idea ?
ah a frenchman ;-) have you configured domo_path in config.yml ?
hanor
Post by hanor »
salut ;-)
Yes the domo_path is configured.
When I try http://my-ip:8080/devices I can see in start2.sh most of my devices.
The crash appears at the end.
Strange...
epierre
Post by epierre »
hanor wrote:salut ;-)
ok so dependencies are met.
In your browser you should access : http://192.168.1.50:3001/devices
When you say "crash" thre is a message "interface déjà utilisée" or "alrady bunded port" or something like that ?
do a "lsof -i tcp:3001 to see who's using port 3001" or a pas ax and search for an already running starman process and kill it.
on a classic system, on a port only one process can listen (aka bind), so start2.sh won't start (maybe what you call crash) if the process (started before) is already running on this port.
hanor
Post by hanor »
here what I've got :
pi@raspberrypi ~ $ sudo service MyDomoAtHome.sh stop
[ ok ] Stopping plack server: MyDomoAtHome.
pi@raspberrypi ~ $ sudo service MyDomoAtHome.sh status
[FAIL] MyDomoAtHome process is not running ... failed!
pi@raspberrypi ~ $
MyDomoAtHome service is not running --> I can start "start2.sh"
When I try http://my-ip:8080/devices I can see this message in chrome:
   "exception" : "Could not create socket: Aucun chemin d'accès pour atteindre l'hôte cible\n",
   "error" : "Could not create socket: Aucun chemin d'accès pour atteindre l'hôte cible\n"
in the shell I've got a loop with this log:
[12902] debug @1.730143> [hit #2]DBG:119:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12902] debug @1.731364> [hit #2]DBG:120:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12902] debug @1.732599> [hit #2]DBG:127:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12902] debug @1.733723> [hit #2]DBG:139:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12902] debug @1.734788> [hit #2]DBG:170:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12902] debug @1.735910> [hit #2]DBG:171:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12902] debug @1.736999> [hit #2]DBG:181:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12902] debug @1.738086> [hit #2]DBG:182:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12902] error @4.797388> [hit #2]request to GET /devices crashed: Could not create socket: Aucun chemin d'accès pour atteindre l'hôte cible in /usr/share/perl5/Dancer/Handler.pm l. 98
[12902]  core @4.803380> [hit #2]response: 500 in /usr/share/perl5/Dancer/Handler.pm l. 179
192.168.1.148 - - [20/Jan/2016:19:08:54 +0100] "GET /devices HTTP/1.1" 500 203 "-" "-"
[12903]  core @0.000965> request: GET /devices from 192.168.1.148 in /usr/share/perl5/Dancer/Handler.pm l. 56
[12903]  core @0.004109> [hit #2]Trying to match 'GET /devices' against /^\/$/ (generated from '/') in /usr/share/perl5/Dancer/Route.pm l. 84
[12903]  core @0.005811> [hit #2]Trying to match 'GET /devices' against /^\/rooms$/ (generated from '/rooms') in /usr/share/perl5/Dancer/Route.pm l. 84
[12903]  core @0.007395> [hit #2]Trying to match 'GET /devices' against /^\/system$/ (generated from '/system') in /usr/share/perl5/Dancer/Route.pm l. 84
[12903]  core @0.008908> [hit #2]Trying to match 'GET /devices' against /^\/devices\/([^\/]+)\/([^\/]+)\/histo\/([^\/]+)\/([^\/]+)$/ (generated from '/devices/:deviceId/:paramKey/histo/:startdate/:enddate') in /usr/share/perl5/Dancer/Route.pm l. 84
[12903]  core @0.010511> [hit #2]Trying to match 'GET /devices' against /^\/devices\/([^\/]+)\/action\/([^\/]+)\/?([^\/]+)?$/ (generated from '/devices/:deviceId/action/:actionName/?:actionParam?') in /usr/share/perl5/Dancer/Route.pm l. 84
[12903]  core @0.012073> [hit #2]Trying to match 'GET /devices' against /^\/devices$/ (generated from '/devices') in /usr/share/perl5/Dancer/Route.pm l. 84
[12903]  core @0.013636> [hit #2]  --> got 1 in /usr/share/perl5/Dancer/Route.pm l. 102
[12903] debug @0.016398> [hit #2]http://127.0.0.1:8080/json.htm?type=devices&filter=all&used=true&order=Name in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 410
Use of uninitialized value in concatenation (.) or string at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 435.
[12903] debug @1.430618> [hit #2]DBG:2:Scene: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.432661> [hit #2]DBG:14:Scene: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
Use of uninitialized value in concatenation (.) or string at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 860.
[12903] debug @1.435110> [hit #2]DBG:15:Scene: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.437132> [hit #2]DBG:8:Group: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.439092> [hit #2]DBG:5:Group: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.440517> [hit #2]DBG:6:Group: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.442432> [hit #2]DBG:22:Group: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.444477> [hit #2]DBG:16:Group: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.446472> [hit #2]DBG:18:Group: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.448867> [hit #2]DBG:19:Scene: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.451353> [hit #2]DBG:20:Scene: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.454035> [hit #2]DBG:17:Scene: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.456818> [hit #2]DBG:21:Scene: in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.459009> [hit #2]DBG:105:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.460447> [hit #2]DBG:106:Lighting 1:ARC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.461844> [hit #2]DBG:99:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.463318> [hit #2]DBG:9:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.464781> [hit #2]DBG:100:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.466187> [hit #2]DBG:41:Lighting 1:X10 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.467561> [hit #2]DBG:133:Lighting Limitless/Applamp:RGBW in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.469004> [hit #2]DBG:130:Lighting Limitless/Applamp:RGBW in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.470438> [hit #2]DBG:53:Lighting Limitless/Applamp:RGBW in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.471882> [hit #2]DBG:54:Lighting Limitless/Applamp:RGBW in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.473351> [hit #2]DBG:55:Lighting Limitless/Applamp:RGBW in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.474758> [hit #2]DBG:13:Lighting 1:ARC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.476114> [hit #2]DBG:166:Temp:THR128/138, THC138 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.477595> [hit #2]DBG:39:Temp + Humidity:THGN122/123, THGN132, THGR122/228/238/268 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.479070> [hit #2]DBG:11:Temp + Humidity:THGN122/123, THGN132, THGR122/228/238/268 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.480575> [hit #2]DBG:131:Lighting Limitless/Applamp:RGBW in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.482058> [hit #2]DBG:132:Lighting Limitless/Applamp:RGBW in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.483551> [hit #2]DBG:122:Lighting 1:ARC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.484963> [hit #2]DBG:33:Lighting 1:COCO GDR2 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.486350> [hit #2]DBG:121:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.487735> [hit #2]DBG:63:Lighting 1:X10 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.489113> [hit #2]DBG:29:Security:KD101 smoke detector in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.490548> [hit #2]DBG:61:Lighting 1:X10 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.491912> [hit #2]DBG:17:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.493357> [hit #2]DBG:36:Lighting 1:X10 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.494762> [hit #2]DBG:103:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.496154> [hit #2]DBG:102:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.497579> [hit #2]DBG:101:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.498983> [hit #2]DBG:16:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.500354> [hit #2]DBG:20:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.501728> [hit #2]DBG:19:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.503191> [hit #2]DBG:12:Temp + Humidity:THGN122/123, THGN132, THGR122/228/238/268 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.504720> [hit #2]DBG:115:Temp + Humidity:THGN122/123, THGN132, THGR122/228/238/268 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.506226> [hit #2]DBG:116:Temp + Humidity:THGN122/123, THGN132, THGR122/228/238/268 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.507717> [hit #2]DBG:160:Rain:PCR800 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.509164> [hit #2]DBG:24:Wind:TFA in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.510672> [hit #2]DBG:26:General:Visibility in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.512164> [hit #2]DBG:28:UV:UVN128,UV138 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.513654> [hit #2]DBG:81:General:Solar Radiation in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.515176> [hit #2]DBG:23:Temp + Humidity + Baro:THB1 - BTHR918, BTHGN129 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.516731> [hit #2]DBG:18:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.518118> [hit #2]DBG:104:General:kWh in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.519661> [hit #2]DBG:47:General:Percentage in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.521158> [hit #2]DBG:43:General:Percentage in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.522612> [hit #2]DBG:44:General:Percentage in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.524168> [hit #2]DBG:45:General:Percentage in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.525632> [hit #2]DBG:57:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.527040> [hit #2]DBG:58:Lighting 1:COCO GDR2 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.528434> [hit #2]DBG:59:Lighting 1:COCO GDR2 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.529817> [hit #2]DBG:129:Lighting 1:ARC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.531205> [hit #2]DBG:128:Lighting 1:ARC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.532578> [hit #2]DBG:40:Lighting 1:X10 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.533768> [hit #2]DBG:62:Lighting 1:X10 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.534873> [hit #2]DBG:65:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.535969> [hit #2]DBG:66:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.537042> [hit #2]DBG:67:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.538108> [hit #2]DBG:68:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.539155> [hit #2]DBG:69:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.540212> [hit #2]DBG:70:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.541271> [hit #2]DBG:71:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.542320> [hit #2]DBG:125:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.543456> [hit #2]DBG:126:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.544557> [hit #2]DBG:84:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.545615> [hit #2]DBG:135:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.546646> [hit #2]DBG:137:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.547685> [hit #2]DBG:136:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.548809> [hit #2]DBG:74:Lighting 1:X10 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.549872> [hit #2]DBG:118:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.550912> [hit #2]DBG:76:Lighting 1:X10 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.551946> [hit #2]DBG:88:Temp + Humidity + Baro:THB1 - BTHR918, BTHGN129 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.553261> [hit #2]DBG:89:Temp + Humidity + Baro:THB1 - BTHR918, BTHGN129 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.554483> [hit #2]DBG:48:Rain:WWW in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.555586> [hit #2]DBG:90:Rain:TFA in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.556676> [hit #2]DBG:97:Lighting 1:X10 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.557801> [hit #2]DBG:98:Temp:TFA 30.3133 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.559017> [hit #2]DBG:109:Air Quality:Voltcraft CO-20 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.560196> [hit #2]DBG:110:Air Quality:Voltcraft CO-20 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.561361> [hit #2]DBG:111:Air Quality:Voltcraft CO-20 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.562536> [hit #2]DBG:113:Air Quality:Voltcraft CO-20 in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.563790> [hit #2]DBG:119:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.565030> [hit #2]DBG:120:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.566174> [hit #2]DBG:127:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.567261> [hit #2]DBG:139:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.568359> [hit #2]DBG:170:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.569450> [hit #2]DBG:171:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.570531> [hit #2]DBG:181:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] debug @1.571602> [hit #2]DBG:182:Lighting 2:AC in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 435
[12903] error @4.618048> [hit #2]request to GET /devices crashed: Could not create socket: Aucun chemin d'accès pour atteindre l'hôte cible in /usr/share/perl5/Dancer/Handler.pm l. 98
[12903]  core @4.621705> [hit #2]response: 500 in /usr/share/perl5/Dancer/Handler.pm l. 179
192.168.1.148 - - [20/Jan/2016:19:09:03 +0100] "GET /devices HTTP/1.1" 500 203 "-" "-"
^C2016/01/20-19:09:07 Server closing!
result of "lsof -i tcp:3001" : empty
I killed all the starman process : no change
epierre
Post by epierre »
Where I'm puzzled is that the 8080 port is normally for proxyes, ok domoticz use it too but you should not have MDAH using it in case it is running on the same machine as domoticz.
Can you post here your config.yml please, I guess the issue is inside... (replace by xxx if passwords are in)
Drdre
Post by Drdre »
Can you help me????
same for you:
I've got the next error when I do sudo cpanm Time::Moment
pi@raspberrypi ~/domoticz/MyDomoAtHome $ sudo cpanm Time::Moment
--> Working on Time::Moment
Fetching http://www.cpan.org/authors/id/C/CH/CHA ... .37.tar.gz ... OK
Configuring Time-Moment-0.37 ... N/A
! Configure failed for Time-Moment-0.37. See /root/.cpanm/build.log for details.
Gr DrDre
hanor
Post by hanor »
epierre wrote:Can you post here your config.yml please, I guess the issue is inside... (replace by xxx if passwords are in)
--> here config.yml
# This is the main configuration file of your Dancer app
# env-related settings should go to environments/$env.yml
# all the settings in this file will be loaded at Dancer's startup.
#MyDomoAtHome specific configuration
domo_path: "http://127.0.0.1:8080"
external_url_camera : "http://ip:port/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=&pwd="
volumio_path: "192.168.1.106"
#Just the IP here assuming default port and no login/password, if void inactive
# Your application's name
appname: "MyDomoAtHome"
# The default layout to use for your application (located in
# views/layouts/main.tt)
layout: "main"
logger: 'file'
log: 'error'
# when the charset is set to UTF-8 Dancer will handle for you
# all the magic of encoding and decoding. You should not care
# about unicode within your app when this setting is set (recommended).
charset: UTF-8
engines:
    serializer:
        JSON:
            utf8: 0
serializer: 'JSON'
#template: "simple"
epierre
Post by epierre »
Drdre wrote:
epierre wrote: sudo cpanm Time::Moment
can you send me the /root/.cpanm/build.log to [email protected] so I can se and avoid polluting the forum on logs ?
thanks,
epierre
Post by epierre »
hanor wrote:Hi,
--> here config.yml
layout: "main"
logger: 'file'
log: 'error'
charset: UTF-8
engines:
    serializer:
        JSON:
            utf8: 0
serializer: 'JSON'
#template: "simple"
let's be extreme, try just this:
the MPD/volumio was a bad idea to include for where there is an issue it breaks everything, this is the way the library is done...
