Unable to control Relay With Button Actuator
postaanerik
Domoticz version: V2.423
Post by postaanerik »
I'm just beginning to work with Domoticz and MySensors.
I Build a few sensors like pressure, temp, humidity..all working fine.
With the Relay Actuator I got some difficulties to have it controlled by Domoticz. When I press the button attached to the sensor the relay switches and serial output is generated ( see logging below)
Hope anyone could help me out, some hints or a working sketch would be very appreciated!
Setup:
Domoticz 2.4231 running on a Windows machine.
Arduino Pro mini 3.3v with NRF24L01+ for Gateway and sensors with caps ( tested multiple Nrf's )
Voltage 3,3v verified on NRF
Default MySensors sketch for Serial gateway and Relay With Button Actuator
Act is disabled on the switch in Domoticz otherwise i got a error sending...
When i tick the button on the sensor, the status is updated in Domoticz
Serial output:
Gateway startup:
0;0;3;0;9;gateway started, id=0, parent=0, distance=0
0;0;3;0;14;Gateway startup complete.
Relay sensor startup:
send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
repeater started, id=0, parent=0, distance=0
send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,st=ok:Relay & Button
send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
Press the physical button on the sensor:
send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
read: 0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0:1
This is an ack from gateway
Incoming change for sensor:1, New status: 1
Press again:
send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
read: 0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0:0
Incoming change for sensor:1, New status: 0
Gateway Response when pressing the sensor button:
0;0;3;0;9;read: 0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0:1
0;0;3;0;9;send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
0;1;1;0;2;1
Press again:
0;0;3;0;9;read: 0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0:0
0;0;3;0;9;send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
0;1;1;0;2;0
Thanks in advance!
Erik
gizmocuz
Re: Unable to control Relay With Button Actuator
Post by gizmocuz »
Could you test with the MockMySensors sketch ?
postaanerik
Thanks for the quick reply.
installed the Mock.. Domoticz showing FakeMysensor v0.3 and one child: S_ARDUINO_NODE 1.5.1
Is there also a way to send info to the sensors from domoticz to test that part?
serial output of the sensor showing all device types like:
send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
sensor started, id=254, parent=0, distance=0
GW Started
Send Sketch Info: send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,st=ok:FakeMySensors
send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=4,sg=0,st=ok:v0.3
FakeMySensors v0.3
Get Config: Imperial
Presenting Nodes
________________
________________
RandomNumber:72
Send Battery Level
send: 254-254-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:72
Request Time
send: 254-254-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,st=ok:
postaanerik
Hmm good to first read the instruction...after enabling the option:
#define ID_S_LIGHT 4
it is presented in Domoticz as light switch device. Switching the light on and off in Domoticz is not changing the status of the sensor, it keeps on logging: OFF
RandomNumber:97
Send Battery Level
send: 254-254-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:97
Request Time
Light is: Off
send: 254-254-0-0 s=4,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
Boots33
Post by Boots33 »
I am also just starting out with Domoticz and Mysensors so probably not much help in diagnosing your problem. I can tell you the relay sketch is working for me. I am just switching a LED not a relay but that should make no difference I would think.
I am using 2.0.4210-7
postaanerik
Thanks for the info. are you using domoticz on a synology nas? Im using the windows version, maybe that could be causing an issue....
gizmocuz
Post by gizmocuz »
postaanerik wrote:Thanks for the info. are you using domoticz on a synology nas? Im using the windows version, maybe that could be causing an issue....
This should not matter...
postaanerik
Thanks for al the feedback, but i'm still lost, hope anyone has an idea, any help is more than welcome.
see screenshot below ( click to enlarge)
domoticz and mysensors2.jpg (262.19 KiB) Viewed 2695 times
fets
Domoticz version: 2.2969
Post by fets »
@postaanerik What is the gateway output when you click in domoticz ?
postaanerik
I actually don't know how to monitor.....using the serial gateway, so the port is used for the communication with Domoticz
fets
Post by fets »
Right not so easy to debug gateway.
In my case I use node-red. Take a look if you are interested in.
