I am new to Domoticz and to make a long story short I have a Raspberry 2 with RazBerry Z-wave module.
Everything seems to work smoothly.
The Fibaro roller shutter is the first switch to connect. It went quite easy: automatically recognized, added the fibaro switch to my dashboard, calibrated the roller shutter and it works (50%, open, close, everything).
But: when I tried to open the shutter in the morning there was simply no response. No connection between domoticz and the switch.
That same day I removed the switch from Domoticz and re-paired the it. All worked fine. But... the next morning (this morning) again the same: totally no response.
Because I am fairly new to Domoticz I was hoping somebody recognizes this behaviour and knows a solution. It's quite annoying
Thank you very much for helping!
Kind regards, WIllem.
