Fibaro Roler shutter 2 does not respond after one night
Willem81
Post by Willem81 »
Hello everyone!
I am new to Domoticz and to make a long story short I have a Raspberry 2 with RazBerry Z-wave module.
Everything seems to work smoothly.
The Fibaro roller shutter is the first switch to connect. It went quite easy: automatically recognized, added the fibaro switch to my dashboard, calibrated the roller shutter and it works (50%, open, close, everything).
But: when I tried to open the shutter in the morning there was simply no response. No connection between domoticz and the switch.
That same day I removed the switch from Domoticz and re-paired the it. All worked fine. But... the next morning (this morning) again the same: totally no response.
Because I am fairly new to Domoticz I was hoping somebody recognizes this behaviour and knows a solution. It's quite annoying :)!
Thank you very much for helping!
Kind regards, WIllem.
Willem81
Re: Fibaro Roler shutter 2 does not respond after one night
Post by Willem81 »
Update: the sensor seems to crash because of rhe android domoticz app. I just tried to use the app to set the status and afterwards the switch did not respond anymore.
After a reboot it worked fine trough web browser. I will try tomorrow if this is the issue and let you know.
jvdz
Domoticz version: 4.107
Post by jvdz »
Doubt that will be the reason.
Do you have a stable ZWAVE network with enough devices?
Jos
Willem81
Post by Willem81 »
Hi Jos!
I only have one sensor installed at the moment. Could that be the reason?
*EDIT* just checked: it does not work anymore. One hour ago it did... so the Domoticz Andoird app is not the problem.
jvdz
Post by jvdz »
Yes the issue is likely not having enough devices or to much distance between the controller and device. ZWAVE is a mesh network were all none battery power devices act as repeaters, so it normally requires a couple of devices to create a stable mesh.
Jos
