domoticz in synology as package! Available now.
jumbotroll
Post by jumbotroll »
lampje25 wrote:Hello,
I'm new on this forum.
I have a Synology DS215 with DSM 5.2-5644 Update 1.
Under community, I can see Domoticz from Jumbotroll (version 2.0.4031-7)
When i try to install then "kan "Domoticz" niet installeren"
How to resolve this?
Sorry for the bad English...
Did you activate "Any Publisher" in package senter?
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
lampje25
Post by lampje25 »
Thank you!! that was the problem!!
gevegest
Post by gevegest »
jumbotroll wrote:
cwvs wrote:Hey Jumbotroll, first of all great work!
I have been using it for quite some time now and it works great!
One thing i am realy eager to experiment with is the possibility for Homekit integration. It is already done with Domoticz (https://www.domoticz.com/wiki/Homekit_Siri) is this something that can be incorporated to the package or is there an other solution for this?
Thanks in advance!
This may be relatively much work. I must then cross compile Homekit for all the different Synology NAS (archs) and implement it when I compile domoticz , but I will see how much work it is , before I dismiss it 8-)
Jumbotroll
Hi Jumbotroll, thank you for your answer. Just to be clear i was referring to this post. Can you maybe help with another solution?
amwr
Post by amwr »
I just updated the package from 2.0.35xx to 2.0.4075-7.
Since then, Domoticz won't start anymore:
/usr/local/domoticz/bin/domoticz: error while loading shared libraries: libusb-1.0.so.0: cannot open shared object file: No such file or directory
The libs look like this:
lrwxrwxrwx    1 root     root            19 Jan 10 00:15 libusb-0.1.so.4 -> libusb-0.1.so.4.4.4
-rwxr-xr-x    1 domoticz root         27062 Jan 10 00:15 libusb-0.1.so.4.4.4
-rw-r--r--    1 domoticz root        118814 Jan 10 00:15 libusb-1.0.a
-rwxr-xr-x    1 domoticz root          1118 Jan 10 00:15 libusb-1.0.la
lrwxrwxrwx    1 root     root            19 Jan 10 00:15 libusb-1.0.so -> libusb-1.0.so.0.1.0
lrwxrwxrwx    1 root     root            19 Jan 10 00:15 libusb-1.0.so.0 -> libusb-1.0.so.0.1.0
-rw-r--r--    1 domoticz root         22314 Jan 10 00:15 libusb.a
-rwxr-xr-x    1 domoticz root          1359 Jan 10 00:15 libusb.la
lrwxrwxrwx    1 root     root            19 Jan 10 00:15 libusb.so -> libusb-0.1.so.4.4.4
What went wrong and how can I fix it?
amwr
jumbotroll
amwr wrote:Hi
amwr
Fixed in 2.0.4078-7.
Jumbotroll
Last edited by jumbotroll on Sunday 10 January 2016 16:46, edited 1 time in total.
Jumbotroll
smika
Post by smika »
Here the same problem with a 716+ synology NAS.
jumbotroll
smika wrote:Here the same problem with a 716+ synology NAS.
V2.4078 is uploaded.
Jumbotroll
Jumbotroll
smika
Post by smika »
Works perfect. Thanks for the great support.
sincze
Domoticz version: 2024.4
Post by sincze »
Did you allow the install packages from other (untrusted) communities option??
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
amwr
Post by amwr »
Jumbotroll
Works! What a great support, thanks!
dtech
Post by dtech »
Jumbotroll
Jumbotroll,
Can you please let me know if problem with battery level is fixed ?
jumbotroll
dtech wrote:
Jumbotroll
Jumbotroll,
It's fixed in V2.4088, so in next update from me, battery levels with RFXcom devices work again.
Jumbotroll
Jumbotroll
dtech
Post by dtech »
jumbotroll wrote: It's fixed in V2.4088, so in next update from me, battery levels with RFXcom devices work again.
Jumbotroll
Thank you for this info.
cherowley
Post by cherowley »
Hi!
Over the last few days I'm having the problem where the domoticz package on my sinology box stops running for no apparent reason.
I come to look at the domoticz web page but find its offline. The log doesn't show anything obvious.
It starts fine when selecting run and will continue but at some point stops again after say 10 - 30 hours.
Is there another log somewhere I can look at?
Any ideas? It was working fine until Friday ish.
I've added a couple of espeasy sensors if that makes any difference? Could they be overloading it with log entries or something?
Cheers!
gielie
Domoticz version: latest β
Post by gielie »
harrytasker wrote:Affer getting it to work i am running into a new problem.
On adding the stick from the hardware menu, i see both programmed devices that added to the stick, one a dimmer and one wall plug.
Everything fine so far. When i test both they work fine. But like 5 minutes later all the nodes go dead.
I delete the stick and add it again and the nodes work again straight away but same thing happens again, all dead nodes.
And there is no way of getting it to work again besides removing the stick from the hardware tab and adding it again.
I can choose between ttyACM0 and ttyACM1, it doesnt matter what i choose, happens on both ports.
What is strange though, i dont have to change the stick physically from the front USB port? Is that normal?
Update: I installed Domoticz on my Windows 10 PC and the stick is running fine, network health is perfect, so i guess it must be something with the installation on the NAS?
I have the same problem on my 415play, i must conclude domoticz is not working verry well on synology, maybe i have to switch to a raspberry pi.
Dit u find any solution yet?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
jumbotroll
UPDATE
Domoticz V2.4169.
New:
OpenZWave 1.4.3
Added SSL on port 8443
Added think-theme style.
Jumbotroll
truongdq54
Post by truongdq54 »
Hi jumbotroll,
Great work!
I would be very appreciated if you could post a tutorial how you compile domoticz packages on Synology.
Regards,
Truong
dtech
Post by dtech »
jumbotroll wrote:UPDATE
Domoticz V2.4169.
New:
OpenZWave 1.4.3
I can confirm that everything is working fine, no issue found. Thank you
dtech
Post by dtech »
Domoticz V2.4169.
New:
OpenZWave 1.4.3
Jumbotroll,
I already have ssl certificate on the synology, do you know how can I use it with the domoticz. If I enter domoticz with the port 8443 I got message that certyficate is not valid. On be other synology services certyfiace is valid.
jumbotroll
dtech wrote: I already have ssl certificate on the synology, do you know how can I use it with the domoticz. If I enter domoticz with the port 8443 I got message that certyficate is not valid. On be other synology services certyfiace is valid.
certificate server_cert.pem is located in the folder usr/local/domoticz.
I do not have much time to test this myself.
Jumbotroll
