Nefit Easy™
geezerrr
Nefit Easy™ client library (How to install on the Pi)
Yes I changed these locations.. But where to check the mqtt settings? I might missed that one.
- andreo
- Domoticz version: 2024.3
Re: Nefit Easy™ client library (How to install on the Pi)
Where to find enable MQTT support in Domoticz?pepijn wrote:If you place the scripts in a different location you have to edit the 'EXEC' nodes in Node-RED.
Do you have MQTT enabled on your Domoticz setup?
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Greetz Andre.
pepijn
In the hardware settings
check the wiki for more information
- Dutchsea
- Domoticz version: v2023.2
All flows import fine in the node-red on my pi except you latest. After the functions 2 unknown nodes "unknown rbe" have appearedpepijn wrote:Here is my current Node-RED flow, have fun.
[{"id":"22a46350.4b5c8c","type":"mqtt-broker","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":15,"cleansession":true,"willQos":"0","birthQos":"0"},{"id":"8b0bfef4.74f4","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-update","payload":"","payloadType":"date","repeat":"30","crontab":"","once":true,"x":210.92857360839844,"y":72.4285717010498,"wires":[["b358d0b9.4ca73"]]},{"id":"b358d0b9.4ca73","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-status","addpay":false,"append":"","useSpawn":"","name":"Nefit Status","x":366.3730163574219,"y":72.09524345397949,"wires":[["6ebefa6b.914104","5ddfad82.a22054"],[],[]]},{"id":"3876c9bf.c78936","type":"debug","z":"b83a61b3.47c5a","name":"","active":true,"console":"true","complete":"true","x":1248.1825561523438,"y":201.17855834960938,"wires":[]},{"id":"1caaaa11.e35556","type":"mqtt in","z":"b83a61b3.47c5a","name":"domoticz/out/#","topic":"domoticz/out/#","broker":"22a46350.4b5c8c","x":195.92855834960938,"y":371.4285717010498,"wires":[["577c156d.a883ec"]]},{"id":"577c156d.a883ec","type":"function","z":"b83a61b3.47c5a","name":"de-jsonify","func":"var payload = JSON.parse(msg.payload);\nreturn payload;","outputs":1,"noerr":0,"x":361.9285583496094,"y":371.4285717010498,"wires":[["342ad05e.cbd53"]]},{"id":"23467d6a.dcb982","type":"debug","z":"b83a61b3.47c5a","name":"","active":true,"console":"false","complete":"true","x":1073.1785583496094,"y":357.1785717010498,"wires":[]},{"id":"50e0c648.af1f38","type":"function","z":"b83a61b3.47c5a","name":"Get SetPoint Value","func":"msg.payload = msg.svalue1\nreturn msg;","outputs":1,"noerr":0,"x":741.1230239868164,"y":370.5118885040283,"wires":[["a97981c8.56868"]]},{"id":"342ad05e.cbd53","type":"switch","z":"b83a61b3.47c5a","name":"filter Setpoint IDX","property":"idx","rules":[{"t":"eq","v":"160"}],"checkall":"true","outputs":1,"x":540.3729858398438,"y":370.9841136932373,"wires":[["50e0c648.af1f38"]]},{"id":"a97981c8.56868","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-set","addpay":true,"append":"","useSpawn":"","name":"Nefit Set Temp","x":930.9285697937012,"y":370.17857551574707,"wires":[["23467d6a.dcb982"],[],[]]},{"id":"6440aca2.9bbf54","type":"comment","z":"b83a61b3.47c5a","name":"Read changes from Domoticz and send to Easy","info":"","x":296.9285583496094,"y":334.4285717010498,"wires":[]},{"id":"6ebefa6b.914104","type":"function","z":"b83a61b3.47c5a","name":"Domoticz MQTT","func":"// Configuration\nconst IDX_SetPoint = 160;\nconst IDX_RoomTemp = 161;\nconst IDX_Pressure = 162;\nconst IDX_StatusCode = 163;\n\n\nvar domoticz_msg = {};\ndomoticz_msg.topic = \"domoticz/in\";\ndomoticz_msg.payload = {};\n\nif (msg.topic == 'nefit-update') {\n var NefitJSON = JSON.parse(msg.payload);\n domoticz_msg.payload.idx = IDX_RoomTemp;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + NefitJSON['in house temp'];\n}\nif (msg.topic == 'nefit-pressure') {\n var NefitJSON = JSON.parse(msg.payload);\n domoticz_msg.payload.idx = IDX_Pressure;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + NefitJSON['pressure'];\n}\nif (msg.topic == 'nefit-setpoint') {\n domoticz_msg.payload.idx = IDX_SetPoint;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + msg.payload;\n}\nif (msg.topic == 'nefit-statuscode') {\n domoticz_msg.payload.idx = IDX_StatusCode;\n domoticz_msg.payload.nvalue = 0;\n domoticz_msg.payload.svalue = \"\" + msg.payload;\n}\n\nreturn domoticz_msg;","outputs":1,"noerr":0,"x":1028.4285354614258,"y":140.78571891784668,"wires":[["5bc7035e.a438fc","3876c9bf.c78936"]]},{"id":"5bc7035e.a438fc","type":"mqtt out","z":"b83a61b3.47c5a","name":"Domoticz MQTT","topic":"","qos":"","retain":"","broker":"22a46350.4b5c8c","x":1273.1785507202148,"y":142.53571319580078,"wires":[]},{"id":"2f2db332.d0d24c","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-pressure","addpay":false,"append":"","useSpawn":"","name":"Nefit Easy Pressure","x":393.9285659790039,"y":211.17857551574707,"wires":[["6ebefa6b.914104"],[],[]]},{"id":"baf3b005.450c5","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-pressure","payload":"","payloadType":"date","repeat":"300","crontab":"","once":false,"x":208.67857360839844,"y":211.17857551574707,"wires":[["2f2db332.d0d24c"]]},{"id":"2b4dca2.fd4b236","type":"comment","z":"b83a61b3.47c5a","name":"Publish data from Nefit Easy Client to Domoticz","info":"","x":289.9285583496094,"y":24.428571701049805,"wires":[]},{"id":"906bc261.6f944","type":"rbe","z":"b83a61b3.47c5a","name":"","func":"rbe","gap":"","x":794.1428527832031,"y":40.42856979370117,"wires":[["6ebefa6b.914104"]]},{"id":"5ddfad82.a22054","type":"function","z":"b83a61b3.47c5a","name":"Get Setpoint","func":"var NefitJSON = JSON.parse(msg.payload);\nmsg.topic = 'nefit-setpoint';\nmsg.payload = NefitJSON['temp setpoint'];\nreturn msg;","outputs":1,"noerr":0,"x":632,"y":40.571428298950195,"wires":[["906bc261.6f944"]]},{"id":"2296752e.dd698a","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-statuscode","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"x":200.57141876220703,"y":145.6785717010498,"wires":[["4e5066ef.b1af98"]]},{"id":"4e5066ef.b1af98","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-code","addpay":false,"append":"","useSpawn":"","name":"Nefit Status Code","x":386.1785659790039,"y":145.92857360839844,"wires":[["8e61f998.719e08"],[],[]]},{"id":"8e61f998.719e08","type":"function","z":"b83a61b3.47c5a","name":"Get Status Code","func":"var NefitJSON = JSON.parse(msg.payload);\nmsg.topic = 'nefit-statuscode';\nmsg.payload = \"\"+\"[ \"+NefitJSON['code']+\" ] \"+NefitJSON['description'];\nreturn msg;","outputs":1,"noerr":0,"x":586.4285888671875,"y":132.92857360839844,"wires":[["8553f832.7aac08"]]},{"id":"8553f832.7aac08","type":"rbe","z":"b83a61b3.47c5a","name":"","func":"rbe","gap":"","x":741.5714111328125,"y":138.14286041259766,"wires":[["6ebefa6b.914104"]]}]
Message:
"This node is a type unknown to your installation of Node-RED.
If you deploy with the node in this state, it's configuration will be preserved, but the flow will not start until the missing type is installed.
See the Info side bar for more help"
[img]Knipsel.PNG[/img]
Updating my version isnt working
~ $ sudo apt-get install nodered
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package nodered- Attachments
- Knipsel.PNG (16.86 KiB) Viewed 6213 times
Raspberry PI 3B on USB drive, Debian version: 12 (bookworm), Domoticz 2024.7
Aeon Z-Wave G5 stick, RFXCOM, Sonof Zigbee 3.0 Dongle plus E, Nefit Easy, Fritzbox, Buienradar, Sonos
- andreo
I have found itpepijn wrote:In the hardware settingscheck the wiki for more information
Greetz Andre.
Greetz Andre.
- andreo
Dutchsea wrote:All flows import fine in the node-red on my pi except you latest. After the functions 2 unknown nodes "unknown rbe" have appearedpepijn wrote:Here is my current Node-RED flow, have fun.
Message:
~ $ sudo apt-get install nodered Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package nodered
Same issue here
Greetz Andre.
Greetz Andre.
- Dutchsea
I have been looking myself but did bot find it in the Wiki or set-up page. Can you give me more hints?andreo wrote:I have found itpepijn wrote:In the hardware settingscheck the wiki for more information
thanx
- Dutchsea
More questions and a remark:
- In the scripts where I enter the Nefit serial number etc; do I replace only the xxx's and keep the double quotes or do I delete the quotes (I assumed I need have to keep the quotes)
- What permission must the scripts have? (now have rwxr-xr-x)
- In the node red input and output box the code from Pepijn shows as 127.0.0.1:1883 as IP and port. I changed this to my own Domoticz IP and port.
After the change I see these boxes in NOde-red as "disconnected" When I change it back to 127.0.0.1:1883 I see "connected" again. Should I not enter my own IP/port?
- I started with Node-red using the last version of Pepijn's code (with the erros described in my previous post). Not knowing what I am doing as I never used node-red before and all the programming knowledge I have is Pascal and 25 years ago
, I deployed this code. Next I did the same with Pepijn's code one version before the latest.
Do I now have 2 different deployments/flows running at the same time? Should I delete one somehow? Or has the latest deployment overwritten the previous flow.
Really not knowing what I am doing.......... But getting somewhere
Remark: I had to install the Nefit node module using as described on Robert Klep's page https://github.com/robertklep/nefit-easy-client
Else the "easy status" command does not work.
So the instalation described in the first post by Holland did not work for me. (CLI Tool is needed....?)
$ npm install robertklep/nefit-easy-client -g Else the "easy status" command does not work.
Holland
- Domoticz version: Beta Ch
Add the MQTT Client gateway. Give it a name , ip address 127.0.0.1 and port 1883, and you will get something like this;
2016-01-04 02:59:00.139 MQTT: Connecting to 127.0.0.1:1883
2016-01-04 02:59:00.241 MQTT: connected to: 127.0.0.1:1883
2016-01-04 02:59:00.341 MQTT: Subscribed
2016-01-04 02:59:07.669 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 02:59:37.685 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.4"}
2016-01-04 03:00:07.769 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 03:00:37.780 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.4"}
2016-01-04 03:01:07.887 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.4"}
2016-01-04 03:01:37.838 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 03:02:01.962 MQTT: Topic: domoticz/in, Message: {"idx":8,"nvalue":0,"svalue":"0.9"}
2016-01-04 03:02:07.878 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 03:02:37.947 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 03:03:08.225 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
Holland
Dutchsea,
I will try to make it a bit more clear;
Yes, keep the quotes.
This is fine. It should be executable, in your case that's the case given it includes x
127.0.0.1 is your local host ip address. But you can also use the ip address that you are referring to (prob something like 192.168... etc). But you should keep the port number equal to 1883, given that is the port number that is relevant voor MQTT.
I would remove the old flow, just to be sure
You didn't show an error message or something. But I'm guessing that you didn't jump to the bin directory in the nefit-easy-client directory
Hope this helps
Hope this helps
Holland
Pepijn,
Thanks for sharing your Node-Red flow. I have got it working now, and I'm very happy with this. Also my first project with Node red, beautiful stuff btw.
Next thing on the to do list is to retrieve more variables from the Nefit Easy Client.
dorenberg
- Domoticz version: 4.10982
here too. Updated node.js and created scripts (pepijn). Dummy sensors created. But cannot update node-red unfortunately. The nefit client is working because I saw some values when using the 3 export functions.andreo wrote:Dutchsea wrote:All flows import fine in the node-red on my pi except you latest. After the functions 2 unknown nodes "unknown rbe" have appearedpepijn wrote:Here is my current Node-RED flow, have fun.
Message:
Same issue here
pepijn
You cannot upgrade Node-RED with apt-get.
See http://nodered.org/docs/getting-started/upgrading.html
Holland
Have you tried the following?
npm update-
dorenberg
Succeeded with the node-red update using:
Node-red gives no longer the rbe error of unknown node.
However, I am getting XMPP error when executing the scripts nefit-pressure. Copy/paste the script in putty gives good results.
sudo npm cache clean
sudo npm install -g --unsafe-perm node-redHowever, I am getting XMPP error when executing the scripts nefit-pressure. Copy/paste the script in putty gives good results.
Holland
Please post the XMPP error message
dorenberg
XMPP authentication failure
this is all I can see in Putty
pepijn
This means the environment variabeles are not set correctly in the script file. Are the other scripts working oké?
dorenberg
I am getting the same error for all the scripts. Should there be more in the script than the 3 export lines and the command, so in total 4 lines? I just copy/pasted the code and saved.
pepijn
To be sure, Did you change the serial, access code and password?
