Nefit Easy™
geezerrr
Nefit Easy™ client library (How to install on the Pi)
Post by geezerrr »
Yes I changed these locations.. But where to check the mqtt settings? I might missed that one.
andreo
Domoticz version: 2024.3
Re: Nefit Easy™ client library (How to install on the Pi)
Post by andreo »
pepijn wrote:If you place the scripts in a different location you have to edit the 'EXEC' nodes in Node-RED.
Do you have MQTT enabled on your Domoticz setup?
Where to find enable MQTT support in Domoticz?
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
pepijn
Post by pepijn »
In the hardware settings :) check the wiki for more information
Dutchsea
Domoticz version: v2023.2
Post by Dutchsea »
pepijn wrote:Here is my current Node-RED flow, have fun.
[{"id":"22a46350.4b5c8c","type":"mqtt-broker","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":15,"cleansession":true,"willQos":"0","birthQos":"0"},{"id":"8b0bfef4.74f4","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-update","payload":"","payloadType":"date","repeat":"30","crontab":"","once":true,"x":210.92857360839844,"y":72.4285717010498,"wires":[["b358d0b9.4ca73"]]},{"id":"b358d0b9.4ca73","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-status","addpay":false,"append":"","useSpawn":"","name":"Nefit Status","x":366.3730163574219,"y":72.09524345397949,"wires":[["6ebefa6b.914104","5ddfad82.a22054"],[],[]]},{"id":"3876c9bf.c78936","type":"debug","z":"b83a61b3.47c5a","name":"","active":true,"console":"true","complete":"true","x":1248.1825561523438,"y":201.17855834960938,"wires":[]},{"id":"1caaaa11.e35556","type":"mqtt in","z":"b83a61b3.47c5a","name":"domoticz/out/#","topic":"domoticz/out/#","broker":"22a46350.4b5c8c","x":195.92855834960938,"y":371.4285717010498,"wires":[["577c156d.a883ec"]]},{"id":"577c156d.a883ec","type":"function","z":"b83a61b3.47c5a","name":"de-jsonify","func":"var payload = JSON.parse(msg.payload);\nreturn payload;","outputs":1,"noerr":0,"x":361.9285583496094,"y":371.4285717010498,"wires":[["342ad05e.cbd53"]]},{"id":"23467d6a.dcb982","type":"debug","z":"b83a61b3.47c5a","name":"","active":true,"console":"false","complete":"true","x":1073.1785583496094,"y":357.1785717010498,"wires":[]},{"id":"50e0c648.af1f38","type":"function","z":"b83a61b3.47c5a","name":"Get SetPoint Value","func":"msg.payload = msg.svalue1\nreturn msg;","outputs":1,"noerr":0,"x":741.1230239868164,"y":370.5118885040283,"wires":[["a97981c8.56868"]]},{"id":"342ad05e.cbd53","type":"switch","z":"b83a61b3.47c5a","name":"filter Setpoint IDX","property":"idx","rules":[{"t":"eq","v":"160"}],"checkall":"true","outputs":1,"x":540.3729858398438,"y":370.9841136932373,"wires":[["50e0c648.af1f38"]]},{"id":"a97981c8.56868","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-set","addpay":true,"append":"","useSpawn":"","name":"Nefit Set Temp","x":930.9285697937012,"y":370.17857551574707,"wires":[["23467d6a.dcb982"],[],[]]},{"id":"6440aca2.9bbf54","type":"comment","z":"b83a61b3.47c5a","name":"Read changes from Domoticz and send to Easy","info":"","x":296.9285583496094,"y":334.4285717010498,"wires":[]},{"id":"6ebefa6b.914104","type":"function","z":"b83a61b3.47c5a","name":"Domoticz MQTT","func":"// Configuration\nconst IDX_SetPoint = 160;\nconst IDX_RoomTemp = 161;\nconst IDX_Pressure = 162;\nconst IDX_StatusCode = 163;\n\n\nvar domoticz_msg = {};\ndomoticz_msg.topic = \"domoticz/in\";\ndomoticz_msg.payload = {};\n\nif (msg.topic == 'nefit-update')  {\n    var NefitJSON = JSON.parse(msg.payload);\n    domoticz_msg.payload.idx = IDX_RoomTemp;\n    domoticz_msg.payload.nvalue = 0;\n    domoticz_msg.payload.svalue = \"\" + NefitJSON['in house temp'];\n}\nif (msg.topic == 'nefit-pressure')  {\n    var NefitJSON = JSON.parse(msg.payload);\n    domoticz_msg.payload.idx = IDX_Pressure;\n    domoticz_msg.payload.nvalue = 0;\n    domoticz_msg.payload.svalue = \"\" + NefitJSON['pressure'];\n}\nif (msg.topic == 'nefit-setpoint')  {\n    domoticz_msg.payload.idx = IDX_SetPoint;\n    domoticz_msg.payload.nvalue = 0;\n    domoticz_msg.payload.svalue = \"\" + msg.payload;\n}\nif (msg.topic == 'nefit-statuscode')  {\n    domoticz_msg.payload.idx = IDX_StatusCode;\n    domoticz_msg.payload.nvalue = 0;\n    domoticz_msg.payload.svalue = \"\" + msg.payload;\n}\n\nreturn domoticz_msg;","outputs":1,"noerr":0,"x":1028.4285354614258,"y":140.78571891784668,"wires":[["5bc7035e.a438fc","3876c9bf.c78936"]]},{"id":"5bc7035e.a438fc","type":"mqtt out","z":"b83a61b3.47c5a","name":"Domoticz MQTT","topic":"","qos":"","retain":"","broker":"22a46350.4b5c8c","x":1273.1785507202148,"y":142.53571319580078,"wires":[]},{"id":"2f2db332.d0d24c","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-pressure","addpay":false,"append":"","useSpawn":"","name":"Nefit Easy Pressure","x":393.9285659790039,"y":211.17857551574707,"wires":[["6ebefa6b.914104"],[],[]]},{"id":"baf3b005.450c5","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-pressure","payload":"","payloadType":"date","repeat":"300","crontab":"","once":false,"x":208.67857360839844,"y":211.17857551574707,"wires":[["2f2db332.d0d24c"]]},{"id":"2b4dca2.fd4b236","type":"comment","z":"b83a61b3.47c5a","name":"Publish data from Nefit Easy Client to Domoticz","info":"","x":289.9285583496094,"y":24.428571701049805,"wires":[]},{"id":"906bc261.6f944","type":"rbe","z":"b83a61b3.47c5a","name":"","func":"rbe","gap":"","x":794.1428527832031,"y":40.42856979370117,"wires":[["6ebefa6b.914104"]]},{"id":"5ddfad82.a22054","type":"function","z":"b83a61b3.47c5a","name":"Get Setpoint","func":"var NefitJSON = JSON.parse(msg.payload);\nmsg.topic = 'nefit-setpoint';\nmsg.payload = NefitJSON['temp setpoint'];\nreturn msg;","outputs":1,"noerr":0,"x":632,"y":40.571428298950195,"wires":[["906bc261.6f944"]]},{"id":"2296752e.dd698a","type":"inject","z":"b83a61b3.47c5a","name":"","topic":"nefit-statuscode","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"x":200.57141876220703,"y":145.6785717010498,"wires":[["4e5066ef.b1af98"]]},{"id":"4e5066ef.b1af98","type":"exec","z":"b83a61b3.47c5a","command":"/opt/nefit/nefit-code","addpay":false,"append":"","useSpawn":"","name":"Nefit Status Code","x":386.1785659790039,"y":145.92857360839844,"wires":[["8e61f998.719e08"],[],[]]},{"id":"8e61f998.719e08","type":"function","z":"b83a61b3.47c5a","name":"Get Status Code","func":"var NefitJSON = JSON.parse(msg.payload);\nmsg.topic = 'nefit-statuscode';\nmsg.payload = \"\"+\"[ \"+NefitJSON['code']+\" ] \"+NefitJSON['description'];\nreturn msg;","outputs":1,"noerr":0,"x":586.4285888671875,"y":132.92857360839844,"wires":[["8553f832.7aac08"]]},{"id":"8553f832.7aac08","type":"rbe","z":"b83a61b3.47c5a","name":"","func":"rbe","gap":"","x":741.5714111328125,"y":138.14286041259766,"wires":[["6ebefa6b.914104"]]}]
All flows import fine in the node-red on my pi except you latest. After the functions 2 unknown nodes "unknown rbe" have appeared
Message:
"This node is a type unknown to your installation of Node-RED.
If you deploy with the node in this state, it's configuration will be preserved, but the flow will not start until the missing type is installed.
See the Info side bar for more help"
[img]Knipsel.PNG[/img]
Updating my version isnt working
 ~ $ sudo apt-get install nodered
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package nodered
Raspberry PI 3B on USB drive, Debian version: 12 (bookworm), Domoticz 2024.7
Aeon Z-Wave G5 stick, RFXCOM, Sonof Zigbee 3.0 Dongle plus E, Nefit Easy, Fritzbox, Buienradar, Sonos
andreo
Post by andreo »
pepijn wrote:In the hardware settings :) check the wiki for more information
I have found it ;) thanx
Greetz Andre.
andreo
Post by andreo »
Message:
Same issue here :cry:
Greetz Andre.
Dutchsea
Post by Dutchsea »
I have been looking myself but did bot find it in the Wiki or set-up page. Can you give me more hints?
Dutchsea
Post by Dutchsea »
More questions and a remark:
- In the scripts where I enter the Nefit serial number etc; do I replace only the xxx's and keep the double quotes or do I delete the quotes (I assumed I need have to keep the quotes)
- What permission must the scripts have? (now have rwxr-xr-x)
- In the node red input and output box the code from Pepijn shows as 127.0.0.1:1883 as IP and port. I changed this to my own Domoticz IP and port.
After the change I see these boxes in NOde-red as "disconnected" When I change it back to 127.0.0.1:1883 I see "connected" again. Should I not enter my own IP/port?
- I started with Node-red using the last version of Pepijn's code (with the erros described in my previous post). Not knowing what I am doing as I never used node-red before and all the programming knowledge I have is Pascal and 25 years ago :( , I deployed this code. Next I did the same with Pepijn's code one version before the latest.
Do I now have 2 different deployments/flows running at the same time? Should I delete one somehow? Or has the latest deployment overwritten the previous flow.
Really not knowing what I am doing.......... But getting somewhere :D
Remark: I had to install the Nefit node module using
$ npm install robertklep/nefit-easy-client -g
as described on Robert Klep's page https://github.com/robertklep/nefit-easy-client
Else the "easy status" command does not work.
So the instalation described in the first post by Holland did not work for me. (CLI Tool is needed....?)
Holland
Domoticz version: Beta Ch
Post by Holland »
Add the MQTT Client gateway. Give it a name , ip address 127.0.0.1 and port 1883, and you will get something like this;
2016-01-04 02:59:00.139 MQTT: Connecting to 127.0.0.1:1883
2016-01-04 02:59:00.241 MQTT: connected to: 127.0.0.1:1883
2016-01-04 02:59:00.341 MQTT: Subscribed
2016-01-04 02:59:07.669 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 02:59:37.685 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.4"}
2016-01-04 03:00:07.769 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 03:00:37.780 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.4"}
2016-01-04 03:01:07.887 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.4"}
2016-01-04 03:01:37.838 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 03:02:01.962 MQTT: Topic: domoticz/in, Message: {"idx":8,"nvalue":0,"svalue":"0.9"}
2016-01-04 03:02:07.878 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 03:02:37.947 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
2016-01-04 03:03:08.225 MQTT: Topic: domoticz/in, Message: {"idx":1,"nvalue":0,"svalue":"19.3"}
Holland
Post by Holland »
Dutchsea,
I will try to make it a bit more clear;
Yes, keep the quotes.
This is fine. It should be executable, in your case that's the case given it includes x
127.0.0.1 is your local host ip address. But you can also use the ip address that you are referring to (prob something like 192.168... etc). But you should keep the port number equal to 1883, given that is the port number that is relevant voor MQTT.
I would remove the old flow, just to be sure
You didn't show an error message or something. But I'm guessing that you didn't jump to the bin directory in the nefit-easy-client directory
Hope this helps
Holland
Post by Holland »
Pepijn,
Thanks for sharing your Node-Red flow. I have got it working now, and I'm very happy with this. Also my first project with Node red, beautiful stuff btw.
Next thing on the to do list is to retrieve more variables from the Nefit Easy Client.
dorenberg
Domoticz version: 4.10982
Post by dorenberg »
Message:
here too. Updated node.js and created scripts (pepijn). Dummy sensors created. But cannot update node-red unfortunately. The nefit client is working because I saw some values when using the 3 export functions.
pepijn
Post by pepijn »
You cannot upgrade Node-RED with apt-get.
See http://nodered.org/docs/getting-started/upgrading.html
Holland
Post by Holland »
Have you tried the following?
 npm update
dorenberg
Post by dorenberg »
Succeeded with the node-red update using:
sudo npm cache clean
sudo npm install -g --unsafe-perm node-red
Node-red gives no longer the rbe error of unknown node.
However, I am getting XMPP error when executing the scripts nefit-pressure. Copy/paste the script in putty gives good results.
Holland
Post by Holland »
Please post the XMPP error message
dorenberg
Post by dorenberg »
XMPP authentication failure
this is all I can see in Putty
pepijn
Post by pepijn »
This means the environment variabeles are not set correctly in the script file. Are the other scripts working oké?
dorenberg
Post by dorenberg »
I am getting the same error for all the scripts. Should there be more in the script than the 3 export lines and the command, so in total 4 lines? I just copy/pasted the code and saved.
pepijn
Post by pepijn »
To be sure, Did you change the serial, access code and password?
