Jan-
Re: Domoticz app 2.0
Post by Jan- »
RoadXY wrote:
Jango wrote:Is there a planning for solving the camera error (no image just a light bar)? I realy want to use this function.
We're thinking on disabling the camera functions because it needs a lot more work and testing than initially thought.
I hope it remains on the list with high priority :D
jannl
Domoticz version: 2025.5.x
Post by jannl »
My camera image is visible. Not checked if is also streaming.
pepeEL
Post by pepeEL »
I added next lost translation on github and found one problem with cut text when is translation
https://github.com/galadril/DomoticzFor ... issues/192
Smartie
Post by Smartie »
can you add german? or you habe a csv or xml file?
pepeEL
Post by pepeEL »
Smartie wrote:can you add german? or you habe a csv or xml file?
Go to
https://crowdin.com/project/domoticz-for-android
and start translation...
My suggestion is to add to tab temperature and tab weather text string LAST SEEN to show when is read end measurement. As is on other tabs like switches.
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
Not really high, sorry
Smartie
Post by Smartie »
Done all is Translate but not all Perfect because i dosnt konow all vars.
https://crowdin.com/project/domoticz-for-android/de
RoadXY
Post by RoadXY »
Smartie wrote:Done all is Translate but not all Perfect because i dosnt konow all vars.
Great, thanks
ben92
Post by ben92 »
Thanks for color picker .... Works fine in 0.1.207
galadril
Domoticz version: latest
Post by galadril »
ben92 wrote:Thanks for color picker .... Works fine in 0.1.207
Great!
Verstuurd vanaf mijn Nexus 5 met Tapatalk
chimit
Domoticz version: master
Post by chimit »
Great work!
pepeEL
Post by pepeEL »
I use fibaro rgbw and when turn on and then try set color...when i set on round it works ok... but slider under round do nothing... what i do wrong ?
Wysłane z mojego SM-G920F przy użyciu Tapatalka
ben92
Post by ben92 »
U must set round after.
pepeEL
Post by pepeEL »
But when i set rounder after.... then i can not set all colors because on rounder is all colors.
I found next bug. I use RFLink 433MHz and use temp sensor connected to this RFLink. In Domoticz i see graph daily from this sensor. But in app anddroid not see.
Screenshot (3 stycznia 2016 21-20).jpg (81.8 KiB) Viewed 4521 times
maluko
Post by maluko »
Now Portuguese translation is avaiable ;)
RoadXY
Post by RoadXY »
maluko wrote:Now Portuguese translation is avaiable ;)
Thank you!
barbaar
Post by barbaar »
Is there anyone else having issues with geofencing?
I currently have one geofence configured, but noticed it doesn't seem to work. The App will not always/never notice that I left de fence..
galadril
Post by galadril »
barbaar wrote:Is there anyone else having issues with geofencing?
You have location services enabled on your device??
https://support.google.com/gmm/answer/1646140?hl=en
barbaar
Post by barbaar »
Yes! Battery saving mode..
That worked okay with domofence ;)
Jango
Post by Jango »
Hello, it's raining here but in domoticz the counter stays always on 0.
I also have no graph in month data.
