I hope it remains on the list with high priorityRoadXY wrote:We're thinking on disabling the camera functions because it needs a lot more work and testing than initially thought.Jango wrote:Is there a planning for solving the camera error (no image just a light bar)? I realy want to use this function.
Jan-
Re: Domoticz app 2.0
jannl
- Domoticz version: 2025.5.x
My camera image is visible. Not checked if is also streaming.
pepeEL
I added next lost translation on github and found one problem with cut text when is translation
https://github.com/galadril/DomoticzFor ... issues/192
Smartie
can you add german? or you habe a csv or xml file?
pepeEL
Go toSmartie wrote:can you add german? or you habe a csv or xml file?
https://crowdin.com/project/domoticz-for-android
and start translation...
My suggestion is to add to tab temperature and tab weather text string LAST SEEN to show when is read end measurement. As is on other tabs like switches.
- RoadXY
- Domoticz version: 2.2331
Not really high, sorryJan- wrote:I hope it remains on the list with high priorityRoadXY wrote:We're thinking on disabling the camera functions because it needs a lot more work and testing than initially thought.Jango wrote:Is there a planning for solving the camera error (no image just a light bar)? I realy want to use this function.
Smartie
Done all is Translate but not all Perfect because i dosnt konow all vars.
https://crowdin.com/project/domoticz-for-android/de
- RoadXY
Great, thanksSmartie wrote:Done all is Translate but not all Perfect because i dosnt konow all vars.
ben92
Thanks for color picker .... Works fine in 0.1.207
- galadril
- Domoticz version: latest
Great!ben92 wrote:Thanks for color picker .... Works fine in 0.1.207
Verstuurd vanaf mijn Nexus 5 met Tapatalk
- chimit
- Domoticz version: master
Great work!
pepeEL
I use fibaro rgbw and when turn on and then try set color...when i set on round it works ok... but slider under round do nothing... what i do wrong ?
Wysłane z mojego SM-G920F przy użyciu Tapatalka
ben92
U must set round after.
pepeEL
But when i set rounder after.... then i can not set all colors because on rounder is all colors.
I found next bug. I use RFLink 433MHz and use temp sensor connected to this RFLink. In Domoticz i see graph daily from this sensor. But in app anddroid not see. Wysłane z mojego SM-G920F przy użyciu Tapatalka
maluko
Now Portuguese translation is avaiable
- RoadXY
Thank you!maluko wrote:Now Portuguese translation is avaiable
barbaar
Is there anyone else having issues with geofencing?
I currently have one geofence configured, but noticed it doesn't seem to work. The App will not always/never notice that I left de fence..
- galadril
You have location services enabled on your device??barbaar wrote:Is there anyone else having issues with geofencing?
https://support.google.com/gmm/answer/1646140?hl=en
barbaar
Yes! Battery saving mode..galadril wrote:You have location services enabled on your device??barbaar wrote:Is there anyone else having issues with geofencing?
That worked okay with domofence
Jango
Hello, it's raining here but in domoticz the counter stays always on 0.
I also have no graph in month data.
