Idiots guide to Raspberry Pi Installation
TheBod
Hi all
I apologise if this has been asked a thousand times before.
I am trying to install Domoticz onto my Raspberry Pi2. Using my Windows desktop I have downloaded the Pi image file from the Sourceforge website (http://sourceforge.net/projects/domotic ... p_redirect) and copied the image to a 8GB micro SD card. With the SD card inserted in the Pi2 I have booted up and get to the Pi and Raspberry login request. Following login I do CD Domoticz and then ./Domoticz.
At this point I receive the following error message;
"Error: Failed to start the web server: bind: Address already in use
Error: check if no other application is using port: 8080"
I have tried the Pi2 both connected to my LAN and without and always receive the same message. As far as I am aware there is nothing else running on the Pi and therefore nothing using 8080. An online suggestion was to run "./domoticz -www 8090 -sslwww 8091" but this still does not work.
Am I using the correct image file? I am planning on installing my RFXcom433 to the Pi to control my many 433 devices at home.
Could someone point me in the correct direction for an easy installation please.
Thanks in advance
TheBod
Thanks in advance
TheBod
- jvdz
- Domoticz version: 4.107
Re: Idiots guide to Raspberry Pi Installation
Are you sure that domoticz isn't already running?
Just check with: sudo ps x|grep domoticz
Jos
Jos
TheBod
Hi Jos
Thanks for your reply. I have tried
and get the response shown in the attached (2032 ? Ssl 0:00 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443)
Any ideas?
The Bod
Any ideas?
The Bod
- Screenshot of Pi2 response
- IMG_8286.JPG (138.15 KiB) Viewed 5563 times
- jvdz
So that means it is running already
Have you tried opening the Domoticz website from your PC's browser: http://rapsberry.ip.address:8080 ?
Jos
Jos
TheBod
Ah, I have just realised something that may be important. I am running Domoticz already on my windows PC (http://127.0.0.1:8080/#/Dashboard). Is this causing the issue?
- jvdz
That should be no issue. just try opening the Raspberry's domoticz website from your PC with the correct IP address you gave to the Raspberry.TheBod wrote:Ah, I have just realised something that may be important. I am running Domoticz already on my windows PC (http://127.0.0.1:8080/#/Dashboard). Is this causing the issue?
Jos
TheBod
Update: I have closed down Chrome on the pc, which was running Domoticz, and tried ./Domoticz on the Pi2 but still get the same message
TheBod
Silly question, how do i find the raspberry's IP address?jvdz wrote:That should be no issue. just try opening the Raspberry's domoticz website from your PC with the correct IP address you gave to the Raspberry.TheBod wrote:Ah, I have just realised something that may be important. I am running Domoticz already on my windows PC (http://127.0.0.1:8080/#/Dashboard). Is this causing the issue?
Jos
- Westcott
Another idiot here...
I'm just about to get my first pi and use it rather than Windows.
My question is: where do you get your pi image files from?
I can't see any on http://sourceforge.net/projects/domotic ... p_redirect, just Windows installers.
- jvdz
Seems you are a little confused here.
Domoticz starts automatically on your raspberry so trying to run it again will obviously fail!
Did you try connection to your raspberry from your windows pc with http://192.168.x.x:8080 (and fill in the ip address you gave the raspberry!)
Jos
Jos
- jvdz
Ah ... you haven't set that yet.TheBod wrote: Silly question, how do i find the raspberry's IP address?
Just follow the Wiki: http://www.domoticz.com/wiki/Domoticz_R ... i_SD_Image
Jos
TheBod
Jos
This is what I get when i do ifconfig
Does this mean that the ip address is 192.168.1.255?
- IMG_8287.JPG (120.56 KiB) Viewed 5522 times
- jvdz
Nah, 192,168.1.129
TheBod
Success. On the windows pc it now loads up Domoticz.
How do I run this on the Pi2 so that I can connect the RFXcom433 and get started?
- Westcott
Thanks, but that also only has Windows setup files.
TheBod
This is what I get
- Capture.PNG (148.44 KiB) Viewed 5519 times
- jvdz
Not sure I understand that question. You are running Domoticz on the RPI when you connect from your windows pc to http://192.168.1.129:8080 !
Just connect your RFXcom433 to one of the USB ports of the RPI and you should be in business (might have to restart Domoticz)
Jos
Jos
- jvdz
Just follow the Wiki i linked in one of the previous posts, which also has the info for the RPI image.Westcott wrote: Thanks, but that also only has Windows setup files.
Jos
TheBod
Thank you very much Jos. Ever so sorry for being really stupid with this. Pi and Linux is new to me. Graet to have experts like you available.
