Re: Domoticz app 2.0
well done, great app. I got to know about it from the tweakers home page. Bought it right away.
I have been involved and contributed to Domoticz in the past but kinda lost interest. Now with the new app I might pickup the hobby. Using the smart phone to control the home also makes a lot of sense.
Lot's of future opportunities as well, like integration with android tv (nvidia shield) and speech control. Looking forward to support you.
peterk
Can anyone explain how I can associate a switch to a geofenced location?
In de "Add Location" dialog there is no field to enter a switch name or id.
And after a location has been added, the location info shows "Connected switch: N/A".
Thanks,
Peter.
Thanks,
Peter.
Domoticz V2.3530 on RPi 2B, P1 Smart Meter, OpenTherm gateway, RFXtrx433 (KiKa, temp sensors)
Jango
Is there a planning for solving the camera error (no image just a light bar)? I realy want to use this function.
kurniawan77
Long press to configurepeterk wrote:Can anyone explain how I can associate a switch to a geofenced location?
Thanks,
Peter.
. A suggestion for the app, maybe handy to reconfigure the distance too
- RoadXY
- Domoticz version: 2.2331
Is done by Android automatically.pepeEL wrote:I have a question. I see tat multilanguage will be add... But in menu settings will be available option set language ? I think that will be a good features to user can set language in menu settings... Can set own language or maybe other language
Option maybe later, maybe not.
pepeEL
Please add to your list.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
jvandenbroek
Just updated, but unfortunately it now crashes on start up. Sent the crash log.
Sent from my SM-N9005 with Tapatalk
- RoadXY
Yes, editing the current geofences is on the listkurniawan77 wrote:Long press to configurepeterk wrote:Can anyone explain how I can associate a switch to a geofenced location?
Thanks,
Peter..
- RoadXY
We're thinking on disabling the camera functions because it needs a lot more work and testing than initially thought.Jango wrote:Is there a planning for solving the camera error (no image just a light bar)? I realy want to use this function.
- RoadXY
Both are on our list.maxtrash wrote:well done, great app. I got to know about it from the tweakers home page. Bought it right away.
You can help if you like?
Github URL is post 1
Jango
I understand, thank you for your reply.RoadXY wrote:We're thinking on disabling the camera functions because it needs a lot more work and testing than initially thought.Jango wrote:Is there a planning for solving the camera error (no image just a light bar)? I realy want to use this function.
Yihaaa
I just updated the app on my N7 and crashes immediately on start-up. Hope this can be solved asap.
pepeEL
Clean memory app and again configure.i also has the same problem but probably that to app was added translation. After clean and again config now works ok but has bugs which i describe on github as issue.
Jango
No crashes here on Xperia z5.
Yihaaa
Thanks for the tip. That did the trick and the app works again.pepeEL wrote:Clean memory app and again configure.i also has the same problem but probably that to app was added translation. After clean and again config now works ok but has bugs which i describe on github as issue.
pepeEL
Lost translation and wrond padding buttons on dashborad.
https://github.com/galadril/DomoticzFor ... issues/192
- RoadXY
pepeEL is right: it has to do with the translation.Yihaaa wrote:I just updated the app on my N7 andere crashes immediately on start-up. Hope this van be solved asap.
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Currently working on a fix and will create an update asap
- RoadXY
Thank you, we'll look into it.pepeEL wrote:Lost translation and wrond padding buttons on dashborad.
pepeEL
Thanx. All is good job and very good job
jvandenbroek
Thanks, fixed it for me as wellpepeEL wrote:Clean memory app and again configure.i also has the same problem but probably that to app was added translation. After clean and again config now works ok but has bugs which i describe on github as issue.
