maxtrash
Re: Domoticz app 2.0
Post by maxtrash »
well done, great app. I got to know about it from the tweakers home page. Bought it right away.
I have been involved and contributed to Domoticz in the past but kinda lost interest. Now with the new app I might pickup the hobby. Using the smart phone to control the home also makes a lot of sense.
Lot's of future opportunities as well, like integration with android tv (nvidia shield) and speech control. Looking forward to support you.
peterk
Post by peterk »
Can anyone explain how I can associate a switch to a geofenced location?
In de "Add Location" dialog there is no field to enter a switch name or id.
And after a location has been added, the location info shows "Connected switch: N/A".
Thanks,
Peter.
Domoticz V2.3530 on RPi 2B, P1 Smart Meter, OpenTherm gateway, RFXtrx433 (KiKa, temp sensors)
Jango
Post by Jango »
Is there a planning for solving the camera error (no image just a light bar)? I realy want to use this function.
kurniawan77
Post by kurniawan77 »
peterk wrote:Can anyone explain how I can associate a switch to a geofenced location?
Thanks,
Peter.
Long press to configureImage.
A suggestion for the app, maybe handy to reconfigure the distance too
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
pepeEL wrote:I have a question. I see tat multilanguage will be add... But in menu settings will be available option set language ? I think that will be a good features to user can set language in menu settings... Can set own language or maybe other language :)
Is done by Android automatically.
Option maybe later, maybe not.
pepeEL
Post by pepeEL »
Please add to your list.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
jvandenbroek
Post by jvandenbroek »
Just updated, but unfortunately it now crashes on start up. Sent the crash log.
Sent from my SM-N9005 with Tapatalk
RoadXY
Post by RoadXY »
Thanks,
Peter.
Yes, editing the current geofences is on the list
RoadXY
Post by RoadXY »
Jango wrote:Is there a planning for solving the camera error (no image just a light bar)? I realy want to use this function.
We're thinking on disabling the camera functions because it needs a lot more work and testing than initially thought.
RoadXY
Post by RoadXY »
maxtrash wrote:well done, great app. I got to know about it from the tweakers home page. Bought it right away.
Both are on our list.
You can help if you like?
Github URL is post 1
Jango
Post by Jango »
I understand, thank you for your reply.
Yihaaa
Post by Yihaaa »
I just updated the app on my N7 and crashes immediately on start-up. Hope this can be solved asap.
pepeEL
Post by pepeEL »
Clean memory app and again configure.i also has the same problem but probably that to app was added translation. After clean and again config now works ok but has bugs which i describe on github as issue.
Jango
Post by Jango »
No crashes here on Xperia z5.
Yihaaa
Post by Yihaaa »
pepeEL wrote:Clean memory app and again configure.i also has the same problem but probably that to app was added translation. After clean and again config now works ok but has bugs which i describe on github as issue.
Thanks for the tip. That did the trick and the app works again.
pepeEL
Post by pepeEL »
Lost translation and wrond padding buttons on dashborad.
https://github.com/galadril/DomoticzFor ... issues/192
RoadXY
Post by RoadXY »
Yihaaa wrote:I just updated the app on my N7 andere crashes immediately on start-up. Hope this van be solved asap.
Verstuurd vanaf mijn Nexus 7 met Tapatalk
pepeEL is right: it has to do with the translation.
Currently working on a fix and will create an update asap
RoadXY
Post by RoadXY »
pepeEL wrote:Lost translation and wrond padding buttons on dashborad.
Thank you, we'll look into it.
pepeEL
Post by pepeEL »
Thanx. All is good job and very good job
jvandenbroek
Thanks, fixed it for me as well Image
