pepeEL
Re: Domoticz app 2.0
Galadril is any chance to also change size slider for dimmer switches ?
Wysłane z mojego SM-G920F przy użyciu Tapatalka
- RoadXY
- Domoticz version: 2.2331
The slider is standard Android.pepeEL wrote:But can you chnge size slider for dimmer switches ?galadril wrote:I've added this to the list (lower prio...)pepeEL wrote:Maybe good option is also add to settings features to enable dark theme ? User would set light or dark theme.
I'll test
pepeEL
But for some switches is bigger but for some is very small...
ThinkPad
pepeEL, i understand that you like the app. But since yesterday you have placed at least 16 messages/requests in this topic.pepeEL wrote:But for some switches is bigger but for some is very small...
It would be nice if you could slow down a bit. This allows the developers to do their work. Stuff like themes etc are less important, the app has just been released and you are asking for new features like crazy
And please disable the signature option in your Tapatalk app, as this adds unneeded garbage in each of your posts
Look at the picture i posted earlier. This is problably what he is talking about. It's a bugThinkPad wrote:pepeEL, i understand that you like the app. But since yesterday you have placed at least 16 messages/requests in this topic.pepeEL wrote:But for some switches is bigger but for some is very small...
It would be nice if you could slow down a bit. This allows the developers to do their work. Stuff like themes etc are less important, the app has just been released and you are asking for new features like crazy![]()
- RoadXY
Re: Fibaro dimmer 2, a new bug
Thank you for your screenshot!ehallq wrote:So I have multiple fibaro dimmer 2 devices. 1 of them shows up correctly, but the other two have a very short slider due to the "set level" and "level" output of data.
EDIT: Now all of the devices shows up with a short slider. First the slider is long for 0.5 sec, but then Set level: and Level: popup under the data line and the slider gets very short.
That really helped understanding.
We'll fix this.
- RoadXY
I really wish you posted an screenshot on your first request.pepeEL wrote:But for some switches is bigger but for some is very small...
It would have been solved by now if you did...
Another bug
Hope you don't mind me posting all this bugs I find. I really like your work, I only want to make it even better
When dimming my fibaro dimmer 2, I get a response of the dimming value set to +1 over the actual value (if i dim to 100%, the message says 101., 53 gets 54 etc.) If I then turn it off with the button, and then on again with the button I would want it to set to the last value or full, as for now the app shows a random percentage each time turning on and off (using the button, not the slider).
EDIT: when reopening the app after turning the fibaro dimmer 2 on with the button, the percentage shown is 255.
The button i am talking about is the button below the dimmer, not the actual physical button
- RoadXY
Re: Another bug
No, no problem at all!ehallq wrote:Hope you don't mind me posting all this bugs I find. I really like your work, I only want to make it even better
We'll see if we can replicate your issue!
Jango
Thank you all for the improvements in version 0.1.203
Verstuurd vanaf mijn E6853 met Tapatalk
Thermostat
I found a bug in the app for the thermostat.
Clicking the + for a thermostat will increase the temp with 1 degree.
Clicking on the - will decrease the temperature with 0.5 degrees, only the first time. After the first time the temperature gets decreased with 1 degree.
Pressing multiple times on the + does not work either.
It is probably caused by the Set Point. The Set point only shows integers.
Regards,
Bryan
btw Great app
Regards,
Bryan
btw Great app
pepeEL
I found next bug. When i set my dimmer switch on device show example 48% but in info on bottom page show always one more: example 49%. Look on screen.
Slider is to small and i think that good option is move slider button under text LAST SEEN. Maybe in this place would be large size. Look on screen as show on my Galaxy S6:
SweetPants
@pepeEl, please slow down, give the guys that develop the app some time. Or better, install Android Studio pull the source from github and help them solve the bugs.
@devs, great app, keep up the good work
Jango
The width of the dimmer slider varies. I have seen them very small to a larger slider which is easier to set.
Jango
Oeps double post, sorry.
pepeEL
But dev please me on screen...SweetPants wrote:@pepeEl, please slow down, give the guys that develop the app some time. Or better, install Android Studio pull the source from github and help them solve the bugs.
swedenhans
First -> Thanks for a great app, bought premium 1st second...
1 problem: I don´t manage to get the cameras to work in the app. Not local connection or remote connection. How is it meant to work? Saw another question about maybe external and internal ip link?! Debug says ok. Cameratype D-link 935, Could it be the request "user:password@IP:port/cgi/jpg/image.cgi" that somehow struggling?
Cameras works great internal/external through web.
See Debug below:
Connection OK
- Result: [CameraInfo{idx=1, Name='Vardagsrum NV', Address='192.168.1.101', ImageURL='cgi/jpg/image.cgi, Port='80, Username='X, Password='X, FullURL='http://X:[email protected]:80/cgi/jpg/image.cgi, Enabled=true'}, CameraInfo{idx=2, Name='Vardagsrum OV', Address='192.168.1.100', ImageURL='cgi/jpg/image.cgi, Port='80, Username='X, Password='X, FullURL='http://X:[email protected]:80/cgi/jpg/image.cgi, Enabled=true'}]
2 question: The security alarm panel -> any thoughts about that one?
Thanks for the good work!
//Hans
See Debug below:
Connection OK
//Hans
Agrippa
Sorry to give my post a kick, but other than peppeEL's posts there seems no reaction on this issue at all:Agrippa wrote:I'm still on the lite vershion, trying to see how 'zonnescherm' (reverse blinds) can be paused halfway..
Nevertheless: Goed werk!
The (revers) blinds buttons can´t be paused half way. It means if you want to use this for a sunscreen one can not have the screen to be paused halfway, or therefore, at any position of the screen at all.
Now you devolpers might allready work on it, but I didn´t find it here and didn´t see it on the update...
- remb0
we are taking all the issues serious. we copy them and prioritize.
all bugs must be fixed is the motto. wishes are mostly for the next version..
so thanks for reporting and keep reports coming!
and as always as extensively as possible: version number, premium/free, OS version, device info, and how to reproduce..
