watermeter Elster V200 PR6P:1
cwavontuur
- Target OS: -
Is there anyone who has been trying to get his watermeter smartly metered.
Type: Elster V200 PR6P:1
What kind of sensor have you used?
And what kind of setup have you chosen?
My thoughts are on using Raspberry PI with PIFace.
Many thanks in advance for your feedback,
Brgds
Cwavontuur
Brgds
Cwavontuur
Peter112
Re: watermeter Elster V200 PR6P:1
RaspberryPI domoticz, test server Intel Atom 230 dual core @1,6 GhzW7-32bit domoticz Test,RFXtrx433 USB, Kaku ,OWL
cwavontuur
- Target OS: -
Great.
That sensor should be fitting my watermeter.
Have been trying to find one for some time,
many thanks,
cwavontuur
many thanks,
cwavontuur
- Keptenkurk
- Target OS: -
Wow, you can buy lots of water for that...
I will first try to see if this el cheapo sensor is able to sense the half moon metal disc in the Elster. It'll take a few weeks but will report results in this thread.
/paul
/paul
cwavontuur
- Target OS: -
Thanks Guy's
This discussion is getting more interesting by the minute.
We now know what the royal / expensive way forward will cost
and possibly a solution through a cheaper alternative sensor.
I haven't given up on my lowpowerlab.com ee-sy310 breakout, but so far haven't been able to get it switching.
And that should be the starting point.
This evening one of my friends is coming over to give it a final try.
Brgds
cwavontuur
Brgds
cwavontuur
Peter112
watermeters with possibility to interface with other systems are most diveded in two
1 Reedcontact reedcontact ex
In the watermeter there is small magnet mounted wich activates the reedswitch ( for small meters most 1L/Pulse)
2 proximity sensor Proximity sensor
(picture example proximity sensor on my gasmeter KromSchroder)
Proximity sensor react on metals
The goal is to find out what system elster V200 uses
cwavontuur
- Target OS: -
Yesterday's discussion with my friends led to the conclusion that most likely the lowpowerlab.com ee-sy310 breakout is dead
aka I must have done something wrong to blow up the component or it arrived busted.
Never mind.
To add to the discussion on Reed or proximity - contact.
I have added a photo of a part of my watermeter with the metal element.
Are there any firm conclusions to be drawn from this photo?
Brgds
Cwavontuur
Never mind.
Brgds
Cwavontuur
- watermeter detail
- elster watermeter detail 3.png (146.71 KiB) Viewed 21843 times
- Keptenkurk
- Target OS: -
At least that's the same as mine! I tried my CNY70 sensor to detect the metal disc but the cny70 only does a good job at black/white detection. It served well measuring electricity until i had a smart meter installed with P1 cable to have the gas usage also monitored.
If the metal disc would be magnetic the reed contact proposed below would be the cheapest solution of all!
/paul
/paul
Peter112
You could try with a small piece of iron hanging on sewing-thread to see if it moves as the meter is counting water.
If it is magnetic you vcan buy a reed switch http://www.produktinfo.conrad.com/daten ... _313_3.pdf or http://www.produktinfo.conrad.com/daten ... _10_VA.pdf
cwavontuur
- Target OS: -
Hi Guys
This morning held a little compass to the turning metal part but observed no reaction what so ever.
The specs mention magnet free communication interface.
specs http://www.elster.nl/downloads/V200V210 ... Engels.pdf
So I doubt the metal item is magnetic.
Brgds
cwavontuur
Brgds
cwavontuur
alfred_j_kwak
- Domoticz version: 2.3530
I suppose that you could consider inductive sensor. http://en.wikipedia.org/wiki/Inductive_sensor
Maybe something like this: https://www.distrelec.nl/elfa3~nl_nl/el ... 7-21&cat=0
Problem with inductive sensor could be power supply and voltage levels (usually 24VDC).
You also need to know distance between sensor and metal disk in your meter.
-Jussi-
-Jussi-
- Keptenkurk
- Target OS: -
Right Jussi, that's what i'll try when the thing arrives from China
Reading more about the Elster interface: it's seems to be targeted to remote metering by the water supplier company (supports backward flow, tampering signalling etc). Therefore i think that a simple reflector or inductive senor will do for our purpose.
/paul
/paul
Peter112
http://www.ia.omron.com/products/family ... ation.html ( check the sensing distance 0 to 1.9 mm with the elster) or something like this with more sensing distance http://www.ia.omron.com/products/family ... ation.html
these function on 12 Volts, the output can be reduced with resistors to match your circuit for 5 or 3,3 volt
alfred_j_kwak
Yes and this works with 5 VDC. http://www.newark.com/telemecanique-sen ... dp/16B3571Peter112 wrote:http://www.ia.omron.com/products/family ... ation.html ( check the sensing distance 0 to 1.9 mm with the elster) or something like this with more sensing distance
I just want to point out, that one should pay attention when selecting sensor. Also those special voltage sensors could be expensive.
24VDC sensors could also be found as used devices.
-Jussi-
cwavontuur
- Target OS: -
Hi Guy's
Am I correct in concluding that the alternatives to the Falcon PR6 are not that easily picked?
Brgds
cwavontuur
Brgds
cwavontuur
alfred_j_kwak
If you like to have something that snaps right on your watermeter - then yes.
-Jussi-
-Jussi-
- Keptenkurk
- Target OS: -
Today, to my surprise, the USD 7,99 metal sensor from China arrived by airmail (only took them 12 days!).
Luckily the specs are printed on the device because they differ way from the specs on the dx.com website.
This one has a three wire connection 6..36V DC and NPN (instead of 5~36V PNP) but also detects metal within 4mm.
It's an "OMOHON" device
(yes: sounds like ... see posts below).
Quickly hooked it up to a 5.4V supply. Because it has a LED on the back, detection is simply visible without connecting it up to the PiFace yet. The LED lits up faintly when metal is near and power consumption for the device itself is only 0,4mA.
Then the big test: will it detect the Elster disc? === IT DOES === !!
When pushing the sensor against the meter window a nice pulse is provided when the disc passes by.
At 12V DC it draws a mere 4 mA and the LED lits nicely. So probably the 5V from the raspberry will not be enough.
Next will be to build a construction which keeps the sensor in place and a small circuit to adjust the output to the PiFace levels.
...to be continued...
/paul
/paul
Thanks for reporting. Sound promising ! Il have a similar water counter (aquadis) that works with a similar standardized pulse detector. Wating for your investigations
- Keptenkurk
- Target OS: -
Today i mounted and connected the proximity sensor and got it all working.
So now we are singing "Let it flow, let it flow, let it flow"
Merry Christmas to you all and a big THANK YOU to all involved with Domoticz.
/paul
EDIT: Changed the schematic to use a reed relay instead of the 2N7000 Mosfet
/paul
Last edited by Keptenkurk on Saturday 28 December 2013 20:38, edited 1 time in total.
- mbliek
Do you mind too write a how to?
Would like to have something like this.
Op zoek naar een Domoticz Start Set?
