sensor stopped working after reboot, node sleeping?
Evelen
Domoticz version: 2.4538
Post by Evelen »
Ok, So I Added my 2. Z-Wave device to Domoticz, worked fine until I rebooted the system, now I can se the LED on the motionsensor is blinking if i am in front of it, but the "switsh" in domoticz don't turn on anymore.
How to I fix thix?
I Can see the device have a moon logo:
Uten navn.png (191.79 KiB) Viewed 2107 times
Enabled Polling (whatever that is), still don't work
Evelen
Re: sensor stopped working after reboot, node sleeping?
Post by Evelen »
Now the status-logo has changed to the normal "v", but the sensor still don't work.
Not even the LED on the sensor.
EDIT: these two is the same physical, still "last Seen" is 2h late on the sensor-part
Uten navn.png (49.4 KiB) Viewed 2095 times
Evelen
Post by Evelen »
ok, so i removed the node and added it again.
worked, until reboot.. :(
Evelen
Post by Evelen »
ramesses
Domoticz version: 3.8755
Post by ramesses »
Hi Evelen,
first of all update to newest version 2.3790. To do that you must enable beta updates (In Setup|Application settings tick "Check for Updates" and select Beta channel).
Exclude PIR and include again. Then send here a devices list (Setup>Devices).
Polling should be disabled for this device. More info here or here.
I have the same PIR too and it detects motion well. Works after restart as well.
Domoticz on RaZberry, OZW 1.4-2713
Aeotec MultiSensor 6, Aeotec LED Bulb, Vision ZD2102 Door/Window Sensor, Vision ZP3102 PIR Motion Sensor, D-Link Siren DCH-Z510, Fibaro Smoke Sensor FGSD002, Aeotec Key Fob, Qubino ZMNHDD1 Z-Wave Plus Flush Dimmer
Evelen
Post by Evelen »
Hi and thank you for the answer.
I have the version: 2.3596 (last beta?) Linux.
Domoticz say no (beta) update available.
Anyway, i Included the sensor "secure" yesterday, worked and then don't worked.
however it worked this morning and when i come home now.
So i guess i Just have to wait and see if it is stable.
(last seen time don't update unless it is motion though)
btw, what is the diffrence between secure and non secure node inklude??
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
I was having the same issue. The solution was to get a wall plug to extend the range from my razberry.
My nodes works perfectly since I bought the wall plug.
Sent from space using an app.
