Hi to all, someone can point me how can i code a telegrambot for running shell scripts on rpi?
Tkanks in advanced
Telegrambot shell scripts
- Egregius
- Domoticz version: v2024.7
Re: Telegrambot shell scripts
Are you sure you want that?
In my opinion there's no security in a bot.
A bot is excellent for notifications, not for actions.
I would consider a webpage with authentication and protection for execution of a script.
carlostkd
Hi thanks for the answer, but i mean preconfigured shell scripts by myself with defined commands, and only that scripts can be runned.
- jvdz
- Domoticz version: 4.107
Why do you state there is no security in DTGBOT?Egregius wrote:Are you sure you want that?
It has the ability to whitelist only selected senders ID's, so should be pretty safe.
Jos
- jvdz
Why not simply do JSON call to operate Domoticz in a script?carlostkd wrote:Hi thanks for the answer, but i mean preconfigured shell scripts by myself with defined commands, and only that scripts can be runned.
Jos
carlostkd
jvdz wrote:Why not simply do JSON call to operate Domoticz in a script?carlostkd wrote:Hi thanks for the answer, but i mean preconfigured shell scripts by myself with defined commands, and only that scripts can be runned.
Jos
because my programming skills are very basic, if thou can give me the code for the execution of scripts i will be grateful.
Thanks in advanced
- Egregius
TS mentioned telegram bot, didn't think of DTGBOT, sorry for the misunderstanding then.jvdz wrote: Why do you state there is no security in DTGBOT?
