Telegrambot shell scripts
carlostkd
Post by carlostkd »
Hi to all, someone can point me how can i code a telegrambot for running shell scripts on rpi?
Tkanks in advanced
Egregius
Domoticz version: v2024.7
Re: Telegrambot shell scripts
Post by Egregius »
Are you sure you want that?
In my opinion there's no security in a bot.
A bot is excellent for notifications, not for actions.
I would consider a webpage with authentication and protection for execution of a script.
carlostkd
Post by carlostkd »
Hi thanks for the answer, but i mean preconfigured shell scripts by myself with defined commands, and only that scripts can be runned.
jvdz
Domoticz version: 4.107
Post by jvdz »
Egregius wrote:Are you sure you want that?
Why do you state there is no security in DTGBOT?
It has the ability to whitelist only selected senders ID's, so should be pretty safe.
Jos
jvdz
Post by jvdz »
carlostkd wrote:Hi thanks for the answer, but i mean preconfigured shell scripts by myself with defined commands, and only that scripts can be runned.
Why not simply do JSON call to operate Domoticz in a script?
Jos
carlostkd
Post by carlostkd »
Jos
because my programming skills are very basic, if thou can give me the code for the execution of scripts i will be grateful.
Thanks in advanced
jvdz
Post by jvdz »
It is all explained in the JSON WiKi: https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's
Jos
Egregius
Post by Egregius »
jvdz wrote: Why do you state there is no security in DTGBOT?
TS mentioned telegram bot, didn't think of DTGBOT, sorry for the misunderstanding then.
