Roller shutter group event coming from inside the group
Barberousse
Post by Barberousse »
I have several roller shutter in a group (Zwave Cubino ZMNHCD). I would like one of the shutter of this group to open the whole group when up button is pressed. How to achieve this? I don't understand how to add the button as group activation device. I tried blocky script (if shutter_room1 = Open do set group shutter_room_1st_floor = On) but with that script, shutter are opening and closing in loop.
Any suggestions ?
Thank you.
Barberousse
Re: Roller shutter group event coming from inside the group
I answer myself. I managed to do it, but the controlling device must be outside of the group it controls, otherwise the events go crazy, it loops, with my ZWave devices. See the 1st example. "Volet séjour" must not be part of group "Volets pièces de vie".
Control a shutter group from a single shutter
I attach another example where there is a slave shutter ("Volet salle d'eau RDC"). It opens or closes at the same time as the master shutter ("Volet chambre RDC"), and it even follows master shutter's planning.
Master / slave shutter configuration
By the way, with Blocky, you must look at open/close events on shutters, but you must use On/Off when setting actions, that's not very intuitive.
