@Zoviel:
I had this for some time, especially after not rebooting for too long. I don't see it anymore though, at least not any different than in the screenshot shown below. I strongly suggest that, if you didn't do that yet, you put your settings to beta updates (top right 'Setup' - 'Settings' - tab 'System' - Software updates release channel 'beta'), than update to the latest beta version.
If you're already running the latest version, I'd suggest you reboot Domoticz (top right 'Setup' - 'More options' - 'Restart system'). At your first time, it might fail to recognize all Zwave nodes. When you try again, you will probably have more luck. Works for me all the time: as you can see in my log below, my sensors are running fine. My timeout notifications are always only temporarily: node 10 is my Aeon 1.
@mvd87:
It's confusing, agreed. With a little help, I figured it out... I think.
When I'm looking at my own ID's, yours should be:
0000200: Motion
0000233: Alarm type
0000232: Alarm level
0000235: Burglar
Supposedly (heard this from Gizmocuz sometime ago) only temp+humidity, lux and UV are numeric sensors, giving a numeric value. You found those already (UV is working well in broad daylight, but not inside your house). The others (motion and vibration) only turn on or off. Compared with my Multisensor 5, the 0000200 must be motion. But... vibration is supposedly given by the Burglar sensor (on / off). I was disapointed by that as I hoped to be able to notice vibrations, but it doesn't work that way.
The other 2 sensors (Alarm type and Alarm level) are also to be found on the Multisensor 5. They don't do a lot for me, maybe Gizmocuz could explain. I read before that alarm type has something to do with the type of signal that triggers the multisensor in sending its signal (dunno how), and the level with the level of activation. But these 2 are very obscure for my, and I don't use 'em. You will find though, that your burglar is mostly triggered when your motion is triggered. I didn't get much extra from this one yet. But... the Lux-sensor is alot better than the one on the Multisensor 5. I think you got yourself a great sensor, and I hope it all works out the way it does for me since quite some time with both sensors.
- Screenshot log.png (106.68 KiB) Viewed 13150 times
