Buienradar settings
SweetPants
Re: Buienradar settings
Post by SweetPants »
Modified the script a little to get the Longitude and Latitude from the domoticz database
#!/usr/bin/perl -w
=head1 buienradar_rain.pl
Installation:
In Domoticz create a Dummy Percentage sensor.
Next go to the Devices overview, and write down the 'idx' value of the sensor.
Copy this file to another location and edit the setting below to match your situation.
cp /home/pi/domoticz/scripts/buienradar_rain_example.pl /home/pi/domoticz/buienradar_rain.pl
nano /home/pi/domoticz/buienradar_rain.pl
You might have to install perl or additional modules
DBI: CPAN
DBD::SQLite: CPAN
sudo perl -MCPAN -e shell
cpan{1] install DBI
cpan[2] install DBD::SQLite
exit
LWP: http://lwp.interglacial.com/ch01_03.htm
sudo apt-get install libjson-perl
Next add a Crontab rule:
crontab -e
Add the following line at the end:
*/5 * * * * perl /home/pi/domoticz/buienradar_rain.pl
In 5 minutes, the sensor should work
=cut
use strict;
use LWP::UserAgent;
use HTTP::Cookies;
use DBI;
my $domoticz_ip="127.0.0.1";
my $domoticz_port="8080";
my $domoticz_sensor_idx="307";
my $domoticz_user="pi";
my $domoticz_pass="<your pi password>";
my $driver="SQLite";
my $database="/home/pi/domoticz.db";
my $dbh = DBI->connect("DBI:$driver:dbname=$database",$domoticz_user, $domoticz_pass, { RaiseError => 1 }) or die $DBI::errstr;
my ($lat, $long) = split(/;/,$dbh->selectrow_array( qq(SELECT sValue FROM preferences WHERE Key = 'Location')));
my $duration=15;
my @user_agents = (
'Mozilla/4.0 (compatible; MSIE 4.01; Windows 98)'
my $ua = LWP::UserAgent->new(
#Set agent name, we are not a script! :)
agent => $user_agents[rand @user_agents],
cookie_jar => HTTP::Cookies->new(),
my ($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst) = localtime();
my $startTime=($hour*60)+$min;
my $endTime=$startTime+$duration;
my $url = "http://gps.buienradar.nl/getrr.php?lat=$lat&lon=$long";
my $response = $ua->get($url);
unless ($response->is_success) {
# hmm, let's retry
# still no luck; sleep and retry
sleep 1;
print "Could not connect to buienradar.nl.\n";
exit 0;
my $data = $response->content;
unless ($data =~ /\A((\d{3})?\|\d{2}:\d{2}\r?\n)+\z/) {
print "Could not parse the data returned by buienradar.nl.\n";
exit 0;
my $total_rain_predictions=0;
my $total_rain_values=0;
while ($data =~ s/\A(\d{3})?\|(\d{2}:\d{2})\r?\n//) {
my ($value, $mtime) = ($1, $2);
if (defined $value) {
my @hour_min = split(':', $mtime);
my $mhour = $hour_min[0];
my $mmin = $hour_min[1];
my $calc_time=($mhour*60)+$mmin;
if (($calc_time>=$startTime)&&($calc_time<=$endTime)) {
$value =~ s/\A0+(\d)/$1/;
$total_rain_predictions+=$value;
$total_rain_values+=1;
my $result = "0.0";
if ($total_rain_values!=0) {
my $rain_0_100=($total_rain_predictions/$total_rain_values)*0.392156862745098;
$result = sprintf("%.2f", $rain_0_100);
$url = "http://$domoticz_ip:$domoticz_port/json.htm?type=command&param=udevice&idx=$domoticz_sensor_idx&nvalue=0&svalue=$result";
print "Error sending data to domoticz!\n";
exit 0;
if (index($data, "\"OK\"") == -1) {
exit 0;
print "OK, precip=$result\n";
if ($dbh) { $dbh->disconnect(); }
gizmocuz
Post by gizmocuz »
you are not allowed to access the database directly, and on most linux systems, this might not work i think...
I leave the script as it is, its not to hard to add 2 values (latitude/longitude), and the overhead of installing perl sqlite is then also not needed
Bdw (for others), this is for the script inside the domoticz/scripts/buienradar_rain_example.pl
it is only suitable for dutch (and Belgium i suppose) users
SweetPants
gizmocuz wrote:you are not allowed to access the database directly, and on most linux systems, this might not work i think...
It works (on linux), and as far as I know multiple SELECT at the same time is supported.
Derik
Post by Derik »
The "normal" way is working great to.... :D :D
On a Cubieboard
gizmocuz
Post by gizmocuz »
Normally the database should be 'locked' and if one process (application) is using it, it should not (could not?) be opened by a second one
maybe it would be better to request the lat/lon value via json ?
SweetPants
gizmocuz wrote:maybe it would be better to request the lat/lon value via json ?
That's another option, will get into that this evening. I want to keep my scripts as easy as possible to save me from editing them every time I change something somewhere else. Thanks for the advise
SweetPants
Changed the script to use Domoticz config JSON
#!/usr/bin/perl -w
Installation:
DBI: CPAN
DBD::SQLite: CPAN
JSON: CPAN
cpan{1] install DBI
cpan[3] install JSON
exit
crontab -e
=cut
use strict;
use LWP::UserAgent;
use HTTP::Cookies;
use DBI;
use JSON;
use Data::Dumper;
my ($long, $lat);
my ($url, $response, $data);
my $duration=15;
my @user_agents = ( 'Mozilla/4.0 (compatible; MSIE 4.01; Windows 98)' );
# Get config from Domoticz
$url = "http://127.0.0.1:8080/json.htm?type=com ... =getconfig";
print "Could not connect to Domoticz.\n"; exit 0;
# Extract longitude and lattitude from JSON string
$data = decode_json($response->content);
$long = $data->{Longitude};
$lat = $data->{Latitude};
# hmm, let's retry
sleep 1;
exit 0;
exit 0;
my $result = "0.0";
exit 0;
exit 0;
jjnj
Post by jjnj »
How do you use this script on Windows?
gizmocuz
Post by gizmocuz »
You can't it's a bash script
SweetPants
gizmocuz wrote:You can't it's a bash script
But you probably can use it if you install ActiveState Perl on your Windows PC, install the right Perl Modules using Perls Packet Manager (ppm) and change the first line to where your Perl is installed. Make sure Perl is in your PATH when calling the script.
dutchnld
Domoticz version: 3.5974
Post by dutchnld »
Hi, I got this up and running by reading through this thread.
Works great, but I'd like to change the percentage Icon to a different Icon.
But for this type of device I can't change is.
Does anyone know how to workaround this?
Raspberry Pi Model 2 B w/ Domoticz 3.5974 + Monit + Pi-Hole + RaZberry Z-wave module + RFXcom 433 USB
gizmocuz
Post by gizmocuz »
That's not possible
Probably you are going to use this device for an event or script so what's an icon
dutchnld
Post by dutchnld »
In this case you're right. I like the overview to be nice with relevant logo's though.
But in other cases like dummy switches, I'd would be very useful.
Pity that's not possible.
assenzuid
Post by assenzuid »
When i run the script I get below error
perl buienradar_rain.pl
Can't locate LWP/UserAgent.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at buienradar_rain.pl line 2.
BEGIN failed--compilation aborted at buienradar_rain.pl line 2.
I have installed Perl following this quide: http://lwp.interglacial.com/ch01_03.htm
assenzuid
Post by assenzuid »
Solved with the following command sudo perl -MCPAN -e 'install LWP::UserAgent::Cached'
JaapKoppejan
Domoticz version: 4.11590
Post by JaapKoppejan »
Thanks a lot for posting your solution, that helped me as well!
